cgal-discuss - Re: [cgal-discuss] Cannot read my data file in off format
  • To:
  • Subject: Re: [cgal-discuss] Cannot read my data file in off format
  • Date: Thu, 12 Sep 2019 16:24:15 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Yes,
I am getting segmentation fault for this line.
CGAL::Polygon_mesh_processing::orient_to_bound_a_volume(mesh);
On Thu, Sep 12, 2019 at 4:27 PM Sebastien Loriot (GeometryFactory) <> wrote:
I can't reproduce the issue with master and CGAL-4.13.
What version are you using?
Could you run the debugger and point to the line where the segfault occur?
Thanks,
Sebastien.
On 9/12/19 9:49 PM, Shrabani Ghosh wrote:
> Thank You. Here it is.
> output_newvolume_bones.off
> <https://drive.google.com/file/d/1UqJWdpvHaHYP7no2T3DW7vYUya3AtTs1/view?usp=drive_web>
> On Thu, Sep 12, 2019 at 3:39 PM Sebastien Loriot (GeometryFactory)
> < <mailto:>> wrote:
>     The code looks correct. Can you share the input file?
>     (please upload it somewhere to avoid sending a large file
>     to all subscribers).
>     Sebastien.
>     On 9/12/19 9:13 PM, Shrabani Ghosh wrote:
>      > CGAL::Polygon_mesh_processing::orient_to_bound_a_volume(mesh);
>     //// this
>      > function is not working.
>      >    const char* filename = (argc > 1) ? argv[1] :
>      > "../data/output_newvolume_bones.off";
>      >    std::ifstream input(filename);
>      >    std::vector<K::Point_3> points;
>      >    std::vector<std::vector<std::size_t> > polygons;
>      >    if(!input || !CGAL::read_OFF(input, points, polygons) ||
>     points.empty())
>      >      std::cerr << "Cannot open file " << std::endl;
>      >      return EXIT_FAILURE;
>      >    CGAL::Polygon_mesh_processing::orient_polygon_soup(points,
>     polygons);
>      >    Polyhedron mesh;
>     CGAL::Polygon_mesh_processing::polygon_soup_to_polygon_mesh(points,
>      > polygons, mesh);
>      >    // Number the faces because 'orient_to_bound_a_volume' needs a
>     face
>      > <--> index map
>      >    int index = 0;
>      >    for(Polyhedron::Face_iterator fb=mesh.facets_begin(),
>      > fe=mesh.facets_end(); fb!=fe; ++fb)
>      >      fb->id() = index++;
>      >    if(CGAL::is_closed(mesh))
>      >    std::ofstream out("../data/output_newvolume_bones_orient.off");
>      >    out << mesh;
>      >    out.close();
>      >    return EXIT_SUCCESS;
>      > On Thu, Sep 12, 2019 at 3:03 PM Sebastien Loriot (GeometryFactory)
>      > < <mailto:>
>     <mailto: <mailto:>>> wrote:
>      >     What are you using precisely?
>      >     CGAL::Polygon_mesh_processing::reverse_face_orientations()?
>      >     How is the mesh read? You should post your code on
>     gist.github.com <http://gist.github.com>
>      >     <http://gist.github.com>
>      >     and the data set there, it would be easier to help you.
>      >     Sebastien.
>      >     On 9/12/19 5:48 PM, Shrabani Ghosh wrote:
>      >      > HI,
>      >      > I was able to use my surface mesh by changing the orientation.
>      >     But now I
>      >      > have a surface mesh which is a bigger one, and when I am
>     trying
>      >     to change
>      >      > the orientation, I am not able to do that. After some time, it
>      >     showing
>      >      > segmentation fault. How to solve this problem?
>      >      > Sent from: http://cgal-discuss.949826.n4.nabble.com/
>      >     You are currently subscribed to cgal-discuss.
>      >     To unsubscribe or access the archives, go to
>      > https://sympa.inria.fr/sympa/info/cgal-discuss
