Re: [cgal-discuss] make_mesh_3 missing disjoint components from polyhedral surface.
- To:
- Subject: Re: [cgal-discuss] make_mesh_3 missing disjoint components from polyhedral surface.
- Date: Tue, 1 Oct 2019 16:06:07 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
You might also have a look at this gist: https://gist.github.com/afabri/1bbf46c6fd4f742bd982 The idea would be to seed with some vertices of your input per connected component. Best, Andreas On 10/1/2019 3:53 PM, Mael wrote:
Hello,
Using the 'master' branch of CGAL, I cannot reproduce your issue: I get all 12 connected components. Which version of CGAL are you using? Best, Mael On 01/10/2019 15:25, rdzhao wrote: Is there anyone that could help? -- Andreas Fabri, PhD Chief Officer, GeometryFactory Editor, The CGAL Project phone: +33.492.954.912 skype: andreas.fabri |
- Re: [cgal-discuss] make_mesh_3 missing disjoint components from polyhedral surface., rdzhao, 10/01/2019
- Re: [cgal-discuss] make_mesh_3 missing disjoint components from polyhedral surface., Mael, 10/01/2019
- Re: [cgal-discuss] make_mesh_3 missing disjoint components from polyhedral surface., Andreas Fabri, 10/01/2019
- Re: [cgal-discuss] make_mesh_3 missing disjoint components from polyhedral surface., Laurent Rineau (CGAL/GeometryFactory), 10/02/2019
- Re: [cgal-discuss] make_mesh_3 missing disjoint components from polyhedral surface., rdzhao, 10/02/2019
