Re: [cgal-discuss] make_mesh_3 missing disjoint components from polyhedral surface.
- To:
- Subject: Re: [cgal-discuss] make_mesh_3 missing disjoint components from polyhedral surface.
- Date: Tue, 1 Oct 2019 14:37:14 -0500 (CDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
- Ironport-phdr: 9a23:Zgvt/BBU+yaJdlGTG0hxUyQJP3N1i/DPJgcQr6AfoPdwSPryosbcNUDSrc9gkEXOFd2Cra4d0KyK7+u5AjFIyK3CmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TW94jEIBxrwKxd+KPjrFY7OlcS30P2594HObwlSizexfL1/IA+5oAjeucUanIVvJ6YswRbVv3VEfPhby3l1LlyJhRb84cmw/J9n8ytOvv8q6tBNX6bncakmVLJUFDspPXw7683trhnDUBCA5mAAXWUMkxpHGBbK4RfnVZrsqCT6t+592C6HPc3qSL0/RDqv47t3RBLulSwKMSMy/mPKhcxqlK9VrhKvqQJ8zYHWboGbKfVxcb/Sc94BWWpMXNpdWzBdDo+gcYcCCfcKM+ZCr4n6olsDtQG+ChStBePv0DBIgWL90Ko70uQhCw7G2xYgH88IsHvJt9j1MbwSUf2vwKbW0DrDcupb1DHg44bGdRAhpOuDXbN2ccfJz0kgDRjKgU6UqYP7JT+ayuMNs22d4uF9Vuyvk3Yqpxx1rzWr3MshhIrEipgWx13F7yl0wYc4KNulQ0Bhe9GkCoFftySCOot2XMwiR2ZotT48yrAJo5K7ejIFx488yB7bdfOLaZSH4hXmVOqJIDd4gmxqeK6nihqv9UWtzvfwW8e33VpQrSdIk8PAu3EM2hDL78iIUPp9/kOv2TaV0ADT7/lJIEE0laXBLJ4h2KMwlpwOvknYGy/2g1j2gLWIeUo55+ik8/7nban+pp+AK490jRnzPbghmsOlBeQ0KxUBX2mA+eugyb3j5lb5Ta5Rjvw2l6nZqIrVKd4apq6/GQ9V05ws5wyxDze8g5wkmiwMI1tBPR6GlIP0IErmIfbiDP75jU7/vi1swqXcMq/hC5KFemrDmbD7YLBxw0tH1Uw+wc0JtMEcMa0IPP+mAhy5j9ffFBJsa1XlkdaiM81008YlYUzKB6aYNK3ItlrZtOc0Pq+BaJJH5G+gechg3ObniDoCoXFYfaSt2sJKOnbkWPJvKU+dbDznhdJTSD5W7Dp7d/TjjRi5aRAWf2y7DvA5/Sx9BY67X9/O
I found something more.
By making a subset of boundary vertices as seeds, somehow, the boundary
surface of the final tet mesh is limited. The triangle quality of the
boundary surface is consistent with the input surface mesh, in the sense
that if the input surface mesh has triangles with bad quality (too small,
too thin triangles), the tet mesh will be that as well.
Is there anything I can do to decoupling this relation? I need the tet mesh
to be relatively uniform in shape and size.
Thanks!!!! Thanks you so much for the help!
- Re: [cgal-discuss] make_mesh_3 missing disjoint components from polyhedral surface., rdzhao, 10/01/2019
- Re: [cgal-discuss] make_mesh_3 missing disjoint components from polyhedral surface., Mael, 10/01/2019
- Re: [cgal-discuss] make_mesh_3 missing disjoint components from polyhedral surface., Andreas Fabri, 10/01/2019
- Re: [cgal-discuss] make_mesh_3 missing disjoint components from polyhedral surface., Laurent Rineau (CGAL/GeometryFactory), 10/02/2019
- Re: [cgal-discuss] make_mesh_3 missing disjoint components from polyhedral surface., rdzhao, 10/02/2019
