cgal-discuss - Re: [cgal-discuss] make_mesh_3 missing disjoint components from polyhedral surface.
  • To:
  • Subject: Re: [cgal-discuss] make_mesh_3 missing disjoint components from polyhedral surface.
  • Date: Tue, 1 Oct 2019 14:15:48 -0500 (CDT)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
  • Ironport-phdr: 9a23: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
I've played with your code. It successfully captures all the components.
That's great!
Your offered treatment incorporates a subset of surface vertices as seeds.
But when I changes the seeds at a set of points inside the surface, the
program crashes with segmentation fault.
What should I do to insert only interior points as seeds?
Thanks.
