- To:
- Subject: [cgal-discuss] Remeshing to make the all the faces look similar
- Date: Mon, 21 Oct 2019 15:52:24 -0500 (CDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
Hello,
I have used Surface Mesh Simplification to simplify the mesh. But after
simplification, I can see the faces of the mesh do not look similar.
<http://cgal-discuss.949826.n4.nabble.com/file/t376134/Capture.jpg>
Is there any function which can remesh the existing mesh which will not
change anything in the mesh (Means will not increase or decrease in the
number of faces, edges, vertices) but the faces angles will be changed so
that the area of all the faces will be same and will look similar.
Thank You
Shrabani Ghosh
- [cgal-discuss] Remeshing to make the all the faces look similar, Shrabani Ghosh, 10/21/2019
- Re: [cgal-discuss] Remeshing to make the all the faces look similar, Andreas Fabri, 10/22/2019
- Re: [cgal-discuss] Remeshing to make the all the faces look similar, Shrabani Ghosh, 10/22/2019
