cgal-discuss - Re: [cgal-discuss] Remeshing to make the all the faces look similar
  • To:
  • Subject: Re: [cgal-discuss] Remeshing to make the all the faces look similar
  • Date: Tue, 22 Oct 2019 11:30:31 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23: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
Hello,
You should maybe right away have used isotropic remeshing.
https://doc.cgal.org/latest/Polygon_mesh_processing/index.html#PMPMeshing
Best,
Andreas
On 10/21/2019 10:52 PM, Shrabani Ghosh wrote:
Hello,
I have used Surface Mesh Simplification to simplify the mesh. But after
simplification, I can see the faces of the mesh do not look similar.
<http://cgal-discuss.949826.n4.nabble.com/file/t376134/Capture.jpg>
Is there any function which can remesh the existing mesh which will not
change anything in the mesh (Means will not increase or decrease in the
number of faces, edges, vertices) but the faces angles will be changed so
that the area of all the faces will be same and will look similar.
Thank You
Shrabani Ghosh
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912    skype: andreas.fabri
