- To:
- Subject: Re: [cgal-discuss] Remeshing to make the all the faces look similar
- Date: Tue, 22 Oct 2019 11:30:55 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hi,
I have used isotropic remeshing with these parameters.
double target_edge_length = 0.5;
unsigned int nb_iter = 1;
After applying remeshing the number of faces increased.
(170 faces)...(255edges)(87vertices)
Start remeshing of data/out3.off (170 faces)...
After isotropic remeshing
(970 faces)...(1455edges)(487vertices)
Remeshing done.
Remeshing done.
Can't I keep the number of faces, edges, vertices consistent in this process? I
Thank You
Shrabani Ghosh
Hello,
You should maybe right away have used isotropic remeshing.
https://doc.cgal.org/latest/Polygon_mesh_processing/index.html#PMPMeshing
Best,
Andreas
On 10/21/2019 10:52 PM, Shrabani Ghosh wrote:
Hello, I have used Surface Mesh Simplification to simplify the mesh. But after simplification, I can see the faces of the mesh do not look similar. <http://cgal-discuss.949826.n4.nabble.com/file/t376134/Capture.jpg> Is there any function which can remesh the existing mesh which will not change anything in the mesh (Means will not increase or decrease in the number of faces, edges, vertices) but the faces angles will be changed so that the area of all the faces will be same and will look similar. Thank You Shrabani Ghosh -- Sent from: http://cgal-discuss.949826.n4.nabble.com/-- Andreas Fabri, PhD Chief Officer, GeometryFactory Editor, The CGAL Project phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Remeshing to make the all the faces look similar, Shrabani Ghosh, 10/21/2019
- Re: [cgal-discuss] Remeshing to make the all the faces look similar, Andreas Fabri, 10/22/2019
- Re: [cgal-discuss] Remeshing to make the all the faces look similar, Shrabani Ghosh, 10/22/2019
