Re: [cgal-discuss] Delaunay refinement of an existing 3D Delaunay Triangulation
- To: "" <>
- Subject: Re: [cgal-discuss] Delaunay refinement of an existing 3D Delaunay Triangulation
- Date: Sun, 3 Nov 2019 16:30:19 +0000
- Accept-language: en-US
- Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=buckeyemail.osu.edu; dmarc=pass action=none header.from=buckeyemail.osu.edu; dkim=pass header.d=buckeyemail.osu.edu; arc=none
- Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=PzURppI8WNx4CAlveNykx3xIB36lTh4erQ2kmvdLsuo=; b=DLXE6QQ9fpfBjd1i5WXSoGsKtJSKKM21fusvnaAg9Y/NLgsICKpzbAhHYNRNgSXxpaGMQLF9aoNyUGAX/ZNKilSGxRPRFOYmkPZtOI29fKKzGjJxV469hzYx8otITfcHoIkHNyNyF9uMR9UbgkYYwDjCQywaaV0gXn3ZfTuTQ9AN4yCh82Cn7bvYyb/8lnDhzHUVYXaIB3WYa7CQLgaxft+9xUapMNGpyv7hX9EuHwLmSKSkGT4Qf5V4LpByjmpldHKsi0XYIYw0cVaBrAQmtssBGhrWCDKmqjFCI6ZCGplDL9DcXwzwn2wT/uHZ4kp54wfvhyNt+BcVB0LzYenRfQ==
- Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=YyxzNdvcVom4/JEyecfHZ6urwnJl+h3b85c54fkmPkpYUJBKMgh6PAAtnnp/zQFVK4sMpqd4C9J0yx0t0NhrE4fo7sgeQzK1LGWsUwZP93hNY5ke+vow3cHiVgC554onFDdDIlsk+Jgs41njynMg+SdizJTi2ey7caINXOmysUleDzH0GG6fU3SS6iu2P4+nlzQSGeTGahaqqRVURft4g607iQUw1ntIJUsd7jcO/MnLHRMWD3IXxLl5O/ciCXPPzQMVsLlytqv3WoPZss8h1cpDx2ve229k+K+6O5D0ccxRFc1N4e2o2kD5cE0PK3M6/ovV+3E8/agUx5VTJAAfbA==
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
HI Mael,
Thanks for the reply. I have looked into the 3D Mesh Generation package. The
problem is every mesh requires a Mesh_domain. The Mesh_domain must be an
instance of Labeled 3D image Gray, Scale Image or Polyhedron Mesh. But I just
want to input a 3D Delaunay Triangulation in the algorithm. Let me give some
details.
I have a point cloud that I have triangulated using Delaunay 3D
Triangulation. I just want to refine the initial triangulation and then want
to run my own algorithm on top of it. I cannot find a way to feed the 3D
triangulation directly in the refinement algorithms. I don’t know whether it
is possible in the current setup. In particular, I want to know whether there
exists a facility similar to TetGen where it can refine an already existing
3D tetrahedral mesh.
One possible way I can think of is to voxelize my 3D triangulation and
convert it as an image. But sometimes it is kind of an extra step
(voxelizing the triangulation).
Thanks in advance.
> On Nov 3, 2019, at 5:27 AM, Mael
> wrote:
> Hello,
> Have you seen the following package:
> https://doc.cgal.org/latest/Mesh_3/index.html#Chapter_3D_Mesh_Generation ?
> Mael
> On 02/11/2019 22:38, Mukherjee, Soham wrote:
>> Can we refine an existing Delaunay 3D Triangulation (Done by CGAL) using
>> 3D Delaunay Refinement ? If so what is the procedure? I referred to the
>> documentation but the procedure is not trivial.
>> Thanks,
>> Soham
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] Delaunay refinement of an existing 3D Delaunay Triangulation, Mukherjee, Soham, 11/02/2019
- Re: [cgal-discuss] Delaunay refinement of an existing 3D Delaunay Triangulation, Mael, 11/03/2019
- Re: [cgal-discuss] Delaunay refinement of an existing 3D Delaunay Triangulation, Mukherjee, Soham, 11/03/2019
- Re: [cgal-discuss] Delaunay refinement of an existing 3D Delaunay Triangulation, Andy Li, 11/20/2019
- Re: [cgal-discuss] Delaunay refinement of an existing 3D Delaunay Triangulation, Mukherjee, Soham, 11/20/2019
