- To:
- Subject: Re: [cgal-discuss] 3D surface mesh generation of two implicit spheres
- Date: Mon, 4 Nov 2019 17:39:47 -0600 (CST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
What you describe makes perfect sense.
Our objective is to perform a Poisson surface reconstruction of several
connected components (see my old post @
http://cgal-discuss.949826.n4.nabble.com/Poisson-reconstruction-of-multiple-connected-components-td4664371.html#a4664383).
I did a couple of tests using 20 initial points per component and it seems
to work fine.
Indeed, it is very unlikely that we will end up with 20 degenerate points
within one component.
Thanks again for your help,
G.
- Re: [cgal-discuss] 3D surface mesh generation of two implicit spheres, Gaetan, 11/05/2019
