cgal-discuss - Re: [cgal-discuss] Delaunay refinement of an existing 3D Delaunay Triangulation
  • To: "" <>
  • Subject: Re: [cgal-discuss] Delaunay refinement of an existing 3D Delaunay Triangulation
  • Date: Wed, 20 Nov 2019 22:40:58 +0000
  • Accept-language: en-US
  • Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=buckeyemail.osu.edu; dmarc=pass action=none header.from=buckeyemail.osu.edu; dkim=pass header.d=buckeyemail.osu.edu; arc=none
  • Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=iyQEXywsrbrFlJHTgz3Krqwuyq/RIOnG55Ta9qD2gU8=; b=LenK97FaonzUYSvush+xsMDNknMT9XRH3uk2viOBBsDE0NGbzuXbVzQ++ABmNpSSyoWvg8OnVBBdWydJjmmLCHsA1VaETrhOFww2HrjwvFLNFENH0dOYanlstd5WmQ09L7bkpOr/jMYTePmhtcKxhQyUG28PCGETmi/s6EYHcBGbZ6ifIFsk7lvOv34i8t+4J9q53ZTfsw8d6DP/gS10rcOfOIGdHD+8MIDl9VgHZhT4I8kjf7blHGYxtNVzoQ/IGeZ7emzV+tZpTimnoFTpds/16DxAwhv+9hOiJYNW1qxTxIUE32zAEnmJV/eivip0WdQzIaGVTONhR/CkHEW2ww==
  • Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=Oid1pd/SKd3zNbNE8h1VoAViPClPypeXZVTnBFjmDYfjS25DEwQEdPSUmUJNLlyzw3Oiv2FPO+J5L9F0Y3LPhTlzYJUkhVdjDnrviGnUhoGD/lxXWlDqmgDH6Cri3FutM1DWgrgtVv5N9TSMlDRFnQhuzOQbrqvS+vAqvES8TTsnDSJ5I4+wvC2rh0hmNlKhrFIR9dmzDn75Ke3VDyvV/bZfqjRObcYiNIV3nEpPG09D9ZZhvb6RmxU1ncwCgg74xnOUKNELvAACIN6mSDJpbYhKZtRstSv7XM48QWMIU4PYraGVLJjAGIc5ry0SZzd8efvFOF11hD9NQHPpv4SECQ==
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Can you copy paste the vertices so that I can take a look at it.
> On Nov 20, 2019, at 4:05 AM, Andy Li
> wrote:
> Hi Mukherjee,
> I have a question about 3D delaunay. After using delaunay triangulation, how
> could I get the triangular face information? Such as vertex index of each
> face. I output the information of six vertices which is
> "T.number_of_finite_facets() ". It shows 12 facets. I don't think so. What's
> more, I use "Finite_facets_iterator" to output each face parameter, I get a
> wrong result.
> Thanks.
> Andy Li
> Sent from: http://cgal-discuss.949826.n4.nabble.com/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
