cgal-discuss - [cgal-discuss] 回复: difference for 2d polygons return incorrect polygon
  • To: "" <>
  • Subject: [cgal-discuss] 回复: difference for 2d polygons return incorrect polygon
  • Date: Sun, 26 Apr 2020 15:25:12 +0000
  • Accept-language: zh-CN, en-US
  • Arc-authentication-results: i=1; mx.microsoft.com 1; spf=none; dmarc=none; dkim=none; arc=none
  • Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=SyTm6a/4HXKtfZH6YYrqNzMsKEZsuzQ+SbbMqVpyOrE=; b=Gk9aSNyf//e8IwzRODZxln7DT7uhRVOpOmeyjwkkfuWZOAgIF9Ja2IfZFdwngSmgzVBXT8Niz081xQu54aGOtaaEwDLOumyDvZvopJ1Cczgwv918pyV5OzDzCamqIcRW0GejARQrVtphRidlWPE6gS1nKE2XPfAsz1pmkmPEmLP9jT4C9WQFIUfXh1mCeocJQsKeDx+ZlGsCLfBgKzqsv0FW+478r2ZU8DMHGKqiiqGdqfYGwXcWlwatax++zlpAcTjYJPDLhYJZRxpljBGIkzKsdO9UicIL+MOAmYpS1nk5fyJ0TfZUuMGMgp4DDEnJBYiPcwk0w2Qn/F+UCiUwrg==
  • Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=ZsPeycy54SXSiwqdyG9yBJXZSr1WIzqgRtFBF5YPvKCjWhl1OA8XM6LLhmBY3mSoT8uOvH5V0zOo0MPyKPjmdXyQG1UjohuXStDQkeY9FSl7wemMoQaxWj/sISbuElrWsJQ4akbmkan6JR4Ur5++4qIqoLZYalBH1AXZzgRSAKf5i62U8DCcyD0j8/wrp5q572vij1UBaJiiedFvrWv6UNFKnnevL0ZMd0QljTxnDgAG6F+mo3CBQJBrjf9/nk/mQRpslbctpc8oaVhzf/y+BEUuqG2rdJo+er+2tY1f45NGqCvPN74SSGAB+8HfGojnAfwamUsI01/Iq59jq8LR1A==
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
  • Ironport-phdr: 9a23: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
The data of the tested hole should be able to cut the source polygon well, but the difference function does not return a cut polygon.
发件人: <> 代表 Efi Fogel <>
发送时间: 2020年4月26日 11:26
收件人: <>
主题: Re: [cgal-discuss] difference for 2d polygons return incorrect polygon
What do you think is wrong?
   ____  _        ____             _
  /_____/_) o    /__________  __  //
 (____ (   (    (    (_/ (_/-(-'_(/
                         _/
Hi,
    I want to compute difference of the given polygons. And I found the
CGAL::difference() to do it. But in some cases, the difference return
incorrect result polygon.
Here is my test code and data.
#include <iostream>
#include "print_utils.h"
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include <CGAL/Boolean_set_operations_2.h>
#include <list>
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
typedef Kernel::Point_2                                   Point_2;
typedef CGAL::Polygon_2<Kernel>                           Polygon_2;
typedef CGAL::Polygon_with_holes_2<Kernel>
Polygon_with_holes_2;
typedef std::list<Polygon_with_holes_2>                   Pwh_list_2;
Polygon_2 MakePolygon(const std::list<Point_2>& Polygon)
        Polygon_2 resultPolygon;
        for (std::list<Point_2>::const_iterator it = Polygon.cbegin(); it !=
Polygon.cend(); it++)
                resultPolygon.push_back(*it);
        return resultPolygon;
int main()
        Polygon_2 sourcePolygon;
        sourcePolygon.push_back(Point_2(-369.040009, 481.649994));
        sourcePolygon.push_back(Point_2(-369.040009, -439.420013));
        sourcePolygon.push_back(Point_2(220.240005, -439.420013));
        sourcePolygon.push_back(Point_2(220.240005, 481.649994));
        if (sourcePolygon.is_clockwise_oriented()) {
                sourcePolygon.reverse_orientation();
        std::list<Point_2> hole_1{ Point_2(220.240005, -121.932671),
                                                           Point_2(220.240005, -439.420013),
        std::list<Point_2> hole_2{ Point_2(-369.040009, 481.649994),
                                                           Point_2(220.240005, 481.649994),
                                                           Point_2(220.240005, 186.445908)
        std::list<Point_2> hole_3{      Point_2(-369.040009, 481.649994),
        Point_2(-369.040009, -439.420013),
        std::list<Polygon_2> allHoles;
        allHoles.push_back(MakePolygon(hole_1));
        allHoles.push_back(MakePolygon(hole_2));
        allHoles.push_back(MakePolygon(hole_3));
        for (Polygon_2 currentHole : allHoles)
                if (currentHole.is_clockwise_oriented()) {
                        currentHole.reverse_orientation();
                Pwh_list_2 difference;
                CGAL::difference(sourcePolygon, currentHole,
std::back_inserter(difference));
                if (difference.size() != 1) {
                        return -1;
                sourcePolygon = difference.front().outer_boundary();
        print_polygon(sourcePolygon);
        return 0;
