- To:
- Subject: Re: [cgal-discuss] 回复: 回复: difference for 2d polygons return incorrect polygon
- Date: Sun, 26 Apr 2020 20:46:55 -0500 (CDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
Hey Luoyu,
With these values the resultant polygon i am getting is - [ 5 vertices:
(-369.04 -439.42) (220.24 -121.933) (-49.0956 -267.043) (45.1425 274.162)
(-369.04 481.65) ].
See if it is the polygon you were expecting.
Regards,
Anmolpreet
- [cgal-discuss] difference for 2d polygons return incorrect polygon, Luoyu, 04/26/2020
- Re: [cgal-discuss] difference for 2d polygons return incorrect polygon, Efi Fogel, 04/26/2020
- [cgal-discuss] 回复: difference for 2d polygons return incorrect polygon, 落 域, 04/26/2020
- Re: [cgal-discuss] 回复: difference for 2d polygons return incorrect polygon, Efi Fogel, 04/26/2020
- [cgal-discuss] 回复: 回复: difference for 2d polygons return incorrect polygon, 落 域, 04/26/2020
- [cgal-discuss] 回复: 回复: difference for 2d polygons return incorrect polygon, 落 域, 04/27/2020
- Re: [cgal-discuss] 回复: 回复: difference for 2d polygons return incorrect polygon, axnmol, 04/27/2020
- [cgal-discuss] 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, 落 域, 04/27/2020
- Re: [cgal-discuss] 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, axnmol, 04/27/2020
- [cgal-discuss] 回复: 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, 落 域, 04/27/2020
- Re: [cgal-discuss] 回复: 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, axnmol, 04/27/2020
- [cgal-discuss] 回复: 回复: 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, 落 域, 04/27/2020
- Re: [cgal-discuss] 回复: 回复: 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, axnmol, 04/27/2020
- [cgal-discuss] 回复: 回复: 回复: 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, 落 域, 04/27/2020
- Re: [cgal-discuss] 回复: 回复: 回复: 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, axnmol, 04/27/2020
