- To:
- Subject: Re: [cgal-discuss] 回复: 回复: difference for 2d polygons return incorrect polygon
- Date: Sun, 26 Apr 2020 20:34:25 -0500 (CDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
Here is the right hole data,
std::list<Point_2> hole_1{ Point_2(220.240005, -121.932671),
Point_2(220.240005, -439.420013),
Point_2(-369.040009, -439.420013)
std::list<Point_2> hole_2{ Point_2(-369.040009, 481.649994),
Point_2(220.240005, 481.649994),
Point_2(220.240005, 186.445908)
std::list<Point_2> hole_3{ Point_2(45.1425400 , 274.162262 ),
Point_2(220.240005 , 186.445908 ),
Point_2(220.240005 , -121.932671),
Point_2(-49.0955925, -267.043030)
- [cgal-discuss] difference for 2d polygons return incorrect polygon, Luoyu, 04/26/2020
- Re: [cgal-discuss] difference for 2d polygons return incorrect polygon, Efi Fogel, 04/26/2020
- [cgal-discuss] 回复: difference for 2d polygons return incorrect polygon, 落 域, 04/26/2020
- Re: [cgal-discuss] 回复: difference for 2d polygons return incorrect polygon, Efi Fogel, 04/26/2020
- [cgal-discuss] 回复: 回复: difference for 2d polygons return incorrect polygon, 落 域, 04/26/2020
- Re: [cgal-discuss] 回复: 回复: difference for 2d polygons return incorrect polygon, Luoyu, 04/27/2020
- [cgal-discuss] 回复: 回复: difference for 2d polygons return incorrect polygon, 落 域, 04/27/2020
- Re: [cgal-discuss] 回复: 回复: difference for 2d polygons return incorrect polygon, axnmol, 04/27/2020
- [cgal-discuss] 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, 落 域, 04/27/2020
- Re: [cgal-discuss] 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, axnmol, 04/27/2020
- [cgal-discuss] 回复: 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, 落 域, 04/27/2020
- Re: [cgal-discuss] 回复: 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, axnmol, 04/27/2020
- [cgal-discuss] 回复: 回复: 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, 落 域, 04/27/2020
- Re: [cgal-discuss] 回复: 回复: 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, axnmol, 04/27/2020
- [cgal-discuss] 回复: 回复: 回复: 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, 落 域, 04/27/2020
- Re: [cgal-discuss] 回复: 回复: 回复: 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, axnmol, 04/27/2020
