Re: [cgal-discuss] 回复: 回复: 回复: 回复: 回复: difference for 2d polygons return incorrect polygon
- To:
- Subject: Re: [cgal-discuss] 回复: 回复: 回复: 回复: 回复: difference for 2d polygons return incorrect polygon
- Date: Mon, 27 Apr 2020 09:59:40 -0500 (CDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
Hey Luoyu,
Glad to know it worked. The type conversion of the Point_2 type and its
usability mainly depends on how your program works. Make sure to avoid any
type of downcasting. There are various solution available for that. I could
have given a further detailed solution, if i had a look at your program.
Moreover i think you can figure it out yourself. If still you need any
assistance, i would be glad to help.
Regards,
Anmolpreet Singh
- Re: [cgal-discuss] 回复: difference for 2d polygons return incorrect polygon, (continued)
- Re: [cgal-discuss] 回复: difference for 2d polygons return incorrect polygon, Efi Fogel, 04/26/2020
- [cgal-discuss] 回复: 回复: difference for 2d polygons return incorrect polygon, 落 域, 04/26/2020
- [cgal-discuss] 回复: 回复: difference for 2d polygons return incorrect polygon, 落 域, 04/27/2020
- Re: [cgal-discuss] 回复: 回复: difference for 2d polygons return incorrect polygon, axnmol, 04/27/2020
- [cgal-discuss] 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, 落 域, 04/27/2020
- Re: [cgal-discuss] 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, axnmol, 04/27/2020
- [cgal-discuss] 回复: 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, 落 域, 04/27/2020
- Re: [cgal-discuss] 回复: 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, axnmol, 04/27/2020
- [cgal-discuss] 回复: 回复: 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, 落 域, 04/27/2020
- Re: [cgal-discuss] 回复: 回复: 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, axnmol, 04/27/2020
- [cgal-discuss] 回复: 回复: 回复: 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, 落 域, 04/27/2020
- Re: [cgal-discuss] 回复: 回复: 回复: 回复: 回复: 回复: difference for 2d polygons return incorrect polygon, axnmol, 04/27/2020
