- To:
- Subject: Re: [cgal-discuss] Intersection algorithm and complexity
- Date: Thu, 14 May 2020 07:50:44 -0500 (CDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
Hi Augusto,
Similar to you, I am someone who enjoy CGAL very much. I recently came
across this package that describe your problem:
https://doc.cgal.org/latest/Polygon_mesh_processing/index.html
I tried it a few times and it gave great result. The page came with some
examples.
- Re: [cgal-discuss] Intersection algorithm and complexity, anh.tran, 05/14/2020
