[cgal-discuss] Calling create_exterior_skeleton_and_offset_polygons_2 freeze my computer
- To:
- Subject: [cgal-discuss] Calling create_exterior_skeleton_and_offset_polygons_2 freeze my computer
- Date: Thu, 14 May 2020 07:45:40 -0500 (CDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23:Leh46RXM8nPdT7d6t05/DQ5/y3TV8LGtZVwlr6E/grcLSJyIuqrYbBaPt8tkgFKBZ4jH8fUM07OQ7/m9Hz1eqsvb+Fk5M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aFRrwLxd6KfroEYDOkcu3y/qy+5rOaAlUmTaxe7x/IAi2oAnLssQbgIRuJ6YvxhDUvnZGZuNayH9yK1mOhRj8/MCw/JBi8yRUpf0s8tNLXLv5caolU7FWFSwqPG8p6sLlsxnDVhaP6WAHUmoKiBpIAhPK4w/8U5zsryb1rOt92C2dPc3rUbA5XCmp4ql3RBP0jioMKjg0+3zVhMNtlqJWuByvqRxhzYDXfY+aO+ZxcKzGcNMGR2dNQtpdWzBdDo+iaYYEEuoPPfxfr4n4v1YCowGxBQ+sBO/11j9InGX53as03+88FgzGwBYgEMgIsHTQsdX1KbkSUeGrw6nU1zrDafNW1Czy6IjNaB8hoPWMUahsfsrWzEkiDgXIhUifpoL5JT2azPgNs3SF4Op6U+Kik20qpgFvrzWv2MshhZfFi4EVx17K9St03Js4KNy3RUN1Y9OpH5tduS+VOoV4Xs4uX3xktDo6x7EauJO1fCYHxYghyhXCZfKHdI2I7QjiVOaXOTp4gmhqd6mkiBa270es0PHzVs6x0FtMsyFLkcHMu2gQ2xHX7sWLUPVw80S71TuM1g3f8OBJLEEymKHGMZAu2KQwmYAWsUnbHi/5hkH2jKiOe0Ui9eWk8eLnba/9qZCHM497lBvyPbgpmsy6Geg4Mw4OUHaH+emkybHu+Un0TK9Eg/A1iKXUs5HXKd4aq6O4GwNV15ws6xe7DzeoytQYmnwHIUpZeBKdlYfpPVXOIO3lDfehglSjjitryOrAPr3hGZjNIX3Dn63gfbZ58UJT1A0zzdVH65JOFr4BOO7zWlP2tNHAEhA5PBa7w+L+BNpg14MeQn6AArKCMKPJqlKI/eIuI+yUZIAPojr9Kv4l5+TvjXAjg1Mdc7OpjtMrbyWzEf1iZkmYenHxmcwpEGEQvwN4Qva5pkeFVGsZbnCyGb4m7zdxQNa6F47FQp2wnr2MwC69HrVZY2lHDhaHFnK+JNbMYOsFdC/HepwpqTcDT7X0E9ZwhyHrjxfzzv9cFsSR/yQZsZz5090svr/ckBgz8Xp/CMHPiDjRHVExpXsBQnoN5I46uVZ0kw7R3q1xgvgeHttWtasQD1UKcKXExuk/MOjcHwLMetDQFQSgHpOgCDs7St93yNgLMR9w
Hi,
I have a polygon (attached as a text file) and I would like to compute the
exterior offset for it. However, for some reason, as soon as I called the
function, it freeze my computer. It almost feel like a memory leak or some
sort.
Is this a bug or something wrong with my polygon? Thank you.
- [cgal-discuss] Calling create_exterior_skeleton_and_offset_polygons_2 freeze my computer, anh.tran, 05/14/2020
- Re: [cgal-discuss] Calling create_exterior_skeleton_and_offset_polygons_2 freeze my computer, Sebastien Loriot (GeometryFactory), 05/14/2020
- Re: [cgal-discuss] Calling create_exterior_skeleton_and_offset_polygons_2 freeze my computer, Trần Anh, 05/14/2020
- Re: [cgal-discuss] Calling create_exterior_skeleton_and_offset_polygons_2 freeze my computer, Peter Palfrader, 05/14/2020
