Re: [cgal-discuss] Calling create_exterior_skeleton_and_offset_polygons_2 freeze my computer
- To:
- Subject: Re: [cgal-discuss] Calling create_exterior_skeleton_and_offset_polygons_2 freeze my computer
- Date: Thu, 14 May 2020 15:19:26 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Seems the attachment did not make it :)
Sebastien.
On 5/14/20 2:45 PM, anh.tran wrote:
Hi,
I have a polygon (attached as a text file) and I would like to compute the
exterior offset for it. However, for some reason, as soon as I called the
function, it freeze my computer. It almost feel like a memory leak or some
sort.
Is this a bug or something wrong with my polygon? Thank you.
- [cgal-discuss] Calling create_exterior_skeleton_and_offset_polygons_2 freeze my computer, anh.tran, 05/14/2020
- Re: [cgal-discuss] Calling create_exterior_skeleton_and_offset_polygons_2 freeze my computer, Sebastien Loriot (GeometryFactory), 05/14/2020
- Re: [cgal-discuss] Calling create_exterior_skeleton_and_offset_polygons_2 freeze my computer, Trần Anh, 05/14/2020
- Re: [cgal-discuss] Calling create_exterior_skeleton_and_offset_polygons_2 freeze my computer, Peter Palfrader, 05/14/2020
