Re: [cgal-discuss] Calling create_exterior_skeleton_and_offset_polygons_2 freeze my computer
- To:
- Subject: Re: [cgal-discuss] Calling create_exterior_skeleton_and_offset_polygons_2 freeze my computer
- Date: Thu, 14 May 2020 22:51:43 +0930
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hi,
Sorry I don't know why, I attached it again.
For reference, the offset distance I used is 1.
Thanks & Regards
Anh Tran
Seems the attachment did not make it :)
Sebastien.
On 5/14/20 2:45 PM, anh.tran wrote:
> Hi,
> I have a polygon (attached as a text file) and I would like to compute the
> exterior offset for it. However, for some reason, as soon as I called the
> function, it freeze my computer. It almost feel like a memory leak or some
> sort.
> Is this a bug or something wrong with my polygon? Thank you.
> Sent from: http://cgal-discuss.949826.n4.nabble.com/
7.702373401121616325e+01 2.694999999999999929e+01
7.754419539029285602e+01 2.696268691007603024e+01
7.839115939956381851e+01 2.699344442436958502e+01
7.880134402449601794e+01 2.704315247002822176e+01
8.063303974741344859e+01 2.735328708764639316e+01
8.068416205694595078e+01 2.736229700401128895e+01
8.094938040932527201e+01 2.743494141878730019e+01
8.229723331833449151e+01 2.798738534953183432e+01
8.344199001231868351e+01 2.859555673765283856e+01
8.376994961080727364e+01 2.882449032765908470e+01
8.505070900780530962e+01 2.991720691019036948e+01
8.552269896678015471e+01 3.040876569315777544e+01
8.612696955888556261e+01 3.121201147667801834e+01
8.701133683688003373e+01 3.266403541093183804e+01
8.703000207721910897e+01 3.270280335979175845e+01
8.759035666862845915e+01 3.434492227185592839e+01
8.764547625419639587e+01 3.456021166113357879e+01
8.781410278278745807e+01 3.532818619053627884e+01
8.788700986396746373e+01 3.610181558970892013e+01
8.799000244140623295e+01 3.781852025680237972e+01
8.799000244140624716e+01 4.068025360545996705e+01
8.808545311083562979e+01 4.274639529922377079e+01
8.810874113314885392e+01 4.343818274506156740e+01
8.822588943776737835e+01 4.445248383575398776e+01
8.853052101495933357e+01 4.602909914432062521e+01
8.859574025493245131e+01 4.626635491166547354e+01
8.871060878470458988e+01 4.673603568811956421e+01
8.941167788661621785e+01 4.853254713736417614e+01
8.969655662383489414e+01 4.912626977149895424e+01
9.077729466151649262e+01 5.080580744108706170e+01
9.110343698158598613e+01 5.123540029654129313e+01
9.256948747366091368e+01 5.275533212906700697e+01
9.284696284060031246e+01 5.300278620178560374e+01
9.302097370115500041e+01 5.313104541540974424e+01
9.341481422491555975e+01 5.344326584108395650e+01
9.466602593346607364e+01 5.435686126285307296e+01
9.618727069017609210e+01 5.530568432958164493e+01
9.644538965238497497e+01 5.546612081416109419e+01
9.871461512007320493e+01 5.680029324688960202e+01
1.058047404349647991e+02 6.098056231601095334e+01
1.062138105759155877e+02 6.121949578837228501e+01
1.064615502056315819e+02 6.138392348678229382e+01
1.067351182773116847e+02 6.158169293432153779e+01
1.070129596366826945e+02 6.180660118028751526e+01
1.075216363489243747e+02 6.222812904176144855e+01
1.077111284244142695e+02 6.238317713759393968e+01
1.080164702423135168e+02 6.270276746721343386e+01
1.089258641779946544e+02 6.389259487720814690e+01
1.090027654304259244e+02 6.401982542325913528e+01
1.092814596030791847e+02 6.465682205842723818e+01
1.095505454923185340e+02 6.527233295310334427e+01
1.097749206711504542e+02 6.598786482159840716e+01
1.097909699759971716e+02 6.607946213561342574e+01
1.099339641459932864e+02 6.690204731231585811e+01
1.100154240787823738e+02 6.757285281620562500e+01
1.100350006103515597e+02 6.787120224023871629e+01
1.100350006103515597e+02 8.479512954589577589e+01
1.100563789813061391e+02 8.501096012074567909e+01
1.101264092522127953e+02 8.627540149841931338e+01
1.101293228220217770e+02 8.629835519902997021e+01
1.101338301232387238e+02 8.631504457121371843e+01
1.104638327857012854e+02 8.763110350370958201e+01
1.106609494272675818e+02 8.813537536174013098e+01
1.109251866033192755e+02 8.860986236990483178e+01
1.115717081234952843e+02 8.949192406766754004e+01
1.117755639467349056e+02 8.971052356903220470e+01
1.123973591591318240e+02 9.022156780189033043e+01
1.125114369710565398e+02 9.029445851708922532e+01
1.133279010977602610e+02 9.081340544734307230e+01
1.133225419462555408e+02 9.081072587159071929e+01
1.144949429018960103e+02 9.119664115451682562e+01
1.149563902420826338e+02 9.130439721520367868e+01
1.150647027946715326e+02 9.132875030678884798e+01
1.151156977487316340e+02 9.133895071827100764e+01
1.165240677014862882e+02 9.143387297945071168e+01
1.168152036604137578e+02 9.145000000000000284e+01
1.319700012207031250e+02 9.145000000000000284e+01
1.319700012207031250e+02 9.154999999999999716e+01
1.168124361100940547e+02 9.154999999999999716e+01
1.165179397448026464e+02 9.153368683500237069e+01
1.151024724172839626e+02 9.143828622020555486e+01
1.150439245246643480e+02 9.142657501059393610e+01
1.149340516524488578e+02 9.140187109534265630e+01
1.144678866879477113e+02 9.129301338649879938e+01
1.132843458711274138e+02 9.090343123290155347e+01
1.132785899911068555e+02 9.090055329289130270e+01
1.124576944986688716e+02 9.037878977392429647e+01
1.123384806846181760e+02 9.030261737877378891e+01
1.117069494809994552e+02 8.978357127960047990e+01
1.114945455386140765e+02 8.955580542451990311e+01
1.108408503839854404e+02 8.866395659982180177e+01
1.105702822621855006e+02 8.817810120075985481e+01
1.103683815697674078e+02 8.766159058808727877e+01
1.100370530554719295e+02 8.634024412507483248e+01
1.100309860158688195e+02 8.631777944452467466e+01
1.100267584723965797e+02 8.628447398986192240e+01
1.099566520245532502e+02 8.501865718882463341e+01
1.099350006103515653e+02 8.480007003906516161e+01
1.099350006103515653e+02 6.787447952245658200e+01
1.099158198177020438e+02 6.758216122188032671e+01
1.098350025288113443e+02 6.691664775604348847e+01
1.096924589790806834e+02 6.609665480774533819e+01
1.096775482009198441e+02 6.601155534441721784e+01
1.094567482088533552e+02 6.530742473732640008e+01
1.091898386146319098e+02 6.469689193081470080e+01
1.089137842521912916e+02 6.406592897127212893e+01
1.088431024968101042e+02 6.394898837474497810e+01
1.079403626434288554e+02 6.276786699323579199e+01
1.076430585873045374e+02 6.245668950058962565e+01
1.074580694616228556e+02 6.230532585325732953e+01
1.069495952949581294e+02 6.188396583631389092e+01
1.066743208096023210e+02 6.166113543481902326e+01
1.064045844379230488e+02 6.146613602249507835e+01
1.061608995070922532e+02 6.130439947529956157e+01
1.057541279732393633e+02 6.106680859463520505e+01
9.866387914262348602e+01 5.688646670184078147e+01
9.639364538179547992e+01 5.555170145146414740e+01
9.613441510084781783e+01 5.539057421533873793e+01
9.461000556067479295e+01 5.443977722591648671e+01
9.335424400262316169e+01 5.352285964719707323e+01
9.296022747071988590e+01 5.321049968957040477e+01
9.278388127561069609e+01 5.308051915710113633e+01
9.250012312204206921e+01 5.282746206038603987e+01
9.102736135825773545e+01 5.130057229867353641e+01
9.069530055332735685e+01 5.086318364778015422e+01
8.960909217987601494e+01 4.917514471824718214e+01
8.931988949619615425e+01 4.857241044320220169e+01
8.861504429146728512e+01 4.676622261266165737e+01
8.849894053120048909e+01 4.629149115767049238e+01
8.843307151433747038e+01 4.605187161983948840e+01
8.812698531809192559e+01 4.446772795623818553e+01
8.800893464810113187e+01 4.344561394683297095e+01
8.798553077588314864e+01 4.275038509628403460e+01
8.789000244140623863e+01 4.068256225147361960e+01
8.789000244140625284e+01 3.782151727981871403e+01
8.778729128349345956e+01 3.610950338001766369e+01
8.771511779826720101e+01 3.534365829188559616e+01
8.754817303779589110e+01 3.458334302636649227e+01
8.749445168098100112e+01 3.437351492296825484e+01
8.693729833781993932e+01 3.274077726764964780e+01
8.692337080472155719e+01 3.271184959883377275e+01
8.604411198408311634e+01 3.126821313269699942e+01
8.544640198536822595e+01 3.047368822529925581e+01
8.498202109473366761e+01 2.999005398458497851e+01
8.370873386087251333e+01 2.890371249216516958e+01
8.338972080311103241e+01 2.868102407289404354e+01
8.225470759963424427e+01 2.807802907917911028e+01
8.091708992758883312e+01 2.752978026090021046e+01
8.066222771356189014e+01 2.745997243568596957e+01
8.061601420766474746e+01 2.745182765844734618e+01
7.878697384659768943e+01 2.714214263495223278e+01
7.838331569809241728e+01 2.709322549750540077e+01
7.754116227572284004e+01 2.706264267976771976e+01
7.702251537843227425e+01 2.705000000000000071e+01
3.247000122070312500e+01 2.705000000000000071e+01
- [cgal-discuss] Calling create_exterior_skeleton_and_offset_polygons_2 freeze my computer, anh.tran, 05/14/2020
- Re: [cgal-discuss] Calling create_exterior_skeleton_and_offset_polygons_2 freeze my computer, Sebastien Loriot (GeometryFactory), 05/14/2020
- Re: [cgal-discuss] Calling create_exterior_skeleton_and_offset_polygons_2 freeze my computer, Trần Anh, 05/14/2020
- Re: [cgal-discuss] Calling create_exterior_skeleton_and_offset_polygons_2 freeze my computer, Peter Palfrader, 05/14/2020
