- To:
- Subject: [cgal-discuss] Shape Detection-size of the model
- Date: Tue, 16 Jun 2020 08:27:55 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hello,
I am new to CGAL and have been trying to adjust it for my own purpose. My aim is to detect all the reference spheres (with known size, radius =7.25cm) in a huge point cloud (40 millions). I use the efficient RANSAC functions in the Shape Detection Examples. However, I did not find out any method to define the size of the model. I added the following code into “Sphere.h” to select the radius within the range:
if (radius > 0.08 || radius < 0.06) {
this->m_is_valid = false;
return;
With this code, I can only choose some spheres from the spheres who are already detected. Which means, I will still get the same results.
I would like to know, is there any possibilities in CGAL that I can detect a certain sized model? More like fitting a model to the point clouds.
Thanks in advance.
Regards.
Muyu Liu
- [cgal-discuss] Shape Detection-size of the model, Muyu Liu, 06/16/2020
- Re: [cgal-discuss] Shape Detection-size of the model, Simon Giraudot, 06/16/2020
