cgal-discuss - Re: [cgal-discuss] No available formula with the name "cgal-qt5"
  • To:
  • Subject: Re: [cgal-discuss] No available formula with the name "cgal-qt5"
  • Date: Fri, 26 Jun 2020 08:56:23 -0600
  • Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=usask.ca; dmarc=pass action=none header.from=usask.ca; dkim=pass header.d=usask.ca; arc=none
  • Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=PKGs0q5gZ/KytA6TT4ipsQ/sn6Mb5YWwe3bStDexIKE=; b=kHY5yAil5GWHzFcW1okYQO1NxW8D4iGP+n5yZRXesm6sOrwd6yaH77KQjZ4/vZWClURLOn+eAXakihYX5k2zdDKut2JflgNuc+O6/cTSt02YiB8w3T2YPmGr0fVlDBOq9Ujx/qcm1rXvHWf6Czb8X+JtyIXhw/T0UwBV4VqynJT2AZ0mJ3fKg/vhD9R+7lp4FCXcd0jKxUkkm/ig7gmFzN5CbNgh1MVGUmp3ekCZhSgSnJfes8l51N6bIDX70Fk0VOHQSmyUK02KIjMeP2VRooRuYHMzx0TjdukQk2uKvKpgcIZUnQjFMscA/LPL3PSvarnKCrtrwyZQTIwhTCCJZA==
  • Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=UjlUwQb141cay+7Br0WZqI10RC18c4el/25jE/rVpxgqsAjZLT2lrVBjqmvg6rZvT+2lgwqi9PpHRLt685FzWr73WpcLLXMdSSkBRO93nOEYys51gY/G3lEUtzvtwXeujS4ia9VGDR0I4gFAPlhhUgcz3Upcp/JUTu2iuSsId2LrYUIdMRzAH4gBPbyVyPRfCY1ooV8be5tcn7WW+P3AOOrVODFR+AM8TdWL+0B185hv3zMnuZpavqduaBB97IwKoxbGuj7CjORO6o3qMH38Ulv6/jvUUtxZ2lc+RxkQxmnXcB38x7HpcR8X4+xOk2ptq7jY9OBEU+xo0+6ckc+iEA==
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
  • Ironport-phdr: 9a23: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
That's good to know, thanks!
On Fri, Jun 26, 2020 at 8:28 AM Laurent Rineau (CGAL/GeometryFactory) <> wrote:
CAUTION: This email originated from outside of the University of Saskatchewan. Do not click links or open attachments unless you recognize the sender and know the content is safe. If in doubt, please forward suspicious emails to
On Friday, June 26, 2020 12:19:54 AM CEST Chris Marsh wrote:
> -DQt5_DIR=`brew --prefix qt5`/lib/cmake/Qt5
As a side note, I think everybody should use `CMAKE_PREFIX_PATH` instead of
specific variables like `Qt5_DIR`:
    cmake -DCMAKE_PREFIX_PATH=`brew --prefix qt5` -DCMAKE_BUILD_TYPE=Release .
Advantages:
  - no need to retrieve the name of the variables `Qt5_DIR`, `Boost_DIR`,
`ZLIB_DIR` (or `Zlib_DIR`, who knows?),
  - CMake is smart enough to search in the platform-dependent sub-directories
like `lib/cmake/Qt5` by itself.
Laurent Rineau, PhD
R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
Release Manager of the CGAL Project       http://www.cgal.org/
Chris Marsh, PhD
chrismarsh.ca
