- To:
- Subject: [cgal-discuss] No available formula with the name "cgal-qt5"
- Date: Mon, 15 Jun 2020 17:05:27 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hello,
I am using Catalina Version 10.15.2. I wish to run cgal - qt examples. However while installing cga-qt5 using brew, I run into the following error:
"No available formula with the name "cgal-qt5" "
I could not find any documentation on how to resolve this issue.
Regards
- [cgal-discuss] No available formula with the name "cgal-qt5", Himanshu Sharma, 06/15/2020
- Re: [cgal-discuss] No available formula with the name "cgal-qt5", Maxime Gimeno, 06/16/2020
- Re: [cgal-discuss] No available formula with the name "cgal-qt5", Laurent Rineau (CGAL/GeometryFactory), 06/17/2020
- Re: [cgal-discuss] No available formula with the name "cgal-qt5", Himanshu Sharma, 06/23/2020
- Re: [cgal-discuss] No available formula with the name "cgal-qt5", Maxime Gimeno, 06/24/2020
- Re: [cgal-discuss] No available formula with the name "cgal-qt5", Himanshu Sharma, 06/25/2020
- Re: [cgal-discuss] No available formula with the name "cgal-qt5", Maxime Gimeno, 06/25/2020
- Re: [cgal-discuss] No available formula with the name "cgal-qt5", Chris Marsh, 06/26/2020
- Re: [cgal-discuss] No available formula with the name "cgal-qt5", Himanshu Sharma, 06/26/2020
- Re: [cgal-discuss] No available formula with the name "cgal-qt5", Laurent Rineau (CGAL/GeometryFactory), 06/26/2020
