- To:
- Cc:
- Subject: Re: [cgal-discuss] Building with cmake on Windows.
- Date: Tue, 18 Aug 2020 09:59:30 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hi All,
I was trying to build demos using the latest 5.0.3 version on Windows using cmake . I have set up QT5_dir and QTDIR
Qt5_DIR=D:\Qt\5.12.7\msvc2017_64\lib\cmake\Qt5
QTDIR=D:\Qt\5.12.7\msvc2017_64
D:\CGAL-5.0.3\build\debug>cmake D:\CGAL-5.0.3 -DCMAKE_BUILD_TYPE=Debug
I get some very obscure cmake QT related messages – I am including the “Trace” from cmake
-- Configuring demo in demo/Triangulation_3
CMake Error at D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake:211 (configure_file):
configure_file Problem configuring file
Call Stack (most recent call first):
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake:281 (_QT5_PARSE_QRC_FILE)
demo/Triangulation_3/CMakeLists.txt:57 (qt5_add_resources)
Here is the trace from cmake.
/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(202): if(NOT IS_ABSOLUTE cgal_logo.xpm )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(203): set(RC_FILE D:/CGAL-5.0.3/demo/resources/cgal_logo.xpm )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(205): set(RC_DEPENDS D:/CGAL-5.0.3/demo/resources/about_CGAL.html;D:/CGAL-5.0.3/demo/resources/cgal_logo_ipe_2013.png;D:/CGAL-5.0.3/demo/resources/cgal_logo_ipe_2013.png D:/CGAL-5.0.3/demo/resources/cgal_logo.xpm )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(210): qt5_make_output_file(D:/CGAL-5.0.3/demo/resources/CGAL.qrc qrc.depends out_depends )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(43): string(LENGTH D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5 _binlength )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(44): string(LENGTH D:/CGAL-5.0.3/demo/resources/CGAL.qrc _infileLength )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(45): set(_checkinfile D:/CGAL-5.0.3/src/CGAL_Qt5 )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(46): if(_infileLength GREATER _binlength )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(53): else()
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(54): file(RELATIVE_PATH rel D:/CGAL-5.0.3/src/CGAL_Qt5 D:/CGAL-5.0.3/demo/resources/CGAL.qrc )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(56): if(WIN32 AND rel MATCHES ^([a-zA-Z]):(.*)$ )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(59): set(_outfile D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/../../demo/resources/CGAL.qrc )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(60): string(REPLACE .. __ _outfile D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/../../demo/resources/CGAL.qrc )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(61): get_filename_component(outpath D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/__/__/demo/resources/CGAL.qrc PATH )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(62): string(REGEX REPLACE \.[^.]*$ _outfile D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/__/__/demo/resources/CGAL.qrc )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(63): file(MAKE_DIRECTORY D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/__/__/demo/resources )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(64): set(out_depends D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/__/__/demo/resources/D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/__/__/demo/resources/CGAL.qrc.depends )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(211): configure_file(D:/CGAL-5.0.3/demo/resources/CGAL.qrc D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/__/__/demo/resources/D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/__/__/demo/resources/CGAL.qrc.depends COPYONLY )
- [cgal-discuss] Building with cmake on Windows., Andrew Cunningham, 08/14/2020
- Re: [cgal-discuss] Building with cmake on Windows., Maxime Gimeno, 08/18/2020
- Re: [cgal-discuss] Building with cmake on Windows., Andrew Cunningham, 08/18/2020
- Re: [cgal-discuss] Building with cmake on Windows., Maxime Gimeno, 08/19/2020
- Re: [cgal-discuss] Building with cmake on Windows., Andrew Cunningham, 08/19/2020
