cgal-discuss - Re: [cgal-discuss] Building with cmake on Windows.
  • To:
  • Subject: Re: [cgal-discuss] Building with cmake on Windows.
  • Date: Wed, 19 Aug 2020 08:27:18 -0700
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23: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
Yes, absolutely. Completely cleaned the "build" directory.
On Tue, Aug 18, 2020 at 11:19 PM Maxime Gimeno <> wrote:
Did you clean your CMakeCache before trying ?
Le mar. 18 août 2020 à 19:47, Andrew Cunningham <> a écrit :
Sadly, removing the definition of QTDIR made no difference. CMake fails in the identical manner.
On Tue, Aug 18, 2020 at 12:59 AM Maxime Gimeno <> wrote:
Hi,
I think your problem is due to QTDIR. You shouldn't have to specify that. Qt5_DIR is enough, and it is possible that both paths are somehow interfering.
Le ven. 14 août 2020 à 21:21, Andrew Cunningham <> a écrit :
Hi All,
I was trying to build demos using the latest 5.0.3 version on Windows using cmake . I have set up QT5_dir and QTDIR
 Qt5_DIR=D:\Qt\5.12.7\msvc2017_64\lib\cmake\Qt5
QTDIR=D:\Qt\5.12.7\msvc2017_64
D:\CGAL-5.0.3\build\debug>cmake  D:\CGAL-5.0.3  -DCMAKE_BUILD_TYPE=Debug
I get some very obscure cmake QT related messages – I am including the “Trace” from cmake
-- Configuring demo in demo/Triangulation_3
CMake Error at D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake:211 (configure_file):
  configure_file Problem configuring file
Call Stack (most recent call first):
  D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake:281 (_QT5_PARSE_QRC_FILE)
  demo/Triangulation_3/CMakeLists.txt:57 (qt5_add_resources)
Here is the trace from cmake.
/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(202):  if(NOT IS_ABSOLUTE cgal_logo.xpm )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(203):  set(RC_FILE D:/CGAL-5.0.3/demo/resources/cgal_logo.xpm )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(205):  set(RC_DEPENDS D:/CGAL-5.0.3/demo/resources/about_CGAL.html;D:/CGAL-5.0.3/demo/resources/cgal_logo_ipe_2013.png;D:/CGAL-5.0.3/demo/resources/cgal_logo_ipe_2013.png D:/CGAL-5.0.3/demo/resources/cgal_logo.xpm )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(210):  qt5_make_output_file(D:/CGAL-5.0.3/demo/resources/CGAL.qrc  qrc.depends out_depends )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(43):  string(LENGTH D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5 _binlength )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(44):  string(LENGTH D:/CGAL-5.0.3/demo/resources/CGAL.qrc _infileLength )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(45):  set(_checkinfile D:/CGAL-5.0.3/src/CGAL_Qt5 )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(46):  if(_infileLength GREATER _binlength )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(53):  else()
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(54):  file(RELATIVE_PATH rel D:/CGAL-5.0.3/src/CGAL_Qt5 D:/CGAL-5.0.3/demo/resources/CGAL.qrc )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(56):  if(WIN32 AND rel MATCHES ^([a-zA-Z]):(.*)$ )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(59):  set(_outfile D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/../../demo/resources/CGAL.qrc )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(60):  string(REPLACE .. __ _outfile D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/../../demo/resources/CGAL.qrc )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(61):  get_filename_component(outpath D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/__/__/demo/resources/CGAL.qrc PATH )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(62):  string(REGEX REPLACE \.[^.]*$  _outfile D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/__/__/demo/resources/CGAL.qrc )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(63):  file(MAKE_DIRECTORY D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/__/__/demo/resources )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(64):  set(out_depends D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/__/__/demo/resources/D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/__/__/demo/resources/CGAL.qrc.depends )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(211):  configure_file(D:/CGAL-5.0.3/demo/resources/CGAL.qrc D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/__/__/demo/resources/D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/__/__/demo/resources/CGAL.qrc.depends COPYONLY )
