cgal-discuss - Re: [cgal-discuss] Building with cmake on Windows.
  • To:
  • Subject: Re: [cgal-discuss] Building with cmake on Windows.
  • Date: Tue, 18 Aug 2020 10:47:07 -0700
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23: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
Sadly, removing the definition of QTDIR made no difference. CMake fails in the identical manner.
On Tue, Aug 18, 2020 at 12:59 AM Maxime Gimeno <> wrote:
Hi,
I think your problem is due to QTDIR. You shouldn't have to specify that. Qt5_DIR is enough, and it is possible that both paths are somehow interfering.
Le ven. 14 août 2020 à 21:21, Andrew Cunningham <> a écrit :
Hi All,
I was trying to build demos using the latest 5.0.3 version on Windows using cmake . I have set up QT5_dir and QTDIR
 Qt5_DIR=D:\Qt\5.12.7\msvc2017_64\lib\cmake\Qt5
QTDIR=D:\Qt\5.12.7\msvc2017_64
D:\CGAL-5.0.3\build\debug>cmake  D:\CGAL-5.0.3  -DCMAKE_BUILD_TYPE=Debug
I get some very obscure cmake QT related messages – I am including the “Trace” from cmake
-- Configuring demo in demo/Triangulation_3
CMake Error at D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake:211 (configure_file):
  configure_file Problem configuring file
Call Stack (most recent call first):
  D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake:281 (_QT5_PARSE_QRC_FILE)
  demo/Triangulation_3/CMakeLists.txt:57 (qt5_add_resources)
Here is the trace from cmake.
/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(202):  if(NOT IS_ABSOLUTE cgal_logo.xpm )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(203):  set(RC_FILE D:/CGAL-5.0.3/demo/resources/cgal_logo.xpm )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(205):  set(RC_DEPENDS D:/CGAL-5.0.3/demo/resources/about_CGAL.html;D:/CGAL-5.0.3/demo/resources/cgal_logo_ipe_2013.png;D:/CGAL-5.0.3/demo/resources/cgal_logo_ipe_2013.png D:/CGAL-5.0.3/demo/resources/cgal_logo.xpm )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(210):  qt5_make_output_file(D:/CGAL-5.0.3/demo/resources/CGAL.qrc  qrc.depends out_depends )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(43):  string(LENGTH D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5 _binlength )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(44):  string(LENGTH D:/CGAL-5.0.3/demo/resources/CGAL.qrc _infileLength )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(45):  set(_checkinfile D:/CGAL-5.0.3/src/CGAL_Qt5 )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(46):  if(_infileLength GREATER _binlength )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(53):  else()
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(54):  file(RELATIVE_PATH rel D:/CGAL-5.0.3/src/CGAL_Qt5 D:/CGAL-5.0.3/demo/resources/CGAL.qrc )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(56):  if(WIN32 AND rel MATCHES ^([a-zA-Z]):(.*)$ )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(59):  set(_outfile D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/../../demo/resources/CGAL.qrc )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(60):  string(REPLACE .. __ _outfile D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/../../demo/resources/CGAL.qrc )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(61):  get_filename_component(outpath D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/__/__/demo/resources/CGAL.qrc PATH )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(62):  string(REGEX REPLACE \.[^.]*$  _outfile D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/__/__/demo/resources/CGAL.qrc )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(63):  file(MAKE_DIRECTORY D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/__/__/demo/resources )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(64):  set(out_depends D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/__/__/demo/resources/D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/__/__/demo/resources/CGAL.qrc.depends )
D:/Qt/5.12.7/msvc2017_64/lib/cmake/Qt5Core/Qt5CoreMacros.cmake(211):  configure_file(D:/CGAL-5.0.3/demo/resources/CGAL.qrc D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/__/__/demo/resources/D:/CGAL-5.0.3/build/debug/src/CGAL_Qt5/__/__/demo/resources/CGAL.qrc.depends COPYONLY )
