- To:
- Subject: [cgal-discuss] Fwd: Isotropic remeshing failed with is_valid_polygon_mesh()
- Date: Sun, 6 Sep 2020 00:57:16 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:dpUoQRykHLmorwnXCy+O+j09IxM/srCxBDY+r6Qd2usVIJqq85mqBkHD//Il1AaPAdyFrase16GG6ujJYi8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tL1LdrWev4jEMBx7xKRR6JvjvGo7Vks+7y/2+94fcbglVhTexe65+IAu5oAnetcQanJZpJ7osxBfOvnZGYfldy3lyJVKUkRb858Ow84Bm/i9Npf8v9NNOXLvjcaggQrNWEDopM2Yu5M32rhbDVheA5mEdUmoNjBVFBRXO4QzgUZfwtiv6sfd92DWfMMbrQ704RSiu4qF2QxDvlSkHKiU58HnJhcNskKJVrhWhpxllzI7VZoGeKf5yc6zZcN8fQ2dKQ8RfWDFbAo6kYIQPAegOM+ZWoYf+ulUAswexCBKpBO/z0DJFnGP60bE43uknDArI3BYgH9ULsHnMrtr6LqASUOCozKLVzzvDcu5d1DD96IjVchEuu/aMXLJtccbMzUQiFALIg06fqYzgJTyV1+ANv3KH4OpnUOKikmgqoBx+rTaz3MkjkJXJhp4LxVDe8yV02Ik4KN62RkNmYNOoDJpduz2VOYZrX84sTG9mtDgmxrAHtpO3YCcExZopyRPCdvGKc4qF7g/iWeiRIjp1hX1rdK65ih2v/0agzej8WdO10FZMtidKjtbMuWoJ1xDJ7ciHUPR98l+91jaAzQ/T7vtILVozlarBJJ4t2rEwlp0UsUTMGi/5hl/6g7ORdkUh/OWj9ufpYq3+q5OCK4N5jhvyP6cul8ClHOg0LAsDU3KU9Om90rDo4Ff3T69QjvIsl6nUqJDaKtofpq6+GwJV15ws6xe7Dzu/3tUYmGQLIEtLeB+IjoXlIV7OIPf/Dfewh1Sjji1nyOzBPr3kGpnNL37Dn6n9fbtl9UJQ1A4+wcpc6p9UEL0NPez/V0zruNHXDxI1Kwm0zPzmCNV52IMeQ2WPAqqBPaPSrF+J5vggI+6MZY8IpTrwL/so6v/1gH82nF8SZ6ip3Z8NZH+kGfRmJl2VYWDwjdcZDWcKog0+QfT2h12NSzFTY2++UL895jEgFI2mEJzDRpu2jbya3Ca7G4VWaXpcBlCNF3fobYSEVO0WZCKcOM8y2gADALOuQotk2RC1vxLh0JJmKPDV82sWr8HNzt9wstzakgAvvRxpR5CdznCESHBpxzJYGRc52al+pQp2zVLVgvswuOBRCdEGv6ABaQw9L5OJk70jVoLCHznZd9LMc26IB9WrBTZrE4A0yt4KJll4QpCs0k6F0C2tDLsY0beMAc5sq/6O7z3KP894jk3++uw5lVB/G5lAMGSnguh08A2BX9eYwXXcrL6jcOEn5ACI8W6CyWSUu0QBCVx/VKzEWTYUYU6E9Nk=
Sorry for the duplicated messages.
I did not specify my CGAL version in the last email. `git status` tells me that I am using CGAL 5.0.2.
Thanks!
---------- Forwarded message ---------
Date: Sun, Sep 6, 2020 at 12:47 AM
Subject: Isotropic remeshing failed with is_valid_polygon_mesh()
To: <>
To: <>
Hi,
I was trying to use CGAL::Polygon_mesh_processing::isotropic_remeshing() to remesh a CGAL::Surface_mesh. However, I got the following error message:
========== Error message begins. ==========
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: is_valid_polygon_mesh(mesh_)
File: /home/yaoyu/Libraries/cgal/Polygon_mesh_processing/include/CGAL/Polygon_mesh_processing/internal/Isotropic_remeshing/remesh_impl.h
Line: 1037
Line: 1037
========== Error message ends. ==========
I was trying the code listed at https://doc.cgal.org/latest/Polygon_mesh_processing/Polygon_mesh_processing_2isotropic_remeshing_example_8cpp-example.html and I enclosed the source file. I am not sure about the reason why CGAL thinks the Surface_mesh is not a valid polygon mesh.
The input mesh is in PLY format and you could find the file at https://drive.google.com/file/d/1Z9AMfRnbkJGmDuUOc7ZAdMAvbhhhx_Vn/view?usp=sharing
One thing that might be interesting is that if I use the CGAL Polyhedron Demo program to load and do the isotropic remeshing, no errors are encountered.
Any comments are appreciated.
Thank you!
Yaoyu
// // Created by yaoyu on 9/6/20. // #include <fstream> #include <iostream> #include <string> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h> #include <CGAL/Polygon_mesh_processing/remesh.h> #include <CGAL/Surface_mesh.h> // Namespace. namespace PMP = CGAL::Polygon_mesh_processing; // CGAL typedefs. typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel_t; typedef Kernel_t::Point_3 Point3_t; typedef CGAL::Surface_mesh<Point3_t> SurfaceMesh_t; typedef boost::graph_traits< SurfaceMesh_t >::face_descriptor DescFace_t; typedef boost::graph_traits< SurfaceMesh_t >::edge_descriptor DescEdge_t; typedef boost::graph_traits< SurfaceMesh_t >::halfedge_descriptor DescHalfedge_t; typedef boost::graph_traits< SurfaceMesh_t >::vertex_descriptor DescVert_t; template < typename PT > void read_mesh_ply(const std::string &fn, CGAL::Surface_mesh<PT> &sm ) { std::ifstream ifs { fn }; if ( !ifs ) { std::stringstream ss; ss << "Cannot open " << fn << " for reading. "; throw std::runtime_error( ss.str() ); } if ( !CGAL::read_ply( ifs, sm ) ) { std::stringstream ss; ss << "read_ply() from " << fn << " failed. "; throw std::runtime_error( ss.str() ); } ifs.close(); } struct halfedge2edge { halfedge2edge(const SurfaceMesh_t &m, std::vector<DescEdge_t> &edges) : m_mesh(m), m_edges(edges) {} void operator()(const DescHalfedge_t &h) const { m_edges.push_back(edge(h, m_mesh)); } const SurfaceMesh_t& m_mesh; std::vector<DescEdge_t>& m_edges; }; static void isotropic_remesh( SurfaceMesh_t &mesh, double targetLength, int iters ) { // Border. std::cout << "Split border...\n"; std::vector<DescEdge_t> border; PMP::border_halfedges(faces(mesh), mesh, boost::make_function_output_iterator(halfedge2edge(mesh, border))); PMP::split_long_edges(border, targetLength, mesh); // Perform smooth. std::cout << "Start remeshing... \n"; PMP::isotropic_remeshing( faces( mesh ), targetLength, mesh, PMP::parameters::number_of_iterations(iters) .protect_constraints(true) ); } int main( int argc, char **argv ) { std::cout << "Hello, RemeshingTest! \n"; // Load the mesh from the PLY file. SurfaceMesh_t mesh; read_mesh_ply( argv[1], mesh); // Remesh. isotropic_remesh( mesh, 0.02, 1 ); return 0; }
- [cgal-discuss] Isotropic remeshing failed with is_valid_polygon_mesh(), Yaoyu Hu, 09/06/2020
- [cgal-discuss] Fwd: Isotropic remeshing failed with is_valid_polygon_mesh(), Yaoyu Hu, 09/06/2020
- Re: [cgal-discuss] Isotropic remeshing failed with is_valid_polygon_mesh(), Sebastien Loriot (GeometryFactory), 09/07/2020
- Re: [cgal-discuss] Isotropic remeshing failed with is_valid_polygon_mesh(), Yaoyu Hu, 09/07/2020
- Re: [cgal-discuss] Isotropic remeshing failed with is_valid_polygon_mesh(), Sebastien Loriot (GeometryFactory), 09/08/2020
- Re: [cgal-discuss] Isotropic remeshing failed with is_valid_polygon_mesh(), Yaoyu Hu, 09/08/2020
- Re: [cgal-discuss] Isotropic remeshing failed with is_valid_polygon_mesh(), Andreas Fabri, 09/09/2020
- Re: [cgal-discuss] Isotropic remeshing failed with is_valid_polygon_mesh(), Yaoyu Hu, 09/09/2020
