cgal-discuss - Re: [cgal-discuss] Isotropic remeshing failed with is_valid_polygon_mesh()
  • To:
  • Subject: Re: [cgal-discuss] Isotropic remeshing failed with is_valid_polygon_mesh()
  • Date: Wed, 9 Sep 2020 09:46:53 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23: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
Hello Yaoyu Hu,
Can you give us the points you used for Advancing Front Surface Reconstruction
as well as the parameters of your call, preferably onĀ  gist.github.com
Best,
Andreas
On 9/8/2020 8:16 PM, Yaoyu Hu ( via cgal-discuss Mailing List) wrote:
If you have such an error for a mesh that is the output of the CGAL
advancing front algorithm, then this is a bug. If this is the case,
could you please try to come up with an example and a point cloud
showing the issue so that we can reproduce it and fix it?
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912    skype: andreas.fabri
