- To:
- Subject: Re: [cgal-discuss] Isotropic remeshing failed with is_valid_polygon_mesh()
- Date: Wed, 9 Sep 2020 12:25:35 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hi Andreas,
I created a public gist. The link is here
There are the sample code, point cloud, and a short ReadMe describing the gist.
Best,
Yaoyu
On Wed, Sep 9, 2020 at 3:47 AM Andreas Fabri <> wrote:
Hello Yaoyu Hu,
Can you give us the points you used for Advancing Front Surface Reconstruction
as well as the parameters of your call, preferably on gist.github.comBest,
Andreas
On 9/8/2020 8:16 PM, Yaoyu Hu ( via cgal-discuss Mailing List) wrote:
If you have such an error for a mesh that is the output of the CGAL
advancing front algorithm, then this is a bug. If this is the case,
could you please try to come up with an example and a point cloud
showing the issue so that we can reproduce it and fix it?-- Andreas Fabri, PhD Chief Officer, GeometryFactory Editor, The CGAL Project phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Isotropic remeshing failed with is_valid_polygon_mesh(), Yaoyu Hu, 09/06/2020
- [cgal-discuss] Fwd: Isotropic remeshing failed with is_valid_polygon_mesh(), Yaoyu Hu, 09/06/2020
- Re: [cgal-discuss] Isotropic remeshing failed with is_valid_polygon_mesh(), Sebastien Loriot (GeometryFactory), 09/07/2020
- Re: [cgal-discuss] Isotropic remeshing failed with is_valid_polygon_mesh(), Yaoyu Hu, 09/07/2020
- Re: [cgal-discuss] Isotropic remeshing failed with is_valid_polygon_mesh(), Sebastien Loriot (GeometryFactory), 09/08/2020
- Re: [cgal-discuss] Isotropic remeshing failed with is_valid_polygon_mesh(), Yaoyu Hu, 09/08/2020
- Re: [cgal-discuss] Isotropic remeshing failed with is_valid_polygon_mesh(), Andreas Fabri, 09/09/2020
- Re: [cgal-discuss] Isotropic remeshing failed with is_valid_polygon_mesh(), Yaoyu Hu, 09/09/2020
