cgal-discuss - [cgal-discuss] Multi-labeled images to multiple manifold surface meshes
  • To:
  • Subject: [cgal-discuss] Multi-labeled images to multiple manifold surface meshes
  • Date: Sun, 6 Sep 2020 17:09:45 -0500 (CDT)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Neutral ; spf=Pass
  • Ironport-phdr: 9a23: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
Hello,
I have a gray level image with multiple labels (1, 2, 3, ... ). I want to
form a surface mesh for each, such that the boundaries between labels are
aligned (e.g. what happens when running CGAL::make_mesh_3 on a domain with
multiple labels).
A similar post said to run CGAL::make_mesh_3 on the images and export them
to .off files:
http://cgal-discuss.949826.n4.nabble.com/Isosurfaces-from-Gray-level-image-td4661158.html
However, when I try this the outputs are not manifold and have to be
remeshed and many non-manifold regions have to be manually removed.
I have run the surface mesh generation on each individual label and have
gotten all manifold outputs, but the boundaries between labels are not
aligned.
Should I extract each surface from the mesh_complex_3_in_triangulation and
run polygonal mesh repair? Or is there a way to get the surface mesh
generation to mesh multiple surfaces at once?
Thanks!
