- To:
- Subject: Re: [cgal-discuss] Multi-labeled images to multiple manifold surface meshes
- Date: Mon, 7 Sep 2020 11:56:50 -0500 (CDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Neutral ; spf=Pass
- Ironport-phdr: 9a23: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
Ah, no I wasn't. Thanks!
The description on the manifold tag indicates that make_mesh_3 can only
terminate if the input surface is manifold - how does this correspond to
voxel image inputs? As mentioned, I've been able to surface mesh each image
label independently with manifold output, but passing the manifold() option
into make_mesh_3 seems to not terminate (it takes ~8 minutes to generate a
volumetric mesh without the manifold() option, but has taken 2 hours so far
with the manifold() option).
- [cgal-discuss] Multi-labeled images to multiple manifold surface meshes, Sapphri, 09/07/2020
- Re: [cgal-discuss] Multi-labeled images to multiple manifold surface meshes, Sebastien Loriot (GeometryFactory), 09/07/2020
- Re: [cgal-discuss] Multi-labeled images to multiple manifold surface meshes, Sapphri, 09/07/2020
- Re: [cgal-discuss] Multi-labeled images to multiple manifold surface meshes, Sebastien Loriot (GeometryFactory), 09/08/2020
- Re: [cgal-discuss] Multi-labeled images to multiple manifold surface meshes, Sapphri, 09/09/2020
