cgal-discuss - Re: [cgal-discuss] Multi-labeled images to multiple manifold surface meshes
  • To:
  • Subject: Re: [cgal-discuss] Multi-labeled images to multiple manifold surface meshes
  • Date: Mon, 7 Sep 2020 06:55:22 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Did you pass the manifold() option?
https://doc.cgal.org/latest/Mesh_3/group__PkgMesh3Parameters.html#ga67c9c42cfafc22044cc74c704c29aa76
Best,
Sebastien.
On 9/7/20 12:09 AM, Sapphri ( via cgal-discuss Mailing List) wrote:
Hello,
I have a gray level image with multiple labels (1, 2, 3, ... ). I want to
form a surface mesh for each, such that the boundaries between labels are
aligned (e.g. what happens when running CGAL::make_mesh_3 on a domain with
multiple labels).
A similar post said to run CGAL::make_mesh_3 on the images and export them
to .off files:
http://cgal-discuss.949826.n4.nabble.com/Isosurfaces-from-Gray-level-image-td4661158.html
However, when I try this the outputs are not manifold and have to be
remeshed and many non-manifold regions have to be manually removed.
I have run the surface mesh generation on each individual label and have
gotten all manifold outputs, but the boundaries between labels are not
aligned.
Should I extract each surface from the mesh_complex_3_in_triangulation and
run polygonal mesh repair? Or is there a way to get the surface mesh
generation to mesh multiple surfaces at once?
Thanks!
