cgal-discuss - Re: [cgal-discuss] OpenGL problem in CGAL
  • To:
  • Subject: Re: [cgal-discuss] OpenGL problem in CGAL
  • Date: Thu, 7 Jan 2021 09:00:07 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
I opened an issue and I've been working on a fix since yesterday: https://github.com/CGAL/cgal/issues/5334
Le jeu. 7 janv. 2021 à 08:47, Sebastien Loriot <> a écrit :
What version of CGAL are you using?
Sebastien
On 1/5/21 8:47 PM, David Rochera wrote:
>> Hello, I'm new in CGAL and in this mailing list,
>> I have been trying for many days to solve an OpenGL problem I have
>> when running some CGAL examples and demos but I could not solve it
>> yet. If some of you know the answer to this question I would be very
>> grateful. :)
>> I'm using a fairly new Mac OS, where I have installed the last
>> versions of CGAL, Qt5 and many other optional libraries. The OpenGL
>> support was discontinued for Apple some years ago, so that my GL Core
>> version is up to 4.1. The problem is that after compiling and running
>> some CGAL examples and demos I get the warning:
>> GL 4.3 context initialization failed.
>> Using context  2 . 1 GL
>> This results in not being able to see vertices nor edges in the
>> Basic_viewer. I'm wondering how the 4.1 context could be set in order
>> to avoid such an issue. Looking at the CGAL Qt files, I can guess
>> that the 4.3 context is tried to be set and, if not found, the ES 2.0
>> context is displayed instead. Nevertheless, I guess there should be a
>> way to display the highest possible Mac OS context 4.1 because the
>> Polyhedron demo, for instance, works fine for me. If I run it, I can
>> see vertices and edges and indeed I get:
>> Using context  4 . 1 GL
>> If the problem is regarding the OS, there should be many affected
>> CGAL users but I haven't found many people speaking about it in any
>> forum... so I don't know if I'm missing something.
>> Thank you very much and best wishes,
>> David
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
