cgal-discuss - Re: [cgal-discuss] OpenGL problem in CGAL
  • To:
  • Subject: Re: [cgal-discuss] OpenGL problem in CGAL
  • Date: Thu, 14 Jan 2021 12:21:10 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Yes, thank you very much for your work! I have been testing this morning all the modified examples and demos to be sure everything works fine. In general, they seem to work correctly, however I have some comments for the demos:
1. Regarding the AABB_tree demo, it works fine but the points are displayed very very small (just a pixel), so that they can hardly be seen (and I don't know a way to increase their size inside the demo; in other demos, the default point size is bigger and they can be clearly seen at first).
2. Although I believe that they work correctly, the demos "periodic_3_triangulation_3_demo", "Periodic_Lloyd_3", "T3_demo" and "PCA_demo" still show the messages
GL 4.3 context initialization failed.
Using context  2 . 1 GL
and
QOpenGLVertexArrayObject::destroy() failed to restore current context
when closing the window.
3. The demos "Alpha_shape_3" and "Circular_kernel_3"  (display correctly the 4.1 context but) when closing the window still show the message:
4. The worst thing happens when initializing the "Linear_cell_complex_3_demo". It shows the message
zsh: segmentation fault  ./Linear_cell_complex_3_demo
and it does not work (I don't know if this has to do with the new PR since I have never run this demo before). See attached the problem report.
Best wishes and thank you very much again! :)
David
On Thu, 14 Jan 2021 at 09:51, Maxime Gimeno <> wrote:
Ok, I think I just fixed it.
Le mer. 13 janv. 2021 à 16:33, David Rochera <> a écrit :
Hi Maxime,
I tested one of the examples and now it works perfectly. Unfortunately, I tried the AABB_tree demo and it does not work yet, I get:
Using context  4 . 1 GL
QOpenGLShader::compile(Fragment): ERROR: 0:6: Invalid call of undeclared identifier 'texture2D'
*** Problematic Fragment shader source code ***
#version 150
#ifdef GL_KHR_blend_equation_advanced
#extension GL_ARB_fragment_coord_conventions : enable
#extension GL_KHR_blend_equation_advanced : enable
#endif
#define lowp
#define mediump
#define highp
#line 1
uniform sampler2D texture;
in highp vec2 texc;
out highp vec4 out_color;
void main(void) {
out_color = texture2D(texture, texc.st);
Compiling fragmentsource FAILED
QOpenGLShader::link: ERROR: One or more attached shaders not successfully compiled
linking Program FAILED
QOpenGLShaderProgram::attributeLocation(vertex): shader program is not linked
QOpenGLShaderProgram::attributeLocation(tex_coord): shader program is not linked
Similar warnings when using it and when closing the window:
Write setting... done.
Best wishes,
David
On Wed, 13 Jan 2021 at 15:25, Maxime Gimeno <> wrote:
Hi,
I updated my PR with a generalization of my fix to all demos, I hope it works now.
Maxime
Le jeu. 7 janv. 2021 à 16:28, David Rochera <> a écrit :
Thank you very much, Maxime! I've tested it and now the points and edges are perfectly displayed in the examples!
I don't know if it's important, but just let you know that when the Basic Viewer window is closed, the following line is still shown:
In addition, there may be some demos in which the 4.1 context still does not work... In particular, I tried the AABB_tree demo.
Best wishes,
David
On Thu, 7 Jan 2021 at 13:16, Maxime Gimeno <> wrote:
I made a PR to fix your specific issue : https://github.com/CGAL/cgal/pull/5336
If you don't want to wait for the next release, you can clone the branch and use it, it is based on CGAL-5.1
Le jeu. 7 janv. 2021 à 10:56, David Rochera <> a écrit :
Sorry, Sebastien, it was for CGAL version 5.1.1.
I downgraded because for the latest version, 5.2, I got an error message like the following when trying to compile the Polyhedron demo:
[  3%] Building CXX object CMakeFiles/demo_framework.dir/Viewer.cpp.o
/Users/drochera/Downloads/CGAL-David/Polyhedron/Viewer.cpp:1133:31: error:
      too few arguments to function call, expected 2, have 1
    d->textRenderer->draw(this);
/usr/local/include/CGAL/Three/TextRenderer.h:142:5: note: 'draw' declared here
    void draw(CGAL::Three::Viewer_interface* viewer, const QVector3D &scaler);
1 error generated.
make[2]: *** [CMakeFiles/demo_framework.dir/Viewer.cpp.o] Error 1
make[1]: *** [CMakeFiles/demo_framework.dir/all] Error 2
make: *** [all] Error 2
But this might be another different bug... (for the CGAL version 5.1.1 this error does not appear).
Best wishes.
On Thu, 7 Jan 2021 at 09:00, Maxime Gimeno <> wrote:
I opened an issue and I've been working on a fix since yesterday: https://github.com/CGAL/cgal/issues/5334
Le jeu. 7 janv. 2021 à 08:47, Sebastien Loriot <> a écrit :
What version of CGAL are you using?
Sebastien
On 1/5/21 8:47 PM, David Rochera wrote:
>> Hello, I'm new in CGAL and in this mailing list,
>> I have been trying for many days to solve an OpenGL problem I have
>> when running some CGAL examples and demos but I could not solve it
>> yet. If some of you know the answer to this question I would be very
>> grateful. :)
>> I'm using a fairly new Mac OS, where I have installed the last
>> versions of CGAL, Qt5 and many other optional libraries. The OpenGL
>> support was discontinued for Apple some years ago, so that my GL Core
>> version is up to 4.1. The problem is that after compiling and running
>> some CGAL examples and demos I get the warning:
>> This results in not being able to see vertices nor edges in the
>> Basic_viewer. I'm wondering how the 4.1 context could be set in order
>> to avoid such an issue. Looking at the CGAL Qt files, I can guess
>> that the 4.3 context is tried to be set and, if not found, the ES 2.0
>> context is displayed instead. Nevertheless, I guess there should be a
>> way to display the highest possible Mac OS context 4.1 because the
>> Polyhedron demo, for instance, works fine for me. If I run it, I can
>> see vertices and edges and indeed I get:
>> If the problem is regarding the OS, there should be many affected
>> CGAL users but I haven't found many people speaking about it in any
>> forum... so I don't know if I'm missing something.
>> Thank you very much and best wishes,
>> David
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
Process: Linear_cell_complex_3_demo [88082]
Path: /Users/USER/Downloads/*/Linear_cell_complex_3_demo
Identifier: Linear_cell_complex_3_demo
Version: 0
Code Type: X86-64 (Native)
Parent Process: zsh [87541]
Responsible: Terminal [49935]
User ID: 502
Date/Time: 2021-01-14 10:54:32.702 +0100
OS Version: Mac OS X 10.15.7 (19H114)
Report Version: 12
Bridge OS Version: 5.1 (18P3030)
Anonymous UUID: 092C83D6-B61B-259A-4C0A-E67FBE0A8690
Sleep/Wake UUID: 43C9028E-E317-4E8E-85C0-CD57E3308041
Time Awake Since Boot: 220000 seconds
Time Since Wake: 5900 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000270
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [88082]
VM Regions Near 0x270:
__TEXT 00000001093ca000-00000001094fa000 [ 1216K] r-x/r-x
SM=COW /Users/USER/Downloads/*
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 Linear_cell_complex_3_demo 0x00000001093e6ca6
CGAL::Combinatorial_map_base<3u,
CGAL::Linear_cell_complex_for_combinatorial_map<3u, 3u,
CGAL::Linear_cell_complex_traits<3u, CGAL::Epick>, Myitems,
std::__1::allocator<int>, CGAL::Combinatorial_map_base,
CGAL::CMap_linear_cell_complex_storage_1<3u, 3u,
std::__1::allocator<int> > >, Myitems, std::__1::allocator<int>,
std::__1::allocator<int> > >::get_new_mark() const + 6
1 Linear_cell_complex_3_demo 0x00000001094a1a82
CGAL::SimpleLCCViewerQt<CGAL::Linear_cell_complex_for_combinatorial_map<3u,
3u, CGAL::Linear_cell_complex_traits<3u, CGAL::Epick>, Myitems,
MyDrawingFunctorLCC>::SimpleLCCViewerQt(QWidget*,
std::__1::allocator<int> > > const*, char const*, bool, MyDrawingFunctorLCC
const&) + 130
2 Linear_cell_complex_3_demo 0x00000001094a1b3e
Viewer::Viewer(QWidget*) + 30
3 Linear_cell_complex_3_demo 0x000000010942506b
Ui_MainWindow::setupUi(QMainWindow*) + 3707
4 Linear_cell_complex_3_demo 0x000000010942318d
MainWindow::MainWindow(QWidget*) + 589
5 Linear_cell_complex_3_demo 0x000000010942278d main + 349
6 libdyld.dylib 0x00007fff73a94cc9 start + 1
Thread 1:
0 libsystem_pthread.dylib 0x00007fff73c94b68 start_wqthread + 0
Thread 2:
Thread 3:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x00000001094fbc10 rbx: 0x00007fd10d017a00 rcx: 0x00000001094fb928
rdx: 0x00000000000001c1
rdi: 0x0000000000000000 rsi: 0x0000000000000000 rbp: 0x00007ffee6835410
rsp: 0x00007ffee6835400
r8: 0x0000000000000063 r9: 0x000000000000001d r10: 0x0000000000000000
r11: 0x0000000000000000
r12: 0x0000000000000000 r13: 0x00007ffee6835888 r14: 0x00007ffee6835480
r15: 0x0000000000000000
rip: 0x00000001093e6ca6 rfl: 0x0000000000010212 cr2: 0x0000000000000270
Logical CPU: 3
Error Code: 0x00000004 (no mapping for user data read)
Trap Number: 14
Binary Images:
0x1093ca000 - 0x1094f9ffb +Linear_cell_complex_3_demo (0)
<6EFD73F8-688A-363C-9CA4-E033A5A73265>
0x109597000 - 0x10959aff7 +libgmpxx.4.dylib (0)
<816AAEEA-2FBE-3C33-9B9F-B2A559E6E31A> /usr/local/opt/gmp/lib/libgmpxx.4.dylib
0x1095ab000 - 0x109604ff3 +libmpfr.6.dylib (0)
<055F5288-E073-3956-8745-8F15B985F57F> /usr/local/opt/mpfr/lib/libmpfr.6.dylib
0x109619000 - 0x109674fe7 +libgmp.10.dylib (0)
<29E83045-6043-319C-B7CD-9E8296F132D8> /usr/local/opt/gmp/lib/libgmp.10.dylib
0x109689000 - 0x1096c0ffb +org.qt-project.QtOpenGL (5.15 -
5.15.2) <65C67F16-7591-333D-95D1-2E6A2DD3E1B7>
/usr/local/opt/qt/lib/QtOpenGL.framework/Versions/5/QtOpenGL
0x1096e4000 - 0x10971bff7 +org.qt-project.QtSvg (5.15 - 5.15.2)
<AF4F44A1-FBA4-36C4-86EB-3D2B7B60F7C1>
/usr/local/opt/qt/lib/QtSvg.framework/Versions/5/QtSvg
0x10973f000 - 0x109b8affb +org.qt-project.QtWidgets (5.15 -
5.15.2) <634846CE-4423-34E5-B1B2-20E68283C70E>
/usr/local/opt/qt/lib/QtWidgets.framework/Versions/5/QtWidgets
0x109cf3000 - 0x10a1defe7 +org.qt-project.QtGui (5.15 - 5.15.2)
<F3A4DEB7-58AB-3547-BB36-0B755C5C1B39>
/usr/local/opt/qt/lib/QtGui.framework/Versions/5/QtGui
0x10a2fd000 - 0x10a334fff +org.qt-project.QtXml (5.15 - 5.15.2)
<D6942A62-4EC6-3FC8-816A-7E39FD75EB92>
/usr/local/opt/qt/lib/QtXml.framework/Versions/5/QtXml
0x10a34a000 - 0x10a88da47 +org.qt-project.QtCore (5.15 -
5.15.2) <11856788-6B54-303A-A7F9-36719F3ED2CF>
/usr/local/opt/qt/lib/QtCore.framework/Versions/5/QtCore
0x10cdcc000 - 0x10cf33ff7 +libqcocoa.dylib (0)
<6D2508E8-E34F-3D4B-ADD8-E76E5DA97E10>
/usr/local/Cellar/qt/5.15.2/plugins/platforms/libqcocoa.dylib
0x10cf84000 - 0x10cfe3ff3 +org.qt-project.QtDBus (5.15 -
5.15.2) <A7B81F8E-DA62-3A1F-930B-0A2F24FB26E6>
/usr/local/Cellar/qt/5.15.2/lib/QtDBus.framework/Versions/5/QtDBus
0x10cfff000 - 0x10d02affb +org.qt-project.QtPrintSupport (5.15
- 5.15.2) <9DDDA106-916A-30E1-955E-B4CD4D89755E>
/usr/local/Cellar/qt/5.15.2/lib/QtPrintSupport.framework/Versions/5/QtPrintSupport
0x10e12c000 - 0x10e153fff +libqmacstyle.dylib (0)
<D639C78B-9006-339D-9561-2B3DDD39D143>
/usr/local/Cellar/qt/5.15.2/plugins/styles/libqmacstyle.dylib
0x113a9b000 - 0x113aa2ffb +libqgif.dylib (0)
<E695010B-6F50-3395-8F0A-1B581049CD52>
/usr/local/Cellar/qt/5.15.2/plugins/imageformats/libqgif.dylib
0x113aa9000 - 0x113ab0fff +libqicns.dylib (0)
<2C350985-BE43-31FD-9417-5636847794E8>
/usr/local/Cellar/qt/5.15.2/plugins/imageformats/libqicns.dylib
0x113ab8000 - 0x113abfff3 +libqico.dylib (0)
<74585029-A774-340E-8493-EBE6A2A7055C>
/usr/local/Cellar/qt/5.15.2/plugins/imageformats/libqico.dylib
0x113ac7000 - 0x113b2affb +libqjpeg.dylib (0)
<BCF68EDB-4A0F-3F17-BF44-07E560E3A488>
/usr/local/Cellar/qt/5.15.2/plugins/imageformats/libqjpeg.dylib
0x113b33000 - 0x113b3aff3 +libqmacheif.dylib (0)
<CA183F27-2A14-3795-9DCF-621FA3BC1B9E>
/usr/local/Cellar/qt/5.15.2/plugins/imageformats/libqmacheif.dylib
0x113b42000 - 0x113b49ff3 +libqmacjp2.dylib (0)
<B8C52C67-1AC5-3853-88A7-9A5A27E60347>
/usr/local/Cellar/qt/5.15.2/plugins/imageformats/libqmacjp2.dylib
0x113b51000 - 0x113b58ff7 +libqpdf.dylib (0)
<E2974024-0E4A-3AE9-9CF2-A277ABB0BE2B>
/usr/local/Cellar/qt/5.15.2/plugins/imageformats/libqpdf.dylib
0x113b5f000 - 0x11417aff3 +org.qt-project.QtPdf (5.15 - 5.15.2)
<D014D911-7FC2-3891-82E7-DEBD2390BB6B>
/usr/local/Cellar/qt/5.15.2/lib/QtPdf.framework/Versions/5/QtPdf
0x1141ae000 - 0x1142c1fff +org.qt-project.QtNetwork (5.15 -
5.15.2) <A989D856-8982-36AF-8480-12B1736196E1>
/usr/local/Cellar/qt/5.15.2/lib/QtNetwork.framework/Versions/5/QtNetwork
0x11430e000 - 0x114315ffb +libqsvg.dylib (0)
<B7E35C5A-48C9-35A5-B9A6-4CABBC04D38F>
/usr/local/Cellar/qt/5.15.2/plugins/imageformats/libqsvg.dylib
0x11431d000 - 0x114324ffb +libqtga.dylib (0)
<BD6E6BE1-D0B3-38E7-B3C9-5DCC07028278>
/usr/local/Cellar/qt/5.15.2/plugins/imageformats/libqtga.dylib
0x11432b000 - 0x114392ff3 +libqtiff.dylib (0)
<8E48E61A-03D2-38CC-850D-B592BADB2738>
/usr/local/Cellar/qt/5.15.2/plugins/imageformats/libqtiff.dylib
0x11439b000 - 0x1143a2ff7 +libqwbmp.dylib (0)
<86D287C7-1B34-39C6-A5FC-54694A31FD97>
/usr/local/Cellar/qt/5.15.2/plugins/imageformats/libqwbmp.dylib
0x1143a9000 - 0x114444ff3 +libqwebp.dylib (0)
<467B028E-05E2-3299-A4D8-D93142425046>
/usr/local/Cellar/qt/5.15.2/plugins/imageformats/libqwebp.dylib
0x11457d000 - 0x11460ef47 dyld (750.6)
<F58DDECD-315C-3B7C-8162-A5E8E1D62FE3> /usr/lib/dyld
0x7fff2ca9a000 - 0x7fff2cce7ff8 com.apple.RawCamera.bundle (9.02.0 -
1350.29) <59F81722-039E-33F5-A20E-936E997575A3>
/System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff35242000 - 0x7fff35246ffb com.apple.agl (3.3.3 - AGL-3.3.3)
<204E20A9-AEA9-3F9F-AE23-EECE3AFFFC54>
/System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x7fff3562f000 - 0x7fff3562ffff com.apple.Accelerate (1.11 -
Accelerate 1.11) <4F9977AE-DBDB-3A16-A536-AC1F9938DCDD>
/System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff35630000 - 0x7fff35646fef libCGInterfaces.dylib (524.2.1)
<8FD09D09-BB19-36C5-ADE9-4F22DA235AEE>
/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff35647000 - 0x7fff35c9dfff com.apple.vImage (8.1 - 524.2.1)
<EA6F5FF2-7A1B-35D5-A5A3-D2B3386ECB75>
/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff35c9e000 - 0x7fff35f05ff7 libBLAS.dylib (1303.60.1)
<C6C2D42F-7456-3DBF-8BE2-9AA06EFC78FD>
/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff35f06000 - 0x7fff363d9fef libBNNS.dylib (144.100.2)
<99C61C48-B14C-3DA6-8C31-6BF72DA0A3A9>
/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff363da000 - 0x7fff36775fff libLAPACK.dylib (1303.60.1)
<5E3E3867-50C3-3E6A-9A2E-007CE77A4641>
/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff36776000 - 0x7fff3678bfec libLinearAlgebra.dylib (1303.60.1)
<3D433800-0099-33E0-8C81-15F83247B2C9>
/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff3678c000 - 0x7fff36791ff3 libQuadrature.dylib (7)
<371F36A7-B12F-363E-8955-F24F7C2048F6>
/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff36792000 - 0x7fff36802fff libSparse.dylib (103)
<B8A10D0C-4577-343D-B310-A3E81265D107>
/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff36803000 - 0x7fff36815fef libSparseBLAS.dylib (1303.60.1)
<B147FEF6-A0DB-3830-BF06-45BEC58DB576>
/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff36816000 - 0x7fff369edfd7 libvDSP.dylib (735.140.1)
<D63DC0A5-B8B4-3562-A574-E73BC3B57407>
/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff369ee000 - 0x7fff36ab0fef libvMisc.dylib (735.140.1)
<3601FDE3-B142-398D-987D-8151A51F0A96>
/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff36ab1000 - 0x7fff36ab1fff com.apple.Accelerate.vecLib (3.11 -
vecLib 3.11) <F6C5613D-2284-342B-9160-9731F78B4DE5>
/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff36ab2000 - 0x7fff36b11ff0 com.apple.Accounts (113 - 113)
<E2438070-30AB-3B89-AE63-1E485B92D108>
/System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff36c5b000 - 0x7fff37a1bff2 com.apple.AppKit (6.9 - 1894.60.100)
<322D043D-1140-3486-9523-3F56FF4D8349>
/System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff37a6b000 - 0x7fff37a6bfff com.apple.ApplicationServices (48 -
50) <20CF59CD-A395-3570-A4DB-589D55C70B3F>
/System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff37a6c000 - 0x7fff37ad7fff com.apple.ApplicationServices.ATS
(377 - 493.0.4.1) <87EA5DE1-506A-39FD-88BE-D8A3416C9012>
/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff37b70000 - 0x7fff37baeff0 libFontRegistry.dylib (274.0.5.1)
<F3461C05-0370-359B-9F03-5C1C1F7763EC>
/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff37c09000 - 0x7fff37c38fff com.apple.ATSUI (1.0 - 1)
<5F513967-DDD7-3F22-AD14-8A38ABD9F2D0>
/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
0x7fff37c39000 - 0x7fff37c3dffb com.apple.ColorSyncLegacy (4.13.0 -
1) <72EE68DB-F069-37F5-AA2A-40D5FCF139F4>
/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff37cd7000 - 0x7fff37d2effa com.apple.HIServices (1.22 - 676)
<14DF4D42-E24D-3EBD-9A9D-93124D8D6AA1>
/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff37d2f000 - 0x7fff37d3dfff com.apple.LangAnalysis (1.7.0 -
1.7.0) <01B8B6B3-E2C3-3607-B34A-8283A7E0E924>
/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff37d3e000 - 0x7fff37d83ffa com.apple.print.framework.PrintCore
(15.4 - 516.2) <437BCF12-48D2-3770-8BC9-567718FB1BCA>
/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff37d84000 - 0x7fff37d8eff7 com.apple.QD (4.0 - 413)
<27A36D07-B5E9-32E6-87B6-3127F260F48D>
/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff37d8f000 - 0x7fff37d9cffc com.apple.speech.synthesis.framework
(9.0.24 - 9.0.24) <75344F8F-32CA-3558-B4E6-F56D498250E4>
/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff37d9d000 - 0x7fff37e7effa com.apple.audio.toolbox.AudioToolbox
(1.14 - 1.14) <6185BF20-D2E7-3812-8FD8-EC5237672104>
/System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff37e80000 - 0x7fff37e80fff com.apple.audio.units.AudioUnit
(1.14 - 1.14) <918ED3EB-0232-31F3-9BF5-18D1CB11523F>
/System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff38217000 - 0x7fff385a6ffa com.apple.CFNetwork (1128.0.1 -
1128.0.1) <07F9CA9C-B954-3EA0-A710-3122BFF9F057>
/System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff38622000 - 0x7fff38622fff com.apple.Carbon (160 - 162)
<6A5EB506-7A43-3879-A358-E6B9182C3733>
/System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff38623000 - 0x7fff38626ff3 com.apple.CommonPanels (1.2.6 - 101)
<9F6E13D9-374B-386F-8E15-FDD6CE967859>
/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff38627000 - 0x7fff3891bff3 com.apple.HIToolbox (2.1.1 - 994.6)
<EAF2DAC3-66B1-30BF-AF10-72DDA90D1044>
/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff3891c000 - 0x7fff3891fff3 com.apple.help (1.3.8 - 71)
<36483951-6F3E-3F7E-8A5B-191C2357EF17>
/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff38920000 - 0x7fff38925ff7 com.apple.ImageCapture (9.0 -
1600.65) <1A1F320E-3E85-3F3D-8AE0-B238C4E92D40>
/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff38926000 - 0x7fff38926fff com.apple.ink.framework (10.15 -
227) <284507AE-EF47-3ABC-86A4-669243DB1D33>
/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff38927000 - 0x7fff38941ffa com.apple.openscripting (1.7 -
185.1) <B6E28747-5FC7-3461-8A71-864A969ED022>
/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff38962000 - 0x7fff38962fff com.apple.print.framework.Print (15
- 271) <0D9FB08F-EA87-3BE7-821B-C61BA5601050>
/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff38963000 - 0x7fff38965ff7 com.apple.securityhi (9.0 - 55008)
<390C6FAA-99BF-3924-9180-9EAE41D9C6BE>
/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff38966000 - 0x7fff3896cfff
com.apple.speech.recognition.framework (6.0.3 - 6.0.3)
<9614A01E-8303-3422-A3BA-6CE27540E09A>
/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff38b14000 - 0x7fff38c0afff com.apple.ColorSync (4.13.0 -
3394.9) <A126406C-DA38-3FFE-8B25-BB9859EFD159>
/System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff38ef5000 - 0x7fff393feffb com.apple.audio.CoreAudio (5.0 -
5.0) <47923B12-3D14-328A-9C86-27A3A2A73068>
/System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff39451000 - 0x7fff39489fff com.apple.CoreBluetooth (1.0 - 1)
<23DBB313-A082-3C08-8E1F-2D31EE4247EF>
/System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff3948a000 - 0x7fff39874fe8 com.apple.CoreData (120 - 977.3)
<49AE61CA-C91E-31FE-9BD0-1AACFFB5181E>
/System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff39875000 - 0x7fff399a7ff6 com.apple.CoreDisplay (1.0 -
186.6.15) <213D7011-8180-3CF4-9BE7-FB8F75DCDB95>
/System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff399a8000 - 0x7fff39e27feb com.apple.CoreFoundation (6.9 -
1677.201) <56B0FE5F-D493-3DF1-ABFF-ECC450268B97>
/System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff39e29000 - 0x7fff3a49eff8 com.apple.CoreGraphics (2.0 -
1355.22) <4A3CDE7B-4578-3058-966A-3D1DC095A935>
/System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff3a4ac000 - 0x7fff3a807ff0 com.apple.CoreImage (15.0.0 - 940.9)
<69361069-01AB-342E-862B-73A74271A765>
/System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff3abc8000 - 0x7fff3aca3ffc com.apple.CoreMedia (1.0 - 2625.9)
<A3FF3AFC-8C1C-36E5-9179-66D8F075EE35>
/System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff3ad90000 - 0x7fff3ad90fff com.apple.CoreServices (1069.24 -
1069.24) <2D1A6C60-DD34-368F-88FF-E39C9FE549A9>
/System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff3ad91000 - 0x7fff3ae16fff com.apple.AE (838.1 - 838.1)
<2E5FD5AE-8A7F-353F-9BD1-0241F3586181>
/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff3ae17000 - 0x7fff3b0f8ff7 com.apple.CoreServices.CarbonCore
(1217 - 1217) <BE379206-99FA-30CD-8391-2708473A633F>
/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff3b0f9000 - 0x7fff3b146ffd com.apple.DictionaryServices (1.2 -
323.6) <26B70C82-25BC-353A-858F-945B14C803A2>
/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff3b147000 - 0x7fff3b14fff7 com.apple.CoreServices.FSEvents
(1268.100.1 - 1268.100.1) <FC84DB48-A3CE-30F7-A918-B3587731ACC7>
/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff3b150000 - 0x7fff3b38aff6 com.apple.LaunchServices (1069.24 -
1069.24) <9A5359D9-9148-3B18-B868-56A9DA5FB60C>
/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff3b38b000 - 0x7fff3b423ff1 com.apple.Metadata (10.7.0 - 2076.7)
<0973F7E5-D58C-3574-A3CE-4F12CAC2D4C7>
/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff3b424000 - 0x7fff3b451fff com.apple.CoreServices.OSServices
(1069.24 - 1069.24) <0E4F48AD-402C-3E9D-9CA9-6DD9479B28F9>
/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff3b452000 - 0x7fff3b4b9fff com.apple.SearchKit (1.4.1 - 1.4.1)
<2C5E1D85-E8B1-3DC5-91B9-E3EDB48E9369>
/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff3b4ba000 - 0x7fff3b4deff5
com.apple.coreservices.SharedFileList (131.4 - 131.4)
<02DE0D56-E371-3EF5-9BC1-FA435451B412>
/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff3b803000 - 0x7fff3b9baffc com.apple.CoreText (643.1.5.2 -
643.1.5.2) <ADDE38C3-C247-34AD-9903-0276050E242C>
/System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff3b9bb000 - 0x7fff3b9ffffb com.apple.CoreVideo (1.8 - 344.3)
<5314E70D-325F-3E98-99FC-00FDF520747E>
/System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff3ba00000 - 0x7fff3ba8dffc com.apple.framework.CoreWLAN (13.0 -
1601.2) <6223BFD5-D451-3DE9-90F6-F609AC0B0027>
/System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff3bd24000 - 0x7fff3bd2afff com.apple.DiskArbitration (2.7 -
2.7) <0BBBB6A6-604D-368B-9943-50B8CE75D51D>
/System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff3bf1f000 - 0x7fff3c04dff6 com.apple.FileProvider (304.1 -
304.1) <E8BB1D4B-05D6-386C-865C-F8C750CEC308>
/System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
0x7fff3c065000 - 0x7fff3c42afff com.apple.Foundation (6.9 -
1677.201) <E020DC09-4221-3961-A450-638525789B38>
/System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff3c497000 - 0x7fff3c4e7ff7 com.apple.GSS (4.0 - 2.0)
<2F3A67E6-D42A-3CF0-9041-A42C22D46F95>
/System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff3c624000 - 0x7fff3c738ff3 com.apple.Bluetooth (7.0.6 -
7.0.6f8) <C7AF719C-51B4-3727-A947-EB01204272D9>
/System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff3c79e000 - 0x7fff3c842ff3 com.apple.framework.IOKit (2.0.2 -
1726.140.1) <14223387-6F81-3976-8605-4BC2F253A93E>
/System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff3c844000 - 0x7fff3c855ffb com.apple.IOSurface (269.11 -
269.11) <BCD744D4-E17E-3C2E-B69C-F69C789892E9>
/System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff3c8d4000 - 0x7fff3ca31fee com.apple.ImageIO.framework (3.3.0 -
1976.11.4) <6FC6EE76-F76F-312C-9C67-4B9F0E0B832A>
/System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff3ca32000 - 0x7fff3ca35fff libGIF.dylib (1976.11.4)
<F57785E7-6FDA-30A1-B926-CD4D727B56DC>
/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff3ca36000 - 0x7fff3caeffe7 libJP2.dylib (1976.11.4)
<A6CC541D-37C4-3A90-86B0-2F67B917B4EE>
/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff3caf0000 - 0x7fff3cb13fe3 libJPEG.dylib (1976.11.4)
<37FA33BD-1C78-3FA6-8D35-3F3755462597>
/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff3cd90000 - 0x7fff3cdaafef libPng.dylib (1976.11.4)
<1AD4B940-5B1F-39A4-873C-9C568AA287B7>
/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff3cdab000 - 0x7fff3cdacfff libRadiance.dylib (1976.11.4)
<868D2C2C-1909-31B1-A0C2-C971F0BE1EC5>
/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff3cdad000 - 0x7fff3cdf3fff libTIFF.dylib (1976.11.4)
<1125DCD0-337D-3E01-84F9-106DEEEA5715>
/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff3e355000 - 0x7fff3e367ff3 com.apple.Kerberos (3.0 - 1)
<03BB492B-016E-37BF-B020-39C2CF7487FE>
/System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff3e368000 - 0x7fff3e368fff libHeimdalProxy.dylib (77)
<0A2905EE-9533-3345-AF9B-AAC71513BDFD>
/System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
0x7fff3e6fa000 - 0x7fff3e704ffb com.apple.MediaAccessibility (1.0 -
125.1) <98065EA1-3484-3A5A-B05C-D2FABED8CEA4>
/System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff3e7d0000 - 0x7fff3ef1dff2 com.apple.MediaToolbox (1.0 -
2625.9) <3A848992-9182-382A-BF7D-5CB9707BE27B>
/System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff3ef1f000 - 0x7fff3efe9fff com.apple.Metal (212.8 - 212.8)
<98C944D6-62C8-355E-90F8-C1CA2429EF24>
/System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff3f006000 - 0x7fff3f043ff7
com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1)
<7EBAC15D-7837-395D-B405-1E29F7DA68FA>
/System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff3f044000 - 0x7fff3f0cefe2
com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1)
<B424FE0C-6E90-3BFA-A6E7-DD86C735AE90>
/System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff3f0cf000 - 0x7fff3f0f4ff4
com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1)
<02006D92-E2AB-3892-A96B-37F6520C19BA>
/System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff3f0f5000 - 0x7fff3f10affb
com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1)
<CAA5A368-DB71-34F6-AEF9-27A8BC298F53>
/System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
0x7fff3f10b000 - 0x7fff3f269ffc
com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1)
<05612E06-50CB-318F-9F8E-EF4D49FAB3B0>
/System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff3f26a000 - 0x7fff3f2b9ff4
com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1)
<B0B591F8-6875-351E-867F-8EB3CD38CD52>
/System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff3f2ba000 - 0x7fff3f2bbff5
com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1)
<F2921F9A-3041-3495-878D-64134267B847>
/System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff40349000 - 0x7fff40355ffe com.apple.NetFS (6.0 - 4.0)
<4415F027-D36D-3B9C-96BA-AD22B44A4722>
/System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff40356000 - 0x7fff404adff3 com.apple.Network (1.0 - 1)
<4A0F3B93-4D23-3E74-9A3D-AD19E9C0E59E>
/System/Library/Frameworks/Network.framework/Versions/A/Network
0x7fff42edf000 - 0x7fff42f37fff com.apple.opencl (3.5 - 3.5)
<293FE223-9186-320B-81A4-EC8104C38357>
/System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff42f38000 - 0x7fff42f54fff com.apple.CFOpenDirectory (10.15 -
220.40.1) <7E6C88EB-3DD9-32B0-81FC-179552834FA9>
/System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff42f55000 - 0x7fff42f60ffd com.apple.OpenDirectory (10.15 -
220.40.1) <4A92D8D8-A9E5-3A9C-942F-28576F6BCDF5>
/System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff438c6000 - 0x7fff438c8fff libCVMSPluginSupport.dylib
(17.10.22) <2B6C3C16-3F5F-36A8-8070-2A862B90328B>
/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff438c9000 - 0x7fff438cefff libCoreFSCache.dylib (176.15)
<E9A20E72-B17F-33D6-8894-41934A10B822>
/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff438cf000 - 0x7fff438d3fff libCoreVMClient.dylib (176.15)
<018A48BA-1326-3847-8FB5-A7C99322EB87>
/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff438d4000 - 0x7fff438dcff7 libGFXShared.dylib (17.10.22)
<AB47B927-65E3-3924-88BE-0A5BE7906785>
/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff438dd000 - 0x7fff438e7fff libGL.dylib (17.10.22)
<FB5E6A75-398E-38EF-8CB2-59F5BFE3034C>
/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff438e8000 - 0x7fff4391cff7 libGLImage.dylib (17.10.22)
<9A3FE633-61B8-3CC7-8183-62960109401A>
/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff43ab2000 - 0x7fff43aeefff libGLU.dylib (17.10.22)
<D8B4D804-7323-30BC-871C-B7236FFC2FE3>
/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff4452a000 - 0x7fff44539ff7 com.apple.opengl (17.10.22 -
17.10.22) <D3C57A32-6BD0-3228-B1C4-0F42A6128A6C>
/System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff454f7000 - 0x7fff4577affb com.apple.QuartzCore (1.11 - 841.4)
<FE927B0E-BD49-32CC-8A55-90F553C86C15>
/System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff462fd000 - 0x7fff46646ff1 com.apple.security (7.0 -
59306.140.5) <B6F8368F-2395-379B-B768-71C53BB1B903>
/System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff46647000 - 0x7fff466cfffb com.apple.securityfoundation (6.0 -
55236.60.1) <7C69DF47-4017-3DF2-B55B-712B481654CB>
/System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff466fe000 - 0x7fff46702ff8 com.apple.xpc.ServiceManagement (1.0
- 1) <9B36FD0E-D280-35EB-ABAB-6AC5D7B2118F>
/System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff473ae000 - 0x7fff47428ff7 com.apple.SystemConfiguration (1.19
- 1.19) <84F9B3BB-F7AF-3B7C-8CD0-D3C22D19619F>
/System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff476a8000 - 0x7fff47a2bff4 com.apple.VideoToolbox (1.0 -
2625.9) <6CF18E28-A7A8-3952-8171-7E4FF4FB37FA>
/System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff4b398000 - 0x7fff4b45dfe7 com.apple.APFS (1412.141.1 -
1412.141.1) <C86A3423-E61C-335A-9D17-0B3CE5BB6467>
/System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff4c572000 - 0x7fff4c573ff1 com.apple.AggregateDictionary (1.0 -
1) <95A291F5-B69F-3C37-9483-C3B2EBF52AC1>
/System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff4cb0d000 - 0x7fff4cb2aff4 com.apple.AppContainer (4.0 -
448.100.6) <87CEE13C-8585-3EFB-92CD-0852DFF0921B>
/System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff4cb7f000 - 0x7fff4cb8dff7 com.apple.AppSandbox (4.0 -
448.100.6) <0F49AA04-3400-349A-9096-6D4D7ED61027>
/System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff4d009000 - 0x7fff4d02dffb com.apple.framework.Apple80211 (13.0
- 1610.1) <D94E03E8-4C38-3B2F-8DF4-473ACC5A7D71>
/System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff4d2eb000 - 0x7fff4d2fafd7 com.apple.AppleFSCompression
(119.100.1 - 1.0) <466ABD77-2E52-36D1-8E39-77AE2CC61611>
/System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff4d3f9000 - 0x7fff4d404ff7 com.apple.AppleIDAuthSupport (1.0 -
1) <74F6CD9C-27A7-39C7-A7EB-47E60D2517EB>
/System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff4d446000 - 0x7fff4d48eff7 com.apple.AppleJPEG (1.0 - 1)
<6DE30A07-C627-319B-A0DE-EB7A832BEB88>
/System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff4d87d000 - 0x7fff4d89ffff com.apple.applesauce (1.0 - 16.25)
<68E0364C-AEA7-3654-A030-136BF3CD92F3>
/System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff4d95e000 - 0x7fff4d961fff com.apple.AppleSystemInfo (3.1.5 -
3.1.5) <67255151-F989-39F0-BC87-0C0BDAE70730>
/System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff4d962000 - 0x7fff4d9b2ff7 com.apple.AppleVAFramework (6.1.2 -
6.1.2) <8E18983B-AF92-3853-8251-A6577A55AC15>
/System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff4d9fb000 - 0x7fff4da0aff9 com.apple.AssertionServices (1.0 -
223.140.2) <48AD21CA-B81D-380E-A04F-90C48FDA5203>
/System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff4df4d000 - 0x7fff4e348ff8
com.apple.audio.AudioResourceArbitration (1.0 - 1)
<2BD68521-C19C-3D67-B5EB-DE3E9A4DAF0A>
/System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
0x7fff4e59e000 - 0x7fff4e7defe8 com.apple.audio.AudioToolboxCore
(1.0 - 1104.95) <9DB96FE2-AE60-32AE-B706-546E25BAE53F>
/System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
0x7fff4e7e2000 - 0x7fff4e8fefff com.apple.AuthKit (1.0 - 1)
<DC1A27C5-0172-3C72-9B24-06996D0B6207>
/System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff4eabb000 - 0x7fff4eac4ff7
com.apple.coreservices.BackgroundTaskManagement (1.0 - 104)
<A6877DAD-8F47-363C-983A-DC8DDE83B7B5>
/System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff4eac5000 - 0x7fff4eb66ff5 com.apple.backup.framework (1.11.7 -
1298.7.1) <C9DC35FA-E69F-3C64-9519-494126096337>
/System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff4eb67000 - 0x7fff4ebf3ff6 com.apple.BaseBoard (466.3 - 466.3)
<10D0F3BB-E8F3-365E-8528-6AC996A9B0E7>
/System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff4ecf5000 - 0x7fff4ed31ff7 com.apple.bom (14.0 - 219.2)
<79CBE5E7-054F-377B-9566-A86A9F120CF1>
/System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff4f8b1000 - 0x7fff4f900fff com.apple.ChunkingLibrary (307 -
307) <5B09C30D-FD2B-3E98-8B64-C5EF470FC13C>
/System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff507ad000 - 0x7fff507bdffb com.apple.CommonAuth (4.0 - 2.0)
<CF67FF34-4238-3ECA-B4A4-EA04F18A0D36>
/System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff507d1000 - 0x7fff507e8fff com.apple.commonutilities (8.0 -
900) <F4C97244-E5D8-3F7D-8D94-4B6841C5A4EC>
/System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fff50eef000 - 0x7fff512c4fc8 com.apple.CoreAUC (283.0.0 -
283.0.0) <4341271C-D270-3F9F-8464-31A20D15158D>
/System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff512c5000 - 0x7fff512f2ff7 com.apple.CoreAVCHD (6.1.0 -
6100.4.1) <C3CFDC68-C7D9-3C44-9E7C-801D45575C10>
/System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff51315000 - 0x7fff51336ff4 com.apple.analyticsd (1.0 - 1)
<2162671C-D49D-3891-AB69-9EEB1FA47DD8>
/System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
0x7fff518cd000 - 0x7fff518ddff3 com.apple.CoreEmoji (1.0 - 107.1)
<7C2B3259-083B-31B8-BCDB-1BA360529936>
/System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff51f1d000 - 0x7fff51f87ff0 com.apple.CoreNLP (1.0 - 213)
<E70E2505-8078-324E-BAE1-01A2DA980E2C>
/System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff523b5000 - 0x7fff523bdff8 com.apple.CorePhoneNumbers (1.0 - 1)
<E4DAD514-0B3B-3E0B-8AEA-39B320FAAF03>
/System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff52daa000 - 0x7fff52dcdfff com.apple.CoreSVG (1.0 - 129.3)
<F38189F9-C8F9-3D62-9D5F-3F520FB81724>
/System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
0x7fff52dce000 - 0x7fff52e01fff com.apple.CoreServicesInternal
(446.7 - 446.7) <65F53A22-6B61-382C-AAC2-B2C53F8FFB44>
/System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff52e02000 - 0x7fff52e30ffd com.apple.CSStore (1069.24 -
1069.24) <C2D67667-FA0B-3DB6-AA34-6999EE4346A0>
/System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
0x7fff53355000 - 0x7fff533ebff7 com.apple.CoreSymbolication (11.4 -
64535.33.2) <0B3BF87A-7F95-3D79-B4F8-421D6FAC4A6C>
/System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff53483000 - 0x7fff535afff6 com.apple.coreui (2.1 - 609.4)
<788818B7-7EBC-316D-9464-D12E365E3791>
/System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff535b0000 - 0x7fff53769ffa com.apple.CoreUtils (6.2.4 - 624.7)
<A74A1C65-6695-3F57-B703-0DEDE13E66C1>
/System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff538a3000 - 0x7fff538b6ff1 com.apple.CrashReporterSupport
(10.13 - 15016) <ADF138F0-0274-3BA2-A1D2-48B91577FE53>
/System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff5396f000 - 0x7fff53981ff8 com.apple.framework.DFRFoundation
(1.0 - 252.50.1) <8162057E-E856-3451-9160-04AEDDECFFA4>
/System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff53982000 - 0x7fff53987fff com.apple.DSExternalDisplay (3.1 -
380) <31ECB5FD-7660-33DB-BC5B-2B2A2AA7C686>
/System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff53a11000 - 0x7fff53a8bff0 com.apple.datadetectorscore (8.0 -
659) <B1534796-1000-3520-A641-A97A4AC5D39B>
/System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff53ad7000 - 0x7fff53b14ff8 com.apple.DebugSymbols (194 - 194)
<040AE30B-CF2C-3798-A289-0929B8CAB10D>
/System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff53b15000 - 0x7fff53c9dff6 com.apple.desktopservices (1.14.6 -
1281.6.1) <C2355E6B-C5F7-3E39-B778-B117BD4652C6>
/System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff5565e000 - 0x7fff55a79ff1 com.apple.vision.FaceCore (4.3.0 -
4.3.0) <5D32F65D-2CD7-3204-975C-F4C9256E505F>
/System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff56118000 - 0x7fff5624fff4 libFontParser.dylib (277.2.6.3)
<D93AD0C8-4657-3A3B-87EB-3DF3D522C70C>
/System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
0x7fff56250000 - 0x7fff56284fff libTrueTypeScaler.dylib (277.2.6.3)
<93039A1A-4946-3166-88B6-82EDD1649C3D>
/System/Library/PrivateFrameworks/FontServices.framework/libTrueTypeScaler.dylib
0x7fff562e8000 - 0x7fff562f8ff6 libhvf.dylib (1.0 -
$[CURRENT_PROJECT_VERSION]) <C4B38245-337D-3553-9669-75E5D90071AE>
/System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
0x7fff5ae94000 - 0x7fff5ae9afff com.apple.GPUWrangler (5.2.7 -
5.2.7) <FA34760B-4E5C-3A18-A6C3-DBA68F9D1220>
/System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff5b1b9000 - 0x7fff5b1dfff1 com.apple.GenerationalStorage (2.0 -
314) <54483E50-20BB-3AF8-900F-992320C109B0>
/System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff5c30d000 - 0x7fff5c31bffb com.apple.GraphVisualizer (1.0 -
100.1) <507D5812-9CB4-3C94-938C-59ED2B370818>
/System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff5c4ba000 - 0x7fff5c578ff4 com.apple.Heimdal (4.0 - 2.0)
<B86FE9DB-71BB-3B6E-A4AE-2B0B44570A7F>
/System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff5e704000 - 0x7fff5e70cff5 com.apple.IOAccelerator (438.7.3 -
438.7.3) <06E3E70B-C0D0-39A2-96B7-12ED6A0EBEE7>
/System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff5e719000 - 0x7fff5e730fff com.apple.IOPresentment (47.10 - 37)
<32F1B3BC-4644-3982-AAB2-8EB5D5FF0161>
/System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff5eab8000 - 0x7fff5eb03ff1 com.apple.IconServices (438.3 -
438.3) <0DADB4C3-46FF-3FDB-8A86-51E2067FC7F4>
/System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff5ecc1000 - 0x7fff5ecc8ff9 com.apple.InternationalSupport (1.0
- 45.4) <8D8D4A7D-FD35-36B8-A456-7C93030EDAB3>
/System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff5ef55000 - 0x7fff5ef74ffd
com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1)
<6F655A32-F963-3A7E-B475-E460F4AC7D99>
/System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff5f0a9000 - 0x7fff5f177ffd com.apple.LanguageModeling (1.0 -
215.1) <C456087D-5B3A-390E-A665-862FA284C59C>
/System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff5f178000 - 0x7fff5f1c0fff com.apple.Lexicon-framework (1.0 -
72) <41F208B9-8255-3EC7-9673-FE0925D071D3>
/System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff5f1c7000 - 0x7fff5f1ccff3 com.apple.LinguisticData (1.0 -
353.18) <3B92F249-4602-325F-984B-D2DE61EEE4E1>
/System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff5fa65000 - 0x7fff5fa68fff com.apple.Mangrove (1.0 - 25)
<482F300F-9B70-351F-A4DF-B440EEF7368D>
/System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff5fcd1000 - 0x7fff5fd5bff8 com.apple.MediaExperience (1.0 - 1)
<0203AF27-AB5E-32FA-B529-AB7F29EEB887>
/System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
0x7fff60535000 - 0x7fff60581fff
com.apple.spotlight.metadata.utilities (1.0 - 2076.7)
<0237323B-EC78-3FBF-9FC7-5A1FE2B5CE25>
/System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff60582000 - 0x7fff60653ffa com.apple.gpusw.MetalTools (1.0 - 1)
<99876E08-37D7-3828-8796-56D90C9AFBDB>
/System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff606b1000 - 0x7fff606caff4 com.apple.MobileAssets (1.0 -
619.120.1) <07E116E6-7EBC-39F2-B5B4-31BAB6BAF852>
/System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff60887000 - 0x7fff608a5fff com.apple.MobileKeyBag (2.0 - 1.0)
<D5FA7041-297F-3ADC-8C7A-6EAAAB82EB68>
/System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff60b08000 - 0x7fff60b38ff7
com.apple.MultitouchSupport.framework (3440.1 - 3440.1)
<6794E1C8-9627-33DF-84F4-FDD02C97F383>
/System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff61038000 - 0x7fff61042fff com.apple.NetAuth (6.2 - 6.2)
<B0C03C41-87A3-352B-B130-96E1A6F94B47>
/System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff61a4e000 - 0x7fff61a99ffb com.apple.OTSVG (1.0 - 643.1.5.2)
<AD1D4601-05DE-37A7-AD7E-FCF46BF9981D>
/System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff62cb6000 - 0x7fff62cc1ff2 com.apple.PerformanceAnalysis
(1.243.2 - 243.2) <B47C00E5-ECC2-313D-93D4-DBDF562C48EF>
/System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff62cc2000 - 0x7fff62ceaffb com.apple.persistentconnection (1.0
- 1.0) <5B2D87A8-2641-3F6D-ACEA-96B00F85AAB5>
/System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
0x7fff656aa000 - 0x7fff656c3ffb com.apple.ProtocolBuffer (1 -
274.24.9.16.3) <5A020941-C43C-303E-8DE8-230FC6A84DBC>
/System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff65b23000 - 0x7fff65b4cff1 com.apple.RemoteViewServices (2.0 -
148) <D3AAC2BE-3423-3F18-9654-E35F1DD8DDB3>
/System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff65cb1000 - 0x7fff65cecff0 com.apple.RunningBoardServices (1.0
- 223.140.2) <96BB04BD-D6E0-3D70-8F36-89B46DA1DA30>
/System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
0x7fff675cd000 - 0x7fff675d0ff5 com.apple.SecCodeWrapper (4.0 -
448.100.6) <C4BF691D-A09E-37E8-A6CC-1145B79B8722>
/System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff67743000 - 0x7fff6786afff com.apple.Sharing (1526.37 -
1526.37) <CBDA0ADD-F1E7-3B06-9118-C5E183F0D3D6>
/System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff68c7f000 - 0x7fff68f75ff7 com.apple.SkyLight (1.600.0 - 451.4)
<A24929C3-95E6-35A7-9654-46FF3F4D1E80>
/System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff697c2000 - 0x7fff697d0ffb com.apple.SpeechRecognitionCore
(6.0.91.2 - 6.0.91.2) <4D6CAC2A-151B-3BBE-BDB7-E2BE72128691>
/System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff69eac000 - 0x7fff69eedff9 com.apple.StreamingZip (1.0 - 1)
<72CA32F8-4C96-3264-A655-623329EB3A28>
/System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff6a004000 - 0x7fff6a00dff7 com.apple.SymptomDiagnosticReporter
(1.0 - 1238.120.2) <C3D66901-7E31-3FDB-BD7A-441EB0520D1D>
/System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
0x7fff6a2c4000 - 0x7fff6a2d4ff3 com.apple.TCC (1.0 - 1)
<C9EB52E3-099B-3597-9623-067C403FA525>
/System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff6a7f9000 - 0x7fff6a8bfff0 com.apple.TextureIO (3.10.9 -
3.10.9) <EEDAB753-329A-396A-8119-5BEDF7DB5A56>
/System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff6aa8f000 - 0x7fff6ace7ff0 com.apple.UIFoundation (1.0 - 662)
<EC55B9E5-7E62-380A-9AB1-FC7BEF663653>
/System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff6b95d000 - 0x7fff6b97dffc com.apple.UserManagement (1.0 - 1)
<9F00880E-6EA6-3684-B208-455E14EC07C8>
/System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
0x7fff6c9ba000 - 0x7fff6c9bbfff com.apple.WatchdogClient.framework
(1.0 - 67.120.2) <FFA17DA1-F6DD-34D3-A708-1F73C8BA7EA7>
/System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
0x7fff6d5eb000 - 0x7fff6d5eeffa com.apple.dt.XCTTargetBootstrap (1.0
- 16091) <D459D628-58C5-39A6-B7E8-B691CBEECEC1>
/System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x7fff6d668000 - 0x7fff6d676ff5 com.apple.audio.caulk (1.0 - 32.3)
<06D695EA-E2BC-31E4-9816-9C12542BA744>
/System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x7fff6d9b8000 - 0x7fff6d9baff3 com.apple.loginsupport (1.0 - 1)
<12F77885-27DC-3837-9CE9-A25EBA75F833>
/System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff7049e000 - 0x7fff704d1ffa libAudioToolboxUtility.dylib
(1104.95) <E534364D-5E5F-37BA-9FB6-FFFF1416820C>
/usr/lib/libAudioToolboxUtility.dylib
0x7fff704d8000 - 0x7fff7050cfff libCRFSuite.dylib (48)
<5E5DE3CB-30DD-34DC-AEF8-FE8536A85E96> /usr/lib/libCRFSuite.dylib
0x7fff7050f000 - 0x7fff70519fff libChineseTokenizer.dylib (34)
<7F0DA183-1796-315A-B44A-2C234C7C50BE> /usr/lib/libChineseTokenizer.dylib
0x7fff705a5000 - 0x7fff705a7ff7 libDiagnosticMessagesClient.dylib
(112) <C94F3B7B-1854-38EB-9778-834501C53B3F>
/usr/lib/libDiagnosticMessagesClient.dylib
0x7fff705ed000 - 0x7fff707a4ffb libFosl_dynamic.dylib (100.4)
<737573B2-190A-3BA1-8220-807AD0A2CE5E> /usr/lib/libFosl_dynamic.dylib
0x7fff707cb000 - 0x7fff707d1ff3 libIOReport.dylib (54)
<75D177C4-BAD7-3285-B8E1-3019F49B3178> /usr/lib/libIOReport.dylib
0x7fff708b3000 - 0x7fff708bafff libMatch.1.dylib (36)
<5C6F3971-9D9E-3630-BDB6-60BFC5A665E0> /usr/lib/libMatch.1.dylib
0x7fff708e9000 - 0x7fff70909ff7 libMobileGestalt.dylib (826.140.5)
<2BE94E6A-FA61-312F-84A1-F764D71B7E39> /usr/lib/libMobileGestalt.dylib
0x7fff70a7b000 - 0x7fff70a7cfff libSystem.B.dylib (1281.100.1)
<8E6AD412-91E7-36FC-A6FD-C13B06A4952A> /usr/lib/libSystem.B.dylib
0x7fff70b09000 - 0x7fff70b0afff libThaiTokenizer.dylib (3)
<4F4ADE99-0D09-3223-B7C0-C407AB6DE8DC> /usr/lib/libThaiTokenizer.dylib
0x7fff70b22000 - 0x7fff70b38fff libapple_nghttp2.dylib (1.39.2)
<07FEC48A-87CF-32A3-8194-FA70B361713A> /usr/lib/libapple_nghttp2.dylib
0x7fff70b6d000 - 0x7fff70bdfff7 libarchive.2.dylib (72.140.2)
<F9EA2883-5D5C-3FA6-B3F8-C5031BF88ABD> /usr/lib/libarchive.2.dylib
0x7fff70be0000 - 0x7fff70c79fe5 libate.dylib (3.0.1)
<76EA60FB-748C-313F-8951-B076540BEA97> /usr/lib/libate.dylib
0x7fff70c7d000 - 0x7fff70c7dff3 libauto.dylib (187)
<B6124448-7690-34AE-8939-ED84AAC630CE> /usr/lib/libauto.dylib
0x7fff70d43000 - 0x7fff70d53ffb libbsm.0.dylib (60.100.1)
<00BFFB9A-2FFE-3C24-896A-251BC61917FD> /usr/lib/libbsm.0.dylib
0x7fff70d54000 - 0x7fff70d60fff libbz2.1.0.dylib (44)
<14CC4988-B6D4-3879-AFC2-9A0DDC6388DE> /usr/lib/libbz2.1.0.dylib
0x7fff70d61000 - 0x7fff70db3fff libc++.1.dylib (902.1)
<59A8239F-C28A-3B59-B8FA-11340DC85EDC> /usr/lib/libc++.1.dylib
0x7fff70db4000 - 0x7fff70dc9ffb libc++abi.dylib (902)
<E692F14F-C65E-303B-9921-BB7E97D77855> /usr/lib/libc++abi.dylib
0x7fff70dca000 - 0x7fff70dcafff libcharset.1.dylib (59)
<72447768-9244-39AB-8E79-2FA14EC0AD33> /usr/lib/libcharset.1.dylib
0x7fff70dcb000 - 0x7fff70ddcfff libcmph.dylib (8)
<E72A20DB-2E86-378D-A237-EB9A1370F989> /usr/lib/libcmph.dylib
0x7fff70ddd000 - 0x7fff70df4fd7 libcompression.dylib (87)
<64C91066-586D-38C0-A2F3-3E60A940F859> /usr/lib/libcompression.dylib
0x7fff710ce000 - 0x7fff710e4ff7 libcoretls.dylib (167)
<770A5B96-936E-34E3-B006-B1CEC299B5A5> /usr/lib/libcoretls.dylib
0x7fff710e5000 - 0x7fff710e6fff libcoretls_cfhelpers.dylib (167)
<940BF370-FD0C-30A8-AA05-FF48DA44FA4C> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff716a3000 - 0x7fff71702ff7 libcups.2.dylib (483.7)
<821ED293-B7B3-3B37-88C9-7B6CA91DA7FA> /usr/lib/libcups.2.dylib
0x7fff7180c000 - 0x7fff7180cfff libenergytrace.dylib (21)
<162DFCC0-8F48-3DD0-914F-FA8653E27B26> /usr/lib/libenergytrace.dylib
0x7fff7180d000 - 0x7fff71825fff libexpat.1.dylib (19.60.2)
<FED7C38B-92D8-342D-AED7-871B12D1F7E7> /usr/lib/libexpat.1.dylib
0x7fff71833000 - 0x7fff71835fff libfakelink.dylib (149.1)
<36146CB2-E6A5-37BB-9EE8-1B4034D8F3AD> /usr/lib/libfakelink.dylib
0x7fff71844000 - 0x7fff71849fff libgermantok.dylib (24)
<D2AE5AC0-EDCE-3216-B8C9-CF59292A545F> /usr/lib/libgermantok.dylib
0x7fff7184a000 - 0x7fff71853ff7 libheimdal-asn1.dylib (564.140.1)
<0AC6FB62-2B0F-3E93-A931-E4DC4B1D757A> /usr/lib/libheimdal-asn1.dylib
0x7fff71854000 - 0x7fff71944fff libiconv.2.dylib (59)
<18311A67-E4EF-3CC7-95B3-C0EDEE3A282F> /usr/lib/libiconv.2.dylib
0x7fff71945000 - 0x7fff71b9cfff libicucore.A.dylib (64260.0.1)
<8AC2CB07-E7E0-340D-A849-186FA1F27251> /usr/lib/libicucore.A.dylib
0x7fff71bb4000 - 0x7fff71bb5fff liblangid.dylib (133)
<30CFC08C-EF36-3CF5-8AEA-C1CB070306B7> /usr/lib/liblangid.dylib
0x7fff71bb6000 - 0x7fff71bceff3 liblzma.5.dylib (16)
<C131EF18-2CDD-3271-8A30-A8760D4FE166> /usr/lib/liblzma.5.dylib
0x7fff71be6000 - 0x7fff71c8dff7 libmecab.dylib (883.11)
<0D5BFD01-D4A7-3C8D-AA69-C329C1A69792> /usr/lib/libmecab.dylib
0x7fff71c8e000 - 0x7fff71ef0ff1 libmecabra.dylib (883.11)
<E31DE74D-1B88-377F-ACD3-D789D29C3AE7> /usr/lib/libmecabra.dylib
0x7fff7225d000 - 0x7fff7228cfff libncurses.5.4.dylib (57)
<995DFEEA-40F3-377F-B73D-D02AC59D591F> /usr/lib/libncurses.5.4.dylib
0x7fff723bc000 - 0x7fff72838ff5 libnetwork.dylib (1880.120.4)
<BA294A54-F309-398D-B308-F97032AFF555> /usr/lib/libnetwork.dylib
0x7fff728d9000 - 0x7fff7290cfde libobjc.A.dylib (787.1)
<6DF81160-5E7F-3E31-AA1E-C875E3B98AF6> /usr/lib/libobjc.A.dylib
0x7fff7291f000 - 0x7fff72923fff libpam.2.dylib (25.100.1)
<0502F395-8EE6-3D2A-9239-06FD5622E19E> /usr/lib/libpam.2.dylib
0x7fff72926000 - 0x7fff7295cff7 libpcap.A.dylib (89.120.1)
<A76EC076-A8EA-354C-B95F-7AB1EAFBCC65> /usr/lib/libpcap.A.dylib
0x7fff729e0000 - 0x7fff729f8fff libresolv.9.dylib (67.40.1)
<C57EDFEF-D36A-310B-8D14-8C68A625B1E8> /usr/lib/libresolv.9.dylib
0x7fff729fa000 - 0x7fff72a3eff7 libsandbox.1.dylib (1217.141.2)
<E8BA5E84-66AF-3995-8F8E-DDC93B0A88E1> /usr/lib/libsandbox.1.dylib
0x7fff72a52000 - 0x7fff72a53ff7 libspindump.dylib (281.3)
<AE8C1AE9-5CBC-332F-BBE8-370A2A19FED6> /usr/lib/libspindump.dylib
0x7fff72a54000 - 0x7fff72c3eff7 libsqlite3.dylib (308.5)
<35A2BD9F-4E33-30DE-A994-4AB585AC3AFE> /usr/lib/libsqlite3.dylib
0x7fff72e8f000 - 0x7fff72e92ffb libutil.dylib (57)
<F01467F6-23A7-37EE-A170-33CE1577B41D> /usr/lib/libutil.dylib
0x7fff72e93000 - 0x7fff72ea0ff7 libxar.1.dylib (425.2)
<EE964412-9E25-30B3-BCC0-CCEFBCC8094B> /usr/lib/libxar.1.dylib
0x7fff72ea6000 - 0x7fff72f88fff libxml2.2.dylib (33.7)
<20567881-7204-3C11-9179-50FE34B3301B> /usr/lib/libxml2.2.dylib
0x7fff72f8c000 - 0x7fff72fb4fff libxslt.1.dylib (16.9)
<34A45627-DA5B-37D2-9609-65B425E0010A> /usr/lib/libxslt.1.dylib
0x7fff72fb5000 - 0x7fff72fc7ff3 libz.1.dylib (76)
<793D9643-CD83-3AAC-8B96-88D548FAB620> /usr/lib/libz.1.dylib
0x7fff73876000 - 0x7fff7387bff3 libcache.dylib (83)
<AF488D13-9E89-35E0-B078-BE37CC5B8586> /usr/lib/system/libcache.dylib
0x7fff7387c000 - 0x7fff73887fff libcommonCrypto.dylib (60165.120.1)
<C7912BE5-993E-3581-B2A0-6AABDC8C5562> /usr/lib/system/libcommonCrypto.dylib
0x7fff73888000 - 0x7fff7388ffff libcompiler_rt.dylib (101.2)
<49B8F644-5705-3F16-BBE0-6FFF9B17C36E> /usr/lib/system/libcompiler_rt.dylib
0x7fff73890000 - 0x7fff73899ff7 libcopyfile.dylib (166.40.1)
<3C481225-21E7-370A-A30E-0CCFDD64A92C> /usr/lib/system/libcopyfile.dylib
0x7fff7389a000 - 0x7fff7392cfdb libcorecrypto.dylib (866.140.1)
<60567BF8-80FA-359A-B2F3-A3BAEFB288FD> /usr/lib/system/libcorecrypto.dylib
0x7fff73a39000 - 0x7fff73a79ff0 libdispatch.dylib (1173.100.2)
<CD9C059C-91D9-30E8-8926-5B9CD0D5D4F5> /usr/lib/system/libdispatch.dylib
0x7fff73a7a000 - 0x7fff73ab0fff libdyld.dylib (750.6)
<789A18C2-8AC7-3C88-813D-CD674376585D> /usr/lib/system/libdyld.dylib
0x7fff73ab1000 - 0x7fff73ab1ffb libkeymgr.dylib (30)
<DB3337BE-01CA-3425-BD0C-87774FC0CDC0> /usr/lib/system/libkeymgr.dylib
0x7fff73ab2000 - 0x7fff73abeff3 libkxld.dylib (6153.141.10)
<11EABEB3-CD17-3787-86BE-B8B21817E89B> /usr/lib/system/libkxld.dylib
0x7fff73abf000 - 0x7fff73abfff7 liblaunch.dylib (1738.140.2)
<7200E214-9B4D-3B22-9844-4C7892FC890B> /usr/lib/system/liblaunch.dylib
0x7fff73ac0000 - 0x7fff73ac5ff7 libmacho.dylib (959.0.1)
<AA613A9C-961A-3B67-B696-4622FA59FC4E> /usr/lib/system/libmacho.dylib
0x7fff73ac6000 - 0x7fff73ac8ff3 libquarantine.dylib (110.40.3)
<F234E51D-FD0B-3EE4-B679-AE3EE9C536C3> /usr/lib/system/libquarantine.dylib
0x7fff73ac9000 - 0x7fff73acaff7 libremovefile.dylib (48)
<7C7EFC79-BD24-33EF-B073-06AED234593E> /usr/lib/system/libremovefile.dylib
0x7fff73acb000 - 0x7fff73ae2ff3 libsystem_asl.dylib (377.60.2)
<1563EE02-0657-3B78-99BE-A947C24122EF> /usr/lib/system/libsystem_asl.dylib
0x7fff73ae3000 - 0x7fff73ae3ff7 libsystem_blocks.dylib (74)
<0D53847E-AF5F-3ACF-B51F-A15DEA4DEC58> /usr/lib/system/libsystem_blocks.dylib
0x7fff73ae4000 - 0x7fff73b6bfff libsystem_c.dylib (1353.100.2)
<BBDED5E6-A646-3EED-B33A-91E4331EA063> /usr/lib/system/libsystem_c.dylib
0x7fff73b6c000 - 0x7fff73b6fffb libsystem_configuration.dylib
(1061.141.1) <0EE84C33-64FD-372B-974A-AF7A136F2068>
/usr/lib/system/libsystem_configuration.dylib
0x7fff73b70000 - 0x7fff73b73fff libsystem_coreservices.dylib (114)
<A199156E-058D-3ABB-BCE9-4B9F20DCED0F>
/usr/lib/system/libsystem_coreservices.dylib
0x7fff73b74000 - 0x7fff73b7cfff libsystem_darwin.dylib (1353.100.2)
<5B12B5DB-3F30-37C1-8ECC-49A66B1F2864> /usr/lib/system/libsystem_darwin.dylib
0x7fff73b7d000 - 0x7fff73b84fff libsystem_dnssd.dylib (1096.100.3)
<EBB4C2C2-E031-3094-B40A-E67BF261D295> /usr/lib/system/libsystem_dnssd.dylib
0x7fff73b85000 - 0x7fff73b86ffb libsystem_featureflags.dylib (17)
<29FD922A-EC2C-3F25-BCCC-B58D716E60EC>
/usr/lib/system/libsystem_featureflags.dylib
0x7fff73b87000 - 0x7fff73bd4ff7 libsystem_info.dylib (538)
<8A321605-5480-330B-AF9E-64E65DE61747> /usr/lib/system/libsystem_info.dylib
0x7fff73bd5000 - 0x7fff73c01ff7 libsystem_kernel.dylib (6153.141.10)
<FF092EE8-5BEE-3B9A-8749-F0A067115C7E> /usr/lib/system/libsystem_kernel.dylib
0x7fff73c02000 - 0x7fff73c49fff libsystem_m.dylib (3178)
<00F331F1-0D09-39B3-8736-1FE90E64E903> /usr/lib/system/libsystem_m.dylib
0x7fff73c4a000 - 0x7fff73c71fff libsystem_malloc.dylib (283.100.6)
<8549294E-4C53-36EB-99F3-584A7393D8D5> /usr/lib/system/libsystem_malloc.dylib
0x7fff73c72000 - 0x7fff73c7fffb libsystem_networkextension.dylib
(1095.140.2) <F06C65C5-2CBE-313C-96E1-A09240F9FE57>
/usr/lib/system/libsystem_networkextension.dylib
0x7fff73c80000 - 0x7fff73c89ff7 libsystem_notify.dylib (241.100.2)
<FA22F928-D91B-3AA5-96BB-3186AC0FB264> /usr/lib/system/libsystem_notify.dylib
0x7fff73c8a000 - 0x7fff73c92fef libsystem_platform.dylib (220.100.1)
<009A7C1F-313A-318E-B9F2-30F4C06FEA5C>
/usr/lib/system/libsystem_platform.dylib
0x7fff73c93000 - 0x7fff73c9dfff libsystem_pthread.dylib (416.100.3)
<62CB1A98-0B8F-31E7-A02B-A1139927F61D> /usr/lib/system/libsystem_pthread.dylib
0x7fff73c9e000 - 0x7fff73ca2ff3 libsystem_sandbox.dylib (1217.141.2)
<051C4018-4345-3034-AC98-6DE42FB8273B> /usr/lib/system/libsystem_sandbox.dylib
0x7fff73ca3000 - 0x7fff73ca5fff libsystem_secinit.dylib (62.100.2)
<F80872AA-E1FD-3D7E-8729-467656EC6561> /usr/lib/system/libsystem_secinit.dylib
0x7fff73ca6000 - 0x7fff73cadffb libsystem_symptoms.dylib
(1238.120.2) <702D0910-5C34-3D43-9631-8BD215DE4FE1>
/usr/lib/system/libsystem_symptoms.dylib
0x7fff73cae000 - 0x7fff73cc4ff2 libsystem_trace.dylib (1147.120.1)
<BC141783-66D9-3137-A783-211B38E49ADB> /usr/lib/system/libsystem_trace.dylib
0x7fff73cc6000 - 0x7fff73ccbff7 libunwind.dylib (35.4)
<42B7B509-BAFE-365B-893A-72414C92F5BF> /usr/lib/system/libunwind.dylib
0x7fff73ccc000 - 0x7fff73d01ffe libxpc.dylib (1738.140.2)
<54EEF402-42C7-3995-BADE-93C48EFC4452> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 17202326
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=603.0M resident=0K(0%)
swapped_out_or_unallocated=603.0M(100%)
Writable regions: Total=64.3M written=0K(0%) resident=0K(0%)
swapped_out=0K(0%) unallocated=64.3M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Activity Tracing 256K 1
Dispatch continuations 8192K 1
Kernel Alloc Once 8K 1
MALLOC 46.1M 28
MALLOC guard page 16K 4
STACK GUARD 56.0M 4
Stack 9752K 4
VM_ALLOCATE 108K 3
__DATA 25.4M 311
__DATA_CONST 92K 5
__FONT_DATA 4K 1
__LINKEDIT 393.1M 31
__OBJC_RO 32.3M 1
__OBJC_RW 1908K 2
__TEXT 210.0M 304
__UNICODE 564K 1
mapped file 359.0M 21
shared memory 640K 15
TOTAL 1.1G 738
Model: MacBookAir8,2, BootROM 1554.60.15.0.0 (iBridge: 18.16.13030.0.0,0), 2
processors, Dual-Core Intel Core i5, 1,6 GHz, 16 GB, SMC
Graphics: kHW_IntelUHDGraphics617Item, Intel UHD Graphics 617,
spdisplays_builtin
Memory Module: BANK 0/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x80AD,
0x483943434E4E4E4641474D4C4C522D4E5644
Memory Module: BANK 1/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x80AD,
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x843), wl0:
Oct 27 2020 17:15:52 version 9.30.357.42.32.5.43 FWID 01-b9d21b73
Bluetooth: Version 7.0.6f8, 3 services, 25 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB3.0 Hub
USB Device: USB 10/100/1000 LAN
USB Device: USB 3.0 Bus
USB Device: USB2.0 Hub
USB Device: USB 2.0 Hub
USB Device: USB Optical Mouse
USB Device: USB Billboard Device
USB Device: Apple T2 Bus
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Headset
USB Device: Ambient Light Sensor
USB Device: FaceTime HD Camera (Built-in)
USB Device: Apple T2 Controller
Thunderbolt Bus: MacBook Air, Apple Inc., 47.4
