- To: "" <>
- Subject: Re: [cgal-discuss] Help to build from vcpkg
- Date: Thu, 14 Jan 2021 16:29:24 +0000
- Accept-language: en-US
- Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=epmap-system.com; dmarc=pass action=none header.from=epmap-system.com; dkim=pass header.d=epmap-system.com; arc=none
- Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=IaOa7C/GoT1ZvnaRypOIaesxRpbP48jX4+y9E1IL+KY=; b=ZiasNH93M4vb71jy/Ze8VnJ2Xa1qglFs1jXZRxsJYeXLk2wSoZ78vje6+/gKi0NwMF9XLl/FWY6635EwmcQrM/+q6Pvv4Vx+JMal7mkbM10DauYgeUfF3kPBKEU/3/1fQdvGU0TeNmWRXMhp1r8LJkm2s6N3DTTa7ddGmjqa8SwWCCdJbZrUBLjazNQTDWJ20qvvUPRvHQcW2ddyQQci62+0WAmIHoIJs7ylvmKJCPyMI4IlVrTFR9GKp3Q2SOjsYP1vZszRuFBrTMGLDP4Oj1mJGv7xJZLPrGZBjyX0aecyFuL92YPdnhrStGfGTpePtTjNMTtGK8IsVE1bCTiP/A==
- Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=hN8k7FGLZMOaGQXV5ll3H/We43weIXiRKcPDIrMwCJAgn0hUraVvCXbGm7rNb2q7i1CcVAJXuggLiiWptthWuMF2wZs1x+KRs+K27ww30MK1eLz3NgvR0DZVhSEgj/advtQ9raH1Kkae5tUSGmHvVZNG8klTC/BKD5G8Ynx3I1bKJ6CHpfa79pKndpMjL7wrXr24BfMOWsWnft/mWD1/ndpWrAWYML8d+gjz15XfjDyBNdkLQJ7Wb0t7QKXdylknB6k5xxJv6XXjiQCC4z968mbqZpidh6/igLc3SJX7Y7pmL6UVKms7i455Mf4e7KspWKjrFdCOfX7bL9j3+LaLLA==
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
- Ironport-phdr: 9a23:HeodJxMbZhjtEVZgWRIl6mtUPXoX/o7sNwtQ0KIMzox0K/78rsbcNUDSrc9gkEXOFd2Cra4d2qyO6+u5BiRAuc/H7CldNsQUFlcssoY/p0QYGsmLCEn2frbBThcRO4B8bmJj5GyxKkNPGczzNBX4q3y26iMOSF2kbVImbuv6FZTPgMupyuu854PcYxlShDq6fLh+MAi6oR/eu8ULhYZuMLo9xgfGrndVeeld2GdkKU6Okxrm6cq84Zxu/z5Mt/498sJLTLn3cbk/QbFEFjotLno75NfstRnNTAuP4mUTX2ALmRdWAAbL8Q/3UI7pviT1quRy1i+aPdbrTb8vQjSt871rSB7zhygZMTMy7XzahdZxjKJfpxKhugB/zovJa4ybKPZyYqXQds4cSGFcXMheSjZBD5u8YYUREuQBIehWoYrzp1QMrBuxGQajCfj1xTNUmnP7x7E23/g8HQzAwQcuH8gOsHPRrNjtKqkSVua1zanVxjjfd/NW2Cvy55bMchAlu/6HQLV9cdbWyUkpFwLKlE2QqY35MDyL0uQNt3KU4vF+WuK3jm4osRlxriG0xsYskYnJmpwaylXe+Splx4Y1IMS1RUhmatGrDJVerTuVN5dqQsw8WWFovj43x7MatZO1cyUEyJoqyh3DZ/GGb4WG4hztWemNLDpkmH5ofK+zihmy/Eagy+DxVcu53lZLoydZk9TBuHAA2h/N5sWBV/Bz8ECh2TOV2ADS7OFJOUE0lazBK54g2LE8jJQTsV7FEyTrm0v2lLebe0o49uSy9ujrfrfrqoWBO4NqiAzyKKsjltGnDegmMwUCQ3WX9OG92bDs/0D0RbVHgeM1n6XFtZ3VP8YWqbKlDwJQ3Isu5AywAjWj3dkZnXQKLlNIdRedgIf0JV7DIPX1APO7jlmokDpn3+7KM7z9DpjDK3XPjavtcqx85kNZ0wU/0MxT6pdbB7wEJf//R0D8udrFBREjKQO02fzoCNBl24MeR22PBqiZPbvcv1GH6O0jP/SAaJYItTjyN/Qp/vnugmQnllMHeqmpwIcXZ2u/HvR7JUWWfGDggs8bEWcNogoxUvDliEGDUT5UYXa+RaU85iwnCIKiCofDQYOtjKad0ye8G51afmFGClaSHnf0b4iJVOsAZDiPLsN9kDEIT6WtR5Ej2B20uwL21qJrLu/O9S0ZsZLj2sJ15+rWlRwq6Tx0CMKd0mGXQGFsn2MHWyE53KR7oUNn0VqMz7B4g/lCGtxL/v9JSQc7NYXAz+NkDtD+QB7OftCMSFq+WNWpHSkxTs4tw98Je0tyB9qigQrH3yazHrAVlqeLC4Ap8qLHxHj8PN19ynbD1Kk5lVYqWMpPNWu8hq5+7QffHYDJk1/K35usbrkWiS7R6H+Yny3Jp1BdSAc2UKPfXHlZaFGRtsX8/kqFTrmgDvMsPQJFjMKDMaBXcca6sFNdWf3DJNHaNmKth3+rV1HP3aKJdIOsemMH3SybBlJDiBEW5X/BNA4wAWCqrGvaSTBvDlnyeFi/zO9ltXmHQ18omgGWc1V6hf3y4Q8QnfXaSvUJ37tCtj1msCRxBF/63tTYDJ2LqANlOaldetgg+0wU6WWM/QdyN5jlI6F5jUMFaCx2uVnv3lN5EM8IxcMlpXdvwAtpIr+Dy3tAcSmZ1Nb+IOuEBHP1+UWTbKjHknjG0d2b/qMGoKAkrFPytRmoHUcm93xP3sFQ2mPZ/YTREAcXF5n2VxBkpFBBu7jGb3xltMvv3np2PPzs626Q65cSHOIgjy2YUZJaOaKAGhX1FpRKVcW2LeUy3kO4dQ4JOaZZ86tmZpr6JcvD47aiOaNbpBzjlX5OudAv31qJ/jI5Uf/Tw5sAhfqf21nfDmquvBKaqsny3Lt8S3QSE264lXe2KKNsPvQ3V6tTTGCkLouw28l0gIPrVzhA7lm/Clga2civPx2Pc1j62g4W3kMS8yWq
The compiler is finding boost. But the vcpkg build is installing boost 1.75, and these files have been removed that version. When I switch boost to version 1.69 then I can build.
Sent: Wednesday, January 13, 2021 11:58 PM
To: <>
To: <>
It seems your compiler cannot find boost. Did you give a valid path to cmake for Boost_DIR or BOOST_ROOT ?
Le mer. 13 janv. 2021 à 22:42, Tony Apicella <> a écrit :
I am trying to build and use CGAL by using the vcpkg tool.Everything has installed without error.
But when compiling my code, which is mostly the example code taken from Mesh_3/mesh_3D_gray_image.cpp,I have the following error coming from ls_mesh_domain_field_3.h
Cannot open include file: 'boost/callable_traits/is_invocable.hpp': No such file or directory
Thank you
- [cgal-discuss] Help to build from vcpkg, Tony Apicella, 01/13/2021
- Re: [cgal-discuss] Help to build from vcpkg, Maxime Gimeno, 01/14/2021
- Re: [cgal-discuss] Help to build from vcpkg, Tony Apicella, 01/14/2021
- Re: [cgal-discuss] Help to build from vcpkg, Maxime Gimeno, 01/15/2021
- Re: [cgal-discuss] Help to build from vcpkg, Tony Apicella, 01/15/2021
