- To: "" <>
- Subject: [cgal-discuss] Adding vertices to a mesh_3
- Date: Thu, 21 Jan 2021 23:31:52 +0000
- Accept-language: en-US
- Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=epmap-system.com; dmarc=pass action=none header.from=epmap-system.com; dkim=pass header.d=epmap-system.com; arc=none
- Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=8v/X6MEdNk+iCo5Jp+9uG34qHS8q4rQR0LTyZqS9p3E=; b=nOhVjnOqvrtvu+95+AtuUeDxCpG7BxSncUw2yGmdq0m4asIopjafY6XNoZ7AEwmXuxCv1lG7mMn+32Opf0Hs9iRPEIbbe3P8hxDfOP1rJ3Zybms39iJG9LIeAl2lgG3ShDHC50yr1L6zRVHxsFrUzy902JbZZ6UyMka8jZk42An+kUSp4vnD4Wi8ErLOCkTIuxsT8bz30xWR22/soNbseaAMHanBYWtMG2pB4jXkRt5fpqWG2eMAxmLekQ9wHcJQ1VWuKpGAUWsfcVdPGBxVMoht1wj1wb+6pckhlG9XH8MYD9HibG7ZOAHBez2e1uxURjf/whEhe35ewEpUTgvjUQ==
- Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=nEnSavapRTCl/HvHIJEBH2zPbxEduauE8l4YuKsQILFkTxCOVARHbmBZIy/kkiiQlKKnglkW2zUq77HXRqgAL8ZVA5OQVc1pEa54BG2F1jcKI16NaMPJNDyLmuoARDt3DQox6ZHgSV+nuCljuxJdPwqz3y8j4VP3KT6qm6gMeuxhKonRK/Sp+XiwxQAlsZQu/s0wgG++0s3R70OpW3Svf+UjJMo0lbSEc74szy4shlmLXUtw6A3O1Vr0EEW16tLLjMz1h2lrW5EiuTo9bIi8wv89+fgeliZRJl+7tB/owwFVvqnkzylGSuEsSn2PrF1RoKRoqIVD/7LahXV9dM5erw==
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
- Ironport-phdr: 9a23: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
Once we have formed a mesh using the mesh_3 classes, and the customer provides us with a few more vertices to consider, do we have to rebuild the entire mesh? Is there some way to start with the current mesh as an initial estimate and quickly produce an updated
mesh?
Thank you.
- [cgal-discuss] Adding vertices to a mesh_3, Tony Apicella, 01/22/2021
- Re: [cgal-discuss] Adding vertices to a mesh_3, Jane Tournois, 01/25/2021
