- To:
- Subject: Re: [cgal-discuss] Adding vertices to a mesh_3
- Date: Mon, 25 Jan 2021 16:47:57 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
Hello,
after forming a mesh with Mesh_3, you have a Mesh_complex_3_in_triangulation_3.
The API gives a non-const access to the underlying triangulation, with the `triangulation()` accessor, see [1]. So, you can insert more vertices or perform other Delaunay_triangulation_3 operations. As mentioned in the documentation, the C3T3 has to be kept valid by the user.
Best regards,
Jane.
Le 22/01/2021 à 00:31, Tony Apicella a
écrit :
Once we have formed a mesh using the mesh_3 classes, and the
customer provides us with a few more vertices to consider, do we
have to rebuild the entire mesh? Is there some way to start
with the current mesh as an initial estimate and quickly produce
an updated mesh?
Thank you.
-- Jane Tournois, PhD R&D Engineer at GeometryFactory http://www.geometryfactory.com/
- [cgal-discuss] Adding vertices to a mesh_3, Tony Apicella, 01/22/2021
- Re: [cgal-discuss] Adding vertices to a mesh_3, Jane Tournois, 01/25/2021
