Re: [cgal-discuss] Problems for running "Triangulation_2_Examples" code with QT and VS2017
- To:
- Subject: Re: [cgal-discuss] Problems for running "Triangulation_2_Examples" code with QT and VS2017
- Date: Wed, 10 Mar 2021 05:06:23 -0600 (CST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
do you mean the path of "draw_triangulation_2.exe" and "? it is in the
"G:\MyCGAL_code\code_1\Triangulation_2\build\Debug"
- [cgal-discuss] Problems for running "Triangulation_2_Examples" code with QT and VS2017, Aomandeyi, 03/10/2021
- Re: [cgal-discuss] Problems for running "Triangulation_2_Examples" code with QT and VS2017, Kabir Kedia, 03/10/2021
- Re: [cgal-discuss] Problems for running "Triangulation_2_Examples" code with QT and VS2017, Aomandeyi, 03/10/2021
- Re: [cgal-discuss] Problems for running "Triangulation_2_Examples" code with QT and VS2017, Maxime Gimeno, 03/10/2021
- Re: [cgal-discuss] Problems for running "Triangulation_2_Examples" code with QT and VS2017, Andreas Fabri, 03/10/2021
