Re: [cgal-discuss] Problems for running "Triangulation_2_Examples" code with QT and VS2017
- To:
- Subject: Re: [cgal-discuss] Problems for running "Triangulation_2_Examples" code with QT and VS2017
- Date: Wed, 10 Mar 2021 06:08:28 -0600 (CST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
thank you very much , i copy the file "data" into the file "build" , the
"data" file contain some files which included some "CIN" files ,so the
program can find theses inputs. It works!
but do you know how to generate such "CIN" files? can it be generated by
some software? Photoshop?
- [cgal-discuss] Problems for running "Triangulation_2_Examples" code with QT and VS2017, Aomandeyi, 03/10/2021
- Re: [cgal-discuss] Problems for running "Triangulation_2_Examples" code with QT and VS2017, Kabir Kedia, 03/10/2021
- Re: [cgal-discuss] Problems for running "Triangulation_2_Examples" code with QT and VS2017, Aomandeyi, 03/10/2021
- Re: [cgal-discuss] Problems for running "Triangulation_2_Examples" code with QT and VS2017, Maxime Gimeno, 03/10/2021
- Re: [cgal-discuss] Problems for running "Triangulation_2_Examples" code with QT and VS2017, Andreas Fabri, 03/10/2021
