Re: [cgal-discuss] Problems for running "Triangulation_2_Examples" code with QT and VS2017
- To:
- Subject: Re: [cgal-discuss] Problems for running "Triangulation_2_Examples" code with QT and VS2017
- Date: Wed, 10 Mar 2021 12:14:40 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
No, I mean that to print something in your viewer, you need to call `G:\MyCGAL_code\code_1\Triangulation_2\build\Debug\draw_triangulation_2.exe <path_to_some_example_data.cin>`
Or you can change your current directory to CGAL/Triangulation_2/examples/Triangulation_2, so that the 'data/triangulation_1.cin` default file is available to your program.
Le mer. 10 mars 2021 à 12:06, Aomandeyi <> a écrit :
do you mean the path of "draw_triangulation_2.exe" and "? it is in the
"G:\MyCGAL_code\code_1\Triangulation_2\build\Debug"
- [cgal-discuss] Problems for running "Triangulation_2_Examples" code with QT and VS2017, Aomandeyi, 03/10/2021
- Re: [cgal-discuss] Problems for running "Triangulation_2_Examples" code with QT and VS2017, Kabir Kedia, 03/10/2021
- Re: [cgal-discuss] Problems for running "Triangulation_2_Examples" code with QT and VS2017, Aomandeyi, 03/10/2021
- Re: [cgal-discuss] Problems for running "Triangulation_2_Examples" code with QT and VS2017, Maxime Gimeno, 03/10/2021
- Re: [cgal-discuss] Problems for running "Triangulation_2_Examples" code with QT and VS2017, Andreas Fabri, 03/10/2021
