cgal-discuss - Re: [cgal-discuss] Periodic 3D mesh aligned with bounding cube cgal-discuss
  • To:
  • Subject: Re: [cgal-discuss] Periodic 3D mesh aligned with bounding cube cgal-discuss
  • Date: Tue, 16 Mar 2021 14:48:20 +0000
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-hdrordr: A9a23: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
  • Ironport-phdr: A9a23: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
Dear Monique,
I agree that adding points on the facets of the bounding cube in the
right places would be a way to solve this. But this technique requires
a description of the regions on each facet that should be
triangulated. This is difficult because many of the surfaces I am
dealing with are defined implicitly and do not cover the entirety of
the cube's facets. Is there something in CGAL that would help do this?
However, I suppose my actual issue is being able to accurately specify
boundary conditions. I was trying to make this easy by forcing the
boundaries of the mesh to align with bounding cube.
With a triangulation generated by the periodic mesh package, is there
a way to colour or otherwise somehow mark the cell faces on each
boundary? I'm not sure this is a meaningful question given the
irregular nature of the boundaries!
Sorry for the basic questions - I'm new to CGAL and still finding my way
around!
Many thanks,
Matt
On Tue, 16 Mar 2021 at 10:54, Monique Teillaud
<> wrote:
> Dear Matthew,
> In fact, if you add points on the facets of the cube and you ensure that
> the facets are triangulated as mael suggests, then you are enforcing the
> periodicity through these points. You are not using the functionality that
> is offered by the periodic mesh package.
> In other words, this should rather be done with the non-periodic meshing
> package.
> (In fact I would be curious why you need the facets to be triangulated...
> Our algorithm is precisely designed to avoid adding such artificial
> points...)
> Best regards,
> Monique Teillaud
> https://members.loria.fr/Monique.Teillaud/
> INRIA Nancy - Grand Est, LORIA
> Institut National de Recherche en Informatique et Automatique
> ----- Le 15 Mar 21, à 17:21, cgal-discuss <> a écrit :
> Hi Mael,
> Thanks for your reply.
> It's a shame the periodic mesher can't do this currently. Would you be able
> to give some hints on how to implement your idea of using the standard 3D
> mesh package? I'm slightly wary about manually moving vertices around -
> won't this reduce the quality of the resulting mesh?
> Thanks,
> Matt
> On Mon, 15 Mar 2021, 08:04 Mael Rouxel-Labbé,
> <> wrote:
>> Hello,
>> This is not currently possible in a straightforward manner in the
>> periodic mesh generator, as there is no 3D constrained Delaunay
>> triangulations in CGAL yet.
>> In a less straight forward manner, if you wish your elements to lie
>> exactly on the boundary of the periodic domain, you might be able to do
>> away with the periodic mesh generation algorithm: generate a 3D mesh of
>> the implicit function clipped by the periodic domain, and then ensure
>> that the vertices are identical on both sides.
>> Best,
>> Mael
>> On 15/03/2021 02:05, Matthew Russell ( via
>> cgal-discuss Mailing List) wrote:
>> > Dear all,
>> > I would like to generate periodic 3D meshes of regions bounded by
>> > implicit functions and so I was pleased to find examples such as [1]
>> > that do almost exactly what I want. The problem that I'm having is
>> > that cells in the meshes generated from this example are able to lie
>> > across the bounding unit cube, but to use the meshes in finite element
>> > simulations I need the faces of the cells to align with the boundaries
>> > of the cube.
>> > For example, the CGAL example [1] (with a different implciit function)
>> > generates meshes like [cgal.jpg], but I would like one like
>> > [gmsh.jpg].
>> > I haven't been able to find a way to do this in CGAL. Is it possible?
>> > Many thanks,
>> > Matt
>> > [1]
>> > https://doc.cgal.org/latest/Periodic_3_mesh_3/Periodic_3_mesh_3_2mesh_implicit_shape_8cpp-example.html
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://sympa.inria.fr/sympa/info/cgal-discuss
