- To:
- Subject: Re: [cgal-discuss] Periodic 3D mesh aligned with bounding cube cgal-discuss
- Date: Wed, 17 Mar 2021 08:29:52 +0900
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-hdrordr: A9a23:vrGic6AmFc1lk/jlHejysceALOonbusQ8zAX/mp2TgFYddHdqtC2kJ0gpGbJoRsyeFVlo9CPP6GcXWjRnKQe3aA9NaqvNTOW3VeAA5pl6eLZsl/dMg34stVQzKJxN5V5YeeAbmRSqebfzE2GH807wN+BmZrIuc77w212RQ9nL4FMhj0JbjqzKUF9SAlYCZdRLvP1jfZvnDaudW8aac62HBA+P9TrncHBl57tfHc9dnkawTSJ5AnYjoLSIly32lM7XylUybkvtVLZmxH0j5/Oj9iLjjHb0WHX49B6uvvEjuFCCsuFl9QPJlzX5zqAVcBOXbuNuTxwmuWz8RIRlsXWqRtIBatOwkKURW2+rRvz1wSI6lgT10M=
- Ironport-phdr: A9a23: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
Dear Matthew, Monique, all,
Sorry to appear out of nowhere like this, but I would like to offer another perspective, perhaps.
Matthew, you mention that in your FEM problem you want to define periodic boundary conditions.
The need for specifying periodic boundary conditions in FEM problems comes from the fact that
traditional meshes do not have a way to represent the periodic medium over which the equation
to be solved is defined. In other words, you need to discretize your domain so that the vertices and
faces coincide neatly, so that you know how to compute interactions and value propagations
periodically, from one side to the other.
The thing is, with a periodic mesh, you don't need to specify any boundary conditions, because there
is no boundary. The CGAL periodic 3D mesh package represents a domain that "wraps around" in
3 dimensions, as the name implies, so the only things you need to define are the equation itself and the
initial conditions. In this setting, boundary conditions actually do not make sense -- if you try to apply
boundary conditions, you would end up splitting a torus only to glue it back together.
Why not just use the torus? :)
I am guessing it will require some re-formulating of your problem, but you will get much better results
in the end, and your computation will be more efficient. The reason is that, when you define a traditional
mesh, you need to store the boundary elements (vertices/faces) twice. Moreover, you need to keep track
of which vertices coincide and when not to count interactions twice, so it is a bit messy. With the periodic
mesh, you really don't save anything extra, and all the elements are unique. Every element knows its
neighbors so computations are much more straightforward conceptually.
I hope this has some meaning for you, and, once more, sorry for butting in like this.
Best of luck and best regards,
- Iordan
On Wed, Mar 17, 2021 at 3:29 AM Matthew Russell <> wrote:
Dear Monique,
Thanks - I saw that example and have tried using a unit cube (defined
implicitly) as the second function in the vector but I don't think it
solves my problem. Is this what you had in mind? The resulting mesh is
similar to the example attached to my original email, except that it
can also include the region with the opposite sign (which I don't
require), depending on the chosen sign vectors.
Apologies if I described the problem poorly! I would like to create a
collection of different meshes, one for each of a collection of
implicitly-defined regions, so I don't think it's a multiple domains
problem. On each mesh I will run a separate finite element simulation
with periodic boundary conditions. We can ignore the multiple meshes
here and consider just one. To make it easy to identify the periodic
boundaries in the FEM code, my first thought was to try to create
meshes where the cells at the boundaries lie on the facets of the
bounding cube as I mentioned earlier. It seems this isn't possible
with the periodic mesh package, but there may be a workaround using
the regular 3D mesh package as Mael suggested. I was wondering if
someone had any further hints on how to achieve this? It seems like a
difficult problem to manually place vertices on the intersection
between the bound cube's facets and the implicit region. I really
appreciate all your help with this!
Thanks,
Matt
On Tue, 16 Mar 2021 at 15:44, Monique Teillaud
<> wrote:
> Dear Matthew,
> If I understand correctly (I am not sure) you would like to mesh multiple domains.
> Does this example help you?
> https://doc.cgal.org/latest/Periodic_3_mesh_3/index.html#title19
> Best,
> Monique Teillaud
> https://members.loria.fr/Monique.Teillaud/
> INRIA Nancy - Grand Est, LORIA
> Institut National de Recherche en Informatique et Automatique
> ----- Le 16 Mar 21, à 15:48, cgal-discuss a écrit :
> > Dear Monique,
> > I agree that adding points on the facets of the bounding cube in the
> > right places would be a way to solve this. But this technique requires
> > a description of the regions on each facet that should be
> > triangulated. This is difficult because many of the surfaces I am
> > dealing with are defined implicitly and do not cover the entirety of
> > the cube's facets. Is there something in CGAL that would help do this?
> > However, I suppose my actual issue is being able to accurately specify
> > boundary conditions. I was trying to make this easy by forcing the
> > boundaries of the mesh to align with bounding cube.
> > With a triangulation generated by the periodic mesh package, is there
> > a way to colour or otherwise somehow mark the cell faces on each
> > boundary? I'm not sure this is a meaningful question given the
> > irregular nature of the boundaries!
> > Sorry for the basic questions - I'm new to CGAL and still finding my way around!
> > Many thanks,
> > Matt
> > On Tue, 16 Mar 2021 at 10:54, Monique Teillaud
> > <> wrote:
> >> Dear Matthew,
> >> In fact, if you add points on the facets of the cube and you ensure that the
> >> facets are triangulated as mael suggests, then you are enforcing the
> >> periodicity through these points. You are not using the functionality that is
> >> offered by the periodic mesh package.
> >> In other words, this should rather be done with the non-periodic meshing
> >> package.
> >> (In fact I would be curious why you need the facets to be triangulated... Our
> >> algorithm is precisely designed to avoid adding such artificial points...)
> >> Best regards,
> >> Monique Teillaud
> >> ----- Le 15 Mar 21, à 17:21, cgal-discuss <> a écrit :
> >> Hi Mael,
> >> Thanks for your reply.
> >> It's a shame the periodic mesher can't do this currently. Would you be able to
> >> give some hints on how to implement your idea of using the standard 3D mesh
> >> package? I'm slightly wary about manually moving vertices around - won't this
> >> reduce the quality of the resulting mesh?
> >> Thanks,
> >> Matt
> >> On Mon, 15 Mar 2021, 08:04 Mael Rouxel-Labbé,
> >> <> wrote:
> >>> Hello,
> >>> This is not currently possible in a straightforward manner in the
> >>> periodic mesh generator, as there is no 3D constrained Delaunay
> >>> triangulations in CGAL yet.
> >>> In a less straight forward manner, if you wish your elements to lie
> >>> exactly on the boundary of the periodic domain, you might be able to do
> >>> away with the periodic mesh generation algorithm: generate a 3D mesh of
> >>> the implicit function clipped by the periodic domain, and then ensure
> >>> that the vertices are identical on both sides.
> >>> Best,
> >>> Mael
> >>> On 15/03/2021 02:05, Matthew Russell ( via
> >>> cgal-discuss Mailing List) wrote:
> >>> > Dear all,
> >>> > I would like to generate periodic 3D meshes of regions bounded by
> >>> > implicit functions and so I was pleased to find examples such as [1]
> >>> > that do almost exactly what I want. The problem that I'm having is
> >>> > that cells in the meshes generated from this example are able to lie
> >>> > across the bounding unit cube, but to use the meshes in finite element
> >>> > simulations I need the faces of the cells to align with the boundaries
> >>> > of the cube.
> >>> > For example, the CGAL example [1] (with a different implciit function)
> >>> > generates meshes like [cgal.jpg], but I would like one like
> >>> > [gmsh.jpg].
> >>> > I haven't been able to find a way to do this in CGAL. Is it possible?
> >>> > Many thanks,
> >>> > Matt
> >>> > [1]
> >>> > https://doc.cgal.org/latest/Periodic_3_mesh_3/Periodic_3_mesh_3_2mesh_implicit_shape_8cpp-example.html
> >>> You are currently subscribed to cgal-discuss.
> >>> To unsubscribe or access the archives, go to
> >>> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] Periodic 3D mesh aligned with bounding cube cgal-discuss, Matthew Russell, 03/15/2021
- Re: [cgal-discuss] Periodic 3D mesh aligned with bounding cube cgal-discuss, Mael Rouxel-Labbé, 03/15/2021
- Re: [cgal-discuss] Periodic 3D mesh aligned with bounding cube cgal-discuss, Matthew Russell, 03/15/2021
- Re: [cgal-discuss] Periodic 3D mesh aligned with bounding cube cgal-discuss, Monique Teillaud, 03/16/2021
- Re: [cgal-discuss] Periodic 3D mesh aligned with bounding cube cgal-discuss, Matthew Russell, 03/16/2021
- Re: [cgal-discuss] Periodic 3D mesh aligned with bounding cube cgal-discuss, Iordan Iordanov, 03/17/2021
- Re: [cgal-discuss] Periodic 3D mesh aligned with bounding cube cgal-discuss, Matthew Russell, 03/17/2021
- Re: [cgal-discuss] Periodic 3D mesh aligned with bounding cube cgal-discuss, Mael Rouxel-Labbé, 03/17/2021
- [cgal-discuss] PRIVATE - Re: Periodic 3D mesh aligned with bounding cube cgal-discuss, Mael Rouxel-Labbé, 03/17/2021
