- To: cgal-discuss <>
- Subject: Re: [cgal-discuss] Periodic 3D mesh aligned with bounding cube cgal-discuss
- Date: Tue, 16 Mar 2021 16:44:27 +0100 (CET)
- Ironport-hdrordr: A9a23:ynRYiamv+UtgWDTrnOLX8OHiujjpDfLL3DAbvn1ZSRFFG/GwvcrGppkm/DXzjyscX2xlvNiGNrWJT3+0z+8Q3aA6O7C+UA76/Fa5NY0K1/qG/xTMEzDzn9Q96Y5OaK57YeeeMXFbioLA7BC8A5IcxrC8gcKVrMP/61socg1wcaFn6G5Ce2WmO2l7XhNPC5Z8NLf03KR6jgGtc3gWcci3b0NtN9TrnNHFmInrZhQLHXcchDWmty+i67LxDnGjtSs2bjUn+90f2FTenxe8zquutOzT8H/h61M=
Dear Matthew,
If I understand correctly (I am not sure) you would like to mesh multiple
domains.
Does this example help you?
https://doc.cgal.org/latest/Periodic_3_mesh_3/index.html#title19
Best,
Monique Teillaud
https://members.loria.fr/Monique.Teillaud/
INRIA Nancy - Grand Est, LORIA
Institut National de Recherche en Informatique et Automatique
----- Le 16 Mar 21, à 15:48, cgal-discuss a écrit :
> Dear Monique,
> I agree that adding points on the facets of the bounding cube in the
> right places would be a way to solve this. But this technique requires
> a description of the regions on each facet that should be
> triangulated. This is difficult because many of the surfaces I am
> dealing with are defined implicitly and do not cover the entirety of
> the cube's facets. Is there something in CGAL that would help do this?
> However, I suppose my actual issue is being able to accurately specify
> boundary conditions. I was trying to make this easy by forcing the
> boundaries of the mesh to align with bounding cube.
> With a triangulation generated by the periodic mesh package, is there
> a way to colour or otherwise somehow mark the cell faces on each
> boundary? I'm not sure this is a meaningful question given the
> irregular nature of the boundaries!
> Sorry for the basic questions - I'm new to CGAL and still finding my way
> around!
> Many thanks,
> Matt
> On Tue, 16 Mar 2021 at 10:54, Monique Teillaud
> <> wrote:
>> Dear Matthew,
>> In fact, if you add points on the facets of the cube and you ensure that
>> the
>> facets are triangulated as mael suggests, then you are enforcing the
>> periodicity through these points. You are not using the functionality that
>> is
>> offered by the periodic mesh package.
>> In other words, this should rather be done with the non-periodic meshing
>> package.
>> (In fact I would be curious why you need the facets to be triangulated...
>> Our
>> algorithm is precisely designed to avoid adding such artificial points...)
>> Best regards,
>> Monique Teillaud
>> ----- Le 15 Mar 21, à 17:21, cgal-discuss <> a écrit :
>> Hi Mael,
>> Thanks for your reply.
>> It's a shame the periodic mesher can't do this currently. Would you be
>> able to
>> give some hints on how to implement your idea of using the standard 3D mesh
>> package? I'm slightly wary about manually moving vertices around - won't
>> this
>> reduce the quality of the resulting mesh?
>> Thanks,
>> Matt
>> On Mon, 15 Mar 2021, 08:04 Mael Rouxel-Labbé,
>> <> wrote:
>>> Hello,
>>> This is not currently possible in a straightforward manner in the
>>> periodic mesh generator, as there is no 3D constrained Delaunay
>>> triangulations in CGAL yet.
>>> In a less straight forward manner, if you wish your elements to lie
>>> exactly on the boundary of the periodic domain, you might be able to do
>>> away with the periodic mesh generation algorithm: generate a 3D mesh of
>>> the implicit function clipped by the periodic domain, and then ensure
>>> that the vertices are identical on both sides.
>>> Best,
>>> Mael
>>> On 15/03/2021 02:05, Matthew Russell ( via
>>> cgal-discuss Mailing List) wrote:
>>> > Dear all,
>>> > I would like to generate periodic 3D meshes of regions bounded by
>>> > implicit functions and so I was pleased to find examples such as [1]
>>> > that do almost exactly what I want. The problem that I'm having is
>>> > that cells in the meshes generated from this example are able to lie
>>> > across the bounding unit cube, but to use the meshes in finite element
>>> > simulations I need the faces of the cells to align with the boundaries
>>> > of the cube.
>>> > For example, the CGAL example [1] (with a different implciit function)
>>> > generates meshes like [cgal.jpg], but I would like one like
>>> > [gmsh.jpg].
>>> > I haven't been able to find a way to do this in CGAL. Is it possible?
>>> > Many thanks,
>>> > Matt
>>> > [1]
>>> > https://doc.cgal.org/latest/Periodic_3_mesh_3/Periodic_3_mesh_3_2mesh_implicit_shape_8cpp-example.html
>>> You are currently subscribed to cgal-discuss.
>>> To unsubscribe or access the archives, go to
>>> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] Periodic 3D mesh aligned with bounding cube cgal-discuss, Matthew Russell, 03/15/2021
- Re: [cgal-discuss] Periodic 3D mesh aligned with bounding cube cgal-discuss, Mael Rouxel-Labbé, 03/15/2021
- Re: [cgal-discuss] Periodic 3D mesh aligned with bounding cube cgal-discuss, Matthew Russell, 03/15/2021
- Re: [cgal-discuss] Periodic 3D mesh aligned with bounding cube cgal-discuss, Monique Teillaud, 03/16/2021
- Re: [cgal-discuss] Periodic 3D mesh aligned with bounding cube cgal-discuss, Matthew Russell, 03/16/2021
- Re: [cgal-discuss] Periodic 3D mesh aligned with bounding cube cgal-discuss, Iordan Iordanov, 03/17/2021
- Re: [cgal-discuss] Periodic 3D mesh aligned with bounding cube cgal-discuss, Matthew Russell, 03/17/2021
- Re: [cgal-discuss] Periodic 3D mesh aligned with bounding cube cgal-discuss, Mael Rouxel-Labbé, 03/17/2021
- [cgal-discuss] PRIVATE - Re: Periodic 3D mesh aligned with bounding cube cgal-discuss, Mael Rouxel-Labbé, 03/17/2021
