cgal-discuss - Re: [cgal-discuss] CMake Problem Installing CGAL 5.2.2
  • To:
  • Subject: Re: [cgal-discuss] CMake Problem Installing CGAL 5.2.2
  • Date: Fri, 9 Jul 2021 10:04:10 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-hdrordr: A9a23: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
  • Ironport-phdr: A9a23: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
Hello,
It seems you are missing GMP. Did you follow the instructions at https://doc.cgal.org/latest/Manual/windows.html#ssec-vcpk-install-cgal ?
Le jeu. 8 juil. 2021 à 23:06, Jeb Gaither <> a écrit :
Hi
CMake encounters errors when I try to do C:\dev\CGAL-5.2.2\examples\Triangulation_2\build> cmake-gui.
The following is the CMake Output from the screen:
The C compiler identification is MSVC 19.29.30038.1
The CXX compiler identification is MSVC 19.29.30038.1
Detecting C compiler ABI info
Detecting C compiler ABI info - done
Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.29.30037/bin/Hostx64/x64/cl.exe - skipped
Detecting C compile features
Detecting C compile features - done
Detecting CXX compiler ABI info
Detecting CXX compiler ABI info - done
Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.29.30037/bin/Hostx64/x64/cl.exe - skipped
Detecting CXX compile features
Detecting CXX compile features - done
Visual Leak Detector (VLD) is not found.
Using header-only CGAL
Targetting Visual Studio 16 2019
Target build enviroment supports auto-linking
Using VC toolset 142.
Generator uses intermediate configuration directory: $(Configuration)
CMake Error at C:/Program Files/CMake/share/cmake-3.21/Modules/FindPackageHandleStandardArgs.cmake:230 (message):
  Could NOT find GMP (missing: GMP_LIBRARIES GMP_INCLUDE_DIR)
Call Stack (most recent call first):
  C:/Program Files/CMake/share/cmake-3.21/Modules/FindPackageHandleStandardArgs.cmake:594 (_FPHSA_FAILURE_MESSAGE)
  C:/dev/vcpkg/installed/x86-windows/share/cgal/FindGMP.cmake:53 (find_package_handle_standard_args)
  C:/dev/vcpkg/scripts/buildsystems/vcpkg.cmake:792 (_find_package)
  C:/dev/vcpkg/installed/x86-windows/share/cgal/CGAL_SetupGMP.cmake:24 (find_package)
  C:/dev/vcpkg/installed/x86-windows/share/cgal/CGAL_SetupCGALDependencies.cmake:41 (include)
  C:/dev/vcpkg/installed/x86-windows/share/cgal/CGALConfig.cmake:128 (include)
  CMakeLists.txt:16 (find_package)
Configuring incomplete, errors occurred!
See also "C:/dev/CGAL-5.2.2/examples/Triangulation_2/build/CMakeFiles/CMakeOutput.log".
The CMakeOutput.log is:
The system is: Windows - 10.0.19041 - AMD64
Compiling the C compiler identification source file "CMakeCCompilerId.c" succeeded.
Compiler:
Build flags:
Id flags:
The output was:
Microsoft (R) Build Engine version 16.10.2+857e5a733 for .NET Framework
Copyright (C) Microsoft Corporation. All rights reserved.
Build started 7/8/2021 4:03:21 PM.
Project "C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\3.21.0-rc2\CompilerIdC\CompilerIdC.vcxproj" on node 1 (default targets).
PrepareForBuild:
  Creating directory "Debug\".
  Creating directory "Debug\CompilerIdC.tlog\".
InitializeBuildStatus:
  Creating "Debug\CompilerIdC.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
ClCompile:
  C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.29.30037\bin\HostX64\x64\CL.exe /c /nologo /W0 /WX- /diagnostics:column /Od /D _MBCS /Gm- /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /Zc:inline /Fo"Debug\\" /Fd"Debug\vc142.pdb" /external:env:EXTERNAL_INCLUDE /external:W0 /Gd /TC /FC /errorReport:queue CMakeCCompilerId.c
  CMakeCCompilerId.c
Link:
  C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.29.30037\bin\HostX64\x64\link.exe /ERRORREPORT:QUEUE /OUT:".\CompilerIdC.exe" /INCREMENTAL:NO /NOLOGO kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /MANIFEST /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /manifest:embed /PDB:".\CompilerIdC.pdb" /SUBSYSTEM:CONSOLE /TLBID:1 /DYNAMICBASE /NXCOMPAT /IMPLIB:".\CompilerIdC.lib" /MACHINE:X64 Debug\CMakeCCompilerId.obj
  CompilerIdC.vcxproj -> C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\3.21.0-rc2\CompilerIdC\CompilerIdC.exe
PostBuildEvent:
  for %%i in (cl.exe) do @echo CMAKE_C_COMPILER=%%~$PATH:i
  :VCEnd
  CMAKE_C_COMPILER=C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.29.30037\bin\Hostx64\x64\cl.exe
FinalizeBuildStatus:
  Deleting file "Debug\CompilerIdC.tlog\unsuccessfulbuild".
  Touching "Debug\CompilerIdC.tlog\CompilerIdC.lastbuildstate".
Done Building Project "C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\3.21.0-rc2\CompilerIdC\CompilerIdC.vcxproj" (default targets).
Build succeeded.
    0 Warning(s)
    0 Error(s)
Time Elapsed 00:00:02.11
Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "CompilerIdC.exe"
Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "CompilerIdC.vcxproj"
The C compiler identification is MSVC, found in "C:/dev/CGAL-5.2.2/examples/Triangulation_2/build/CMakeFiles/3.21.0-rc2/CompilerIdC/CompilerIdC.exe"
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" succeeded.
Compiler:
Build flags:
Id flags:
The output was:
Build started 7/8/2021 4:03:24 PM.
Project "C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\3.21.0-rc2\CompilerIdCXX\CompilerIdCXX.vcxproj" on node 1 (default targets).
PrepareForBuild:
  Creating directory "Debug\CompilerIdCXX.tlog\".
  Creating "Debug\CompilerIdCXX.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
ClCompile:
  C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.29.30037\bin\HostX64\x64\CL.exe /c /nologo /W0 /WX- /diagnostics:column /Od /D _MBCS /Gm- /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /Zc:inline /Fo"Debug\\" /Fd"Debug\vc142.pdb" /external:env:EXTERNAL_INCLUDE /external:W0 /Gd /TP /FC /errorReport:queue CMakeCXXCompilerId.cpp
Link:
  C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.29.30037\bin\HostX64\x64\link.exe /ERRORREPORT:QUEUE /OUT:".\CompilerIdCXX.exe" /INCREMENTAL:NO /NOLOGO kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /MANIFEST /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /manifest:embed /PDB:".\CompilerIdCXX.pdb" /SUBSYSTEM:CONSOLE /TLBID:1 /DYNAMICBASE /NXCOMPAT /IMPLIB:".\CompilerIdCXX.lib" /MACHINE:X64 Debug\CMakeCXXCompilerId.obj
  CompilerIdCXX.vcxproj -> C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\3.21.0-rc2\CompilerIdCXX\CompilerIdCXX.exe
PostBuildEvent:
  for %%i in (cl.exe) do @echo CMAKE_CXX_COMPILER=%%~$PATH:i
  :VCEnd
  CMAKE_CXX_COMPILER=C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.29.30037\bin\Hostx64\x64\cl.exe
  Deleting file "Debug\CompilerIdCXX.tlog\unsuccessfulbuild".
  Touching "Debug\CompilerIdCXX.tlog\CompilerIdCXX.lastbuildstate".
Done Building Project "C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\3.21.0-rc2\CompilerIdCXX\CompilerIdCXX.vcxproj" (default targets).
Build succeeded.
    0 Warning(s)
    0 Error(s)
Time Elapsed 00:00:02.09
Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "CompilerIdCXX.exe"
Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "CompilerIdCXX.vcxproj"
The CXX compiler identification is MSVC, found in "C:/dev/CGAL-5.2.2/examples/Triangulation_2/build/CMakeFiles/3.21.0-rc2/CompilerIdCXX/CompilerIdCXX.exe"
Detecting C compiler ABI info compiled with the following output:
Change Dir: C:/dev/CGAL-5.2.2/examples/Triangulation_2/build/CMakeFiles/CMakeTmp
Run Build Command(s):C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/MSBuild/Current/Bin/MSBuild.exe cmTC_340fb.vcxproj /p:Configuration=Debug /p:Platform=x64 /p:VisualStudioVersion=16.0 /v:m && Microsoft (R) Build Engine version 16.10.2+857e5a733 for .NET Framework
  Microsoft (R) C/C++ Optimizing Compiler Version 19.29.30038.1 for x64
  CMakeCCompilerABI.c
  cl /c /Zi /W1 /WX- /diagnostics:column /Od /Ob0 /D _MBCS /D WIN32 /D _WINDOWS /D "CMAKE_INTDIR=\"Debug\"" /Gm- /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /Zc:inline /Fo"cmTC_340fb.dir\Debug\\" /Fd"cmTC_340fb.dir\Debug\vc142.pdb" /external:env:EXTERNAL_INCLUDE /external:W1 /Gd /TC /errorReport:queue "C:\Program Files\CMake\share\cmake-3.21\Modules\CMakeCCompilerABI.c"
  cmTC_340fb.vcxproj -> C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\CMakeTmp\Debug\cmTC_340fb.exe
Detecting CXX compiler ABI info compiled with the following output:
Run Build Command(s):C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/MSBuild/Current/Bin/MSBuild.exe cmTC_40015.vcxproj /p:Configuration=Debug /p:Platform=x64 /p:VisualStudioVersion=16.0 /v:m && Microsoft (R) Build Engine version 16.10.2+857e5a733 for .NET Framework
  CMakeCXXCompilerABI.cpp
  cl /c /Zi /W1 /WX- /diagnostics:column /Od /Ob0 /D _MBCS /D WIN32 /D _WINDOWS /D "CMAKE_INTDIR=\"Debug\"" /Gm- /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /Zc:inline /GR /Fo"cmTC_40015.dir\Debug\\" /Fd"cmTC_40015.dir\Debug\vc142.pdb" /external:env:EXTERNAL_INCLUDE /external:W1 /Gd /TP /errorReport:queue "C:\Program Files\CMake\share\cmake-3.21\Modules\CMakeCXXCompilerABI.cpp"
  cmTC_40015.vcxproj -> C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\CMakeTmp\Debug\cmTC_40015.exe
Please let me know what I am doing wrong so I can get this version of CGAL running. I am also happy to download and install Version 5.3 if thta would resolve the issues.
Thank you!
Jeb Gaither
