Hi
CMake encounters errors when I try to do C:\dev\CGAL-5.2.2\examples\Triangulation_2\build> cmake-gui.
The following is the CMake Output from the screen:
The C compiler identification is MSVC 19.29.30038.1
The CXX compiler identification is MSVC 19.29.30038.1
Detecting C compiler ABI info
Detecting C compiler ABI info - done
Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.29.30037/bin/Hostx64/x64/cl.exe - skipped
Detecting C compile features
Detecting C compile features - done
Detecting CXX compiler ABI info
Detecting CXX compiler ABI info - done
Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.29.30037/bin/Hostx64/x64/cl.exe - skipped
Detecting CXX compile features
Detecting CXX compile features - done
Visual Leak Detector (VLD) is not found.
Using header-only CGAL
Targetting Visual Studio 16 2019
Target build enviroment supports auto-linking
Using VC toolset 142.
Generator uses intermediate configuration directory: $(Configuration)
CMake Error at C:/Program Files/CMake/share/cmake-3.21/Modules/FindPackageHandleStandardArgs.cmake:230 (message):
Could NOT find GMP (missing: GMP_LIBRARIES GMP_INCLUDE_DIR)
Call Stack (most recent call first):
C:/Program Files/CMake/share/cmake-3.21/Modules/FindPackageHandleStandardArgs.cmake:594 (_FPHSA_FAILURE_MESSAGE)
C:/dev/vcpkg/installed/x86-windows/share/cgal/FindGMP.cmake:53 (find_package_handle_standard_args)
C:/dev/vcpkg/scripts/buildsystems/vcpkg.cmake:792 (_find_package)
C:/dev/vcpkg/installed/x86-windows/share/cgal/CGAL_SetupGMP.cmake:24 (find_package)
C:/dev/vcpkg/installed/x86-windows/share/cgal/CGAL_SetupCGALDependencies.cmake:41 (include)
C:/dev/vcpkg/installed/x86-windows/share/cgal/CGALConfig.cmake:128 (include)
CMakeLists.txt:16 (find_package)
Configuring incomplete, errors occurred!
See also "C:/dev/CGAL-5.2.2/examples/Triangulation_2/build/CMakeFiles/CMakeOutput.log".
The CMakeOutput.log is:
The system is: Windows - 10.0.19041 - AMD64
Compiling the C compiler identification source file "CMakeCCompilerId.c" succeeded.
Compiler:
Build flags:
Id flags:
The output was:
Microsoft (R) Build Engine version 16.10.2+857e5a733 for .NET Framework
Copyright (C) Microsoft Corporation. All rights reserved.
Build started 7/8/2021 4:03:21 PM.
Project "C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\3.21.0-rc2\CompilerIdC\CompilerIdC.vcxproj" on node 1 (default targets).
PrepareForBuild:
Creating directory "Debug\".
Creating directory "Debug\CompilerIdC.tlog\".
InitializeBuildStatus:
Creating "Debug\CompilerIdC.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
ClCompile:
C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.29.30037\bin\HostX64\x64\CL.exe /c /nologo /W0 /WX- /diagnostics:column /Od /D _MBCS /Gm- /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /Zc:inline /Fo"Debug\\" /Fd"Debug\vc142.pdb" /external:env:EXTERNAL_INCLUDE /external:W0 /Gd /TC /FC /errorReport:queue CMakeCCompilerId.c
CMakeCCompilerId.c
Link:
C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.29.30037\bin\HostX64\x64\link.exe /ERRORREPORT:QUEUE /OUT:".\CompilerIdC.exe" /INCREMENTAL:NO /NOLOGO kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /MANIFEST /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /manifest:embed /PDB:".\CompilerIdC.pdb" /SUBSYSTEM:CONSOLE /TLBID:1 /DYNAMICBASE /NXCOMPAT /IMPLIB:".\CompilerIdC.lib" /MACHINE:X64 Debug\CMakeCCompilerId.obj
CompilerIdC.vcxproj -> C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\3.21.0-rc2\CompilerIdC\CompilerIdC.exe
PostBuildEvent:
for %%i in (cl.exe) do @echo CMAKE_C_COMPILER=%%~$PATH:i
:VCEnd
CMAKE_C_COMPILER=C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.29.30037\bin\Hostx64\x64\cl.exe
FinalizeBuildStatus:
Deleting file "Debug\CompilerIdC.tlog\unsuccessfulbuild".
Touching "Debug\CompilerIdC.tlog\CompilerIdC.lastbuildstate".
Done Building Project "C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\3.21.0-rc2\CompilerIdC\CompilerIdC.vcxproj" (default targets).
Build succeeded.
0 Warning(s)
0 Error(s)
Time Elapsed 00:00:02.11
Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "CompilerIdC.exe"
Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "CompilerIdC.vcxproj"
The C compiler identification is MSVC, found in "C:/dev/CGAL-5.2.2/examples/Triangulation_2/build/CMakeFiles/3.21.0-rc2/CompilerIdC/CompilerIdC.exe"
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" succeeded.
Compiler:
Build flags:
Id flags:
The output was:
Build started 7/8/2021 4:03:24 PM.
Project "C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\3.21.0-rc2\CompilerIdCXX\CompilerIdCXX.vcxproj" on node 1 (default targets).
PrepareForBuild:
Creating directory "Debug\CompilerIdCXX.tlog\".
Creating "Debug\CompilerIdCXX.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
ClCompile:
C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.29.30037\bin\HostX64\x64\CL.exe /c /nologo /W0 /WX- /diagnostics:column /Od /D _MBCS /Gm- /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /Zc:inline /Fo"Debug\\" /Fd"Debug\vc142.pdb" /external:env:EXTERNAL_INCLUDE /external:W0 /Gd /TP /FC /errorReport:queue CMakeCXXCompilerId.cpp
Link:
C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.29.30037\bin\HostX64\x64\link.exe /ERRORREPORT:QUEUE /OUT:".\CompilerIdCXX.exe" /INCREMENTAL:NO /NOLOGO kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /MANIFEST /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /manifest:embed /PDB:".\CompilerIdCXX.pdb" /SUBSYSTEM:CONSOLE /TLBID:1 /DYNAMICBASE /NXCOMPAT /IMPLIB:".\CompilerIdCXX.lib" /MACHINE:X64 Debug\CMakeCXXCompilerId.obj
CompilerIdCXX.vcxproj -> C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\3.21.0-rc2\CompilerIdCXX\CompilerIdCXX.exe
PostBuildEvent:
for %%i in (cl.exe) do @echo CMAKE_CXX_COMPILER=%%~$PATH:i
:VCEnd
CMAKE_CXX_COMPILER=C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.29.30037\bin\Hostx64\x64\cl.exe
Deleting file "Debug\CompilerIdCXX.tlog\unsuccessfulbuild".
Touching "Debug\CompilerIdCXX.tlog\CompilerIdCXX.lastbuildstate".
Done Building Project "C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\3.21.0-rc2\CompilerIdCXX\CompilerIdCXX.vcxproj" (default targets).
Build succeeded.
0 Warning(s)
0 Error(s)
Time Elapsed 00:00:02.09
Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "CompilerIdCXX.exe"
Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "CompilerIdCXX.vcxproj"
The CXX compiler identification is MSVC, found in "C:/dev/CGAL-5.2.2/examples/Triangulation_2/build/CMakeFiles/3.21.0-rc2/CompilerIdCXX/CompilerIdCXX.exe"
Detecting C compiler ABI info compiled with the following output:
Change Dir: C:/dev/CGAL-5.2.2/examples/Triangulation_2/build/CMakeFiles/CMakeTmp
Run Build Command(s):C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/MSBuild/Current/Bin/MSBuild.exe cmTC_340fb.vcxproj /p:Configuration=Debug /p:Platform=x64 /p:VisualStudioVersion=16.0 /v:m && Microsoft (R) Build Engine version 16.10.2+857e5a733 for .NET Framework
Microsoft (R) C/C++ Optimizing Compiler Version 19.29.30038.1 for x64
CMakeCCompilerABI.c
cl /c /Zi /W1 /WX- /diagnostics:column /Od /Ob0 /D _MBCS /D WIN32 /D _WINDOWS /D "CMAKE_INTDIR=\"Debug\"" /Gm- /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /Zc:inline /Fo"cmTC_340fb.dir\Debug\\" /Fd"cmTC_340fb.dir\Debug\vc142.pdb" /external:env:EXTERNAL_INCLUDE /external:W1 /Gd /TC /errorReport:queue "C:\Program Files\CMake\share\cmake-3.21\Modules\CMakeCCompilerABI.c"
cmTC_340fb.vcxproj -> C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\CMakeTmp\Debug\cmTC_340fb.exe
Detecting CXX compiler ABI info compiled with the following output:
Run Build Command(s):C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/MSBuild/Current/Bin/MSBuild.exe cmTC_40015.vcxproj /p:Configuration=Debug /p:Platform=x64 /p:VisualStudioVersion=16.0 /v:m && Microsoft (R) Build Engine version 16.10.2+857e5a733 for .NET Framework
CMakeCXXCompilerABI.cpp
cl /c /Zi /W1 /WX- /diagnostics:column /Od /Ob0 /D _MBCS /D WIN32 /D _WINDOWS /D "CMAKE_INTDIR=\"Debug\"" /Gm- /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /Zc:inline /GR /Fo"cmTC_40015.dir\Debug\\" /Fd"cmTC_40015.dir\Debug\vc142.pdb" /external:env:EXTERNAL_INCLUDE /external:W1 /Gd /TP /errorReport:queue "C:\Program Files\CMake\share\cmake-3.21\Modules\CMakeCXXCompilerABI.cpp"
cmTC_40015.vcxproj -> C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\CMakeTmp\Debug\cmTC_40015.exe
Please let me know what I am doing wrong so I can get this version of CGAL running. I am also happy to download and install Version 5.3 if thta would resolve the issues.
Thank you!
Jeb Gaither
