cgal-discuss - RE: [cgal-discuss] CMake Problem Installing CGAL 5.2.2
  • To: <>
  • Subject: RE: [cgal-discuss] CMake Problem Installing CGAL 5.2.2
  • Date: Wed, 14 Jul 2021 20:49:04 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-hdrordr: A9a23:lUDk3qOOy577DcBcThyjsMiBIKoaSvp037BZ7TELdfU1SL3/qynApoV/6faZslgssTQb6LO90cq7MBThHPxOkO0s1N6ZNWGM0gSVxcNZjbcKqAeQeREWg9QtrZuIHZIeNPTASXBnkMf35xS5Gd48zNTCzICE7N2z854Ud3ASV4hQqzpSMz22NmtKaCl+bKBVKKah
  • Ironport-phdr: A9a23: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
Hi again.
I followed the directions and downloaded the vcpkg without any issues.
I have also seen some info online that not all vcpkg updates work the same way.
Therefore I started over and followed the 5.3 Section 2 directions that do not use vcpkg.
The process was straight forward. I tried the Arrangement_on_sufrace_2 examples because that is the CGAL of most interest to me. CMake indicated that everything was okay and that it found the gmp, mpfr and boost libraries. Visual studio built the Solution just fine with no errors or unusual messages.
However, when I tried to execute the Bezier_Curves .exe, Visual Studio indicated it could not find the gmp library libgmp-10.lib, even though CMake indicated it found that library during configuration..
Any suggestions to solve this issue would be greatly appreciated.
Thank you!
Jeb Gaither
From: [mailto:] On Behalf Of Maxime Gimeno ( via cgal-discuss Mailing List)
Sent: Monday, July 12, 2021 3:45 AM
To:
Subject: Re: [cgal-discuss] CMake Problem Installing CGAL 5.2.2
It gets stranger and stranger. Did you maybe update your vcpkg ?
Le sam. 10 juil. 2021 à 23:36, Jeb Gaither <> a écrit :
Thank you Maxime.
I am using Section 1 of the CGAL 5.2.2 Instructions for Windows.
Today I tried manually entering the directory and file name information into CMake manually for GMP, MPFR ,etc which corrected  up to the point that CMake indicated that the version of Boost was not correct.
At that point, I decided to delete everything and start over using CGAL 5.3 following the directions in Section 1 of the 5.3 Instructions for Windows. Now the situation is worse. When I try to install yasm-tool or cgal, I get a "Computing Installation Plan" message with no installation taking place.
A possible cause for this may be my virus protection, McAfee Live Safe. It has real-time scanning turned off so it won't delete .exe files but perhaps it is interfering in some way.
Appreciate whatever assistance you can provide.
Jeb Gaither
Sent: Friday, July 09, 2021 4:04 AM
To:
Hello,
It seems you are missing GMP. Did you follow the instructions at https://doc.cgal.org/latest/Manual/windows.html#ssec-vcpk-install-cgal ?
Le jeu. 8 juil. 2021 à 23:06, Jeb Gaither <> a écrit :
Hi
CMake encounters errors when I try to do C:\dev\CGAL-5.2.2\examples\Triangulation_2\build> cmake-gui.
The following is the CMake Output from the screen:
The C compiler identification is MSVC 19.29.30038.1
The CXX compiler identification is MSVC 19.29.30038.1
Detecting C compiler ABI info
Detecting C compiler ABI info - done
Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.29.30037/bin/Hostx64/x64/cl.exe - skipped
Detecting C compile features
Detecting C compile features - done
Detecting CXX compiler ABI info
Detecting CXX compiler ABI info - done
Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.29.30037/bin/Hostx64/x64/cl.exe - skipped
Detecting CXX compile features
Detecting CXX compile features - done
Visual Leak Detector (VLD) is not found.
Using header-only CGAL
Targetting Visual Studio 16 2019
Target build enviroment supports auto-linking
Using VC toolset 142.
Generator uses intermediate configuration directory: $(Configuration)
CMake Error at C:/Program Files/CMake/share/cmake-3.21/Modules/FindPackageHandleStandardArgs.cmake:230 (message):
  Could NOT find GMP (missing: GMP_LIBRARIES GMP_INCLUDE_DIR)
Call Stack (most recent call first):
  C:/Program Files/CMake/share/cmake-3.21/Modules/FindPackageHandleStandardArgs.cmake:594 (_FPHSA_FAILURE_MESSAGE)
  C:/dev/vcpkg/installed/x86-windows/share/cgal/FindGMP.cmake:53 (find_package_handle_standard_args)
  C:/dev/vcpkg/scripts/buildsystems/vcpkg.cmake:792 (_find_package)
  C:/dev/vcpkg/installed/x86-windows/share/cgal/CGAL_SetupGMP.cmake:24 (find_package)
  C:/dev/vcpkg/installed/x86-windows/share/cgal/CGAL_SetupCGALDependencies.cmake:41 (include)
  C:/dev/vcpkg/installed/x86-windows/share/cgal/CGALConfig.cmake:128 (include)
  CMakeLists.txt:16 (find_package)
Configuring incomplete, errors occurred!
See also "C:/dev/CGAL-5.2.2/examples/Triangulation_2/build/CMakeFiles/CMakeOutput.log".
The CMakeOutput.log is:
The system is: Windows - 10.0.19041 - AMD64
Compiling the C compiler identification source file "CMakeCCompilerId.c" succeeded.
Compiler:
Build flags:
Id flags:
The output was:
Microsoft (R) Build Engine version 16.10.2+857e5a733 for .NET Framework
Copyright (C) Microsoft Corporation. All rights reserved.
Build started 7/8/2021 4:03:21 PM.
Project "C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\3.21.0-rc2\CompilerIdC\CompilerIdC.vcxproj" on node 1 (default targets).
PrepareForBuild:
  Creating directory "Debug\".
  Creating directory "Debug\CompilerIdC.tlog\".
InitializeBuildStatus:
  Creating "Debug\CompilerIdC.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
ClCompile:
  C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.29.30037\bin\HostX64\x64\CL.exe /c /nologo /W0 /WX- /diagnostics:column /Od /D _MBCS /Gm- /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /Zc:inline /Fo"Debug\\" /Fd"Debug\vc142.pdb" /external:env:EXTERNAL_INCLUDE /external:W0 /Gd /TC /FC /errorReport:queue CMakeCCompilerId.c
  CMakeCCompilerId.c
Link:
  C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.29.30037\bin\HostX64\x64\link.exe /ERRORREPORT:QUEUE /OUT:".\CompilerIdC.exe" /INCREMENTAL:NO /NOLOGO kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /MANIFEST /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /manifest:embed /PDB:".\CompilerIdC.pdb" /SUBSYSTEM:CONSOLE /TLBID:1 /DYNAMICBASE /NXCOMPAT /IMPLIB:".\CompilerIdC.lib" /MACHINE:X64 Debug\CMakeCCompilerId.obj
  CompilerIdC.vcxproj -> C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\3.21.0-rc2\CompilerIdC\CompilerIdC.exe
PostBuildEvent:
  for %%i in (cl.exe) do @echo CMAKE_C_COMPILER=%%~$PATH:i
  :VCEnd
  CMAKE_C_COMPILER=C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.29.30037\bin\Hostx64\x64\cl.exe
FinalizeBuildStatus:
  Deleting file "Debug\CompilerIdC.tlog\unsuccessfulbuild".
  Touching "Debug\CompilerIdC.tlog\CompilerIdC.lastbuildstate".
Done Building Project "C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\3.21.0-rc2\CompilerIdC\CompilerIdC.vcxproj" (default targets).
Build succeeded.
    0 Warning(s)
    0 Error(s)
Time Elapsed 00:00:02.11
Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "CompilerIdC.exe"
Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "CompilerIdC.vcxproj"
The C compiler identification is MSVC, found in "C:/dev/CGAL-5.2.2/examples/Triangulation_2/build/CMakeFiles/3.21.0-rc2/CompilerIdC/CompilerIdC.exe"
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" succeeded.
Compiler:
Build flags:
Id flags:
The output was:
Build started 7/8/2021 4:03:24 PM.
Project "C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\3.21.0-rc2\CompilerIdCXX\CompilerIdCXX.vcxproj" on node 1 (default targets).
PrepareForBuild:
  Creating directory "Debug\CompilerIdCXX.tlog\".
  Creating "Debug\CompilerIdCXX.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
ClCompile:
  C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.29.30037\bin\HostX64\x64\CL.exe /c /nologo /W0 /WX- /diagnostics:column /Od /D _MBCS /Gm- /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /Zc:inline /Fo"Debug\\" /Fd"Debug\vc142.pdb" /external:env:EXTERNAL_INCLUDE /external:W0 /Gd /TP /FC /errorReport:queue CMakeCXXCompilerId.cpp
Link:
  C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.29.30037\bin\HostX64\x64\link.exe /ERRORREPORT:QUEUE /OUT:".\CompilerIdCXX.exe" /INCREMENTAL:NO /NOLOGO kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /MANIFEST /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /manifest:embed /PDB:".\CompilerIdCXX.pdb" /SUBSYSTEM:CONSOLE /TLBID:1 /DYNAMICBASE /NXCOMPAT /IMPLIB:".\CompilerIdCXX.lib" /MACHINE:X64 Debug\CMakeCXXCompilerId.obj
  CompilerIdCXX.vcxproj -> C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\3.21.0-rc2\CompilerIdCXX\CompilerIdCXX.exe
PostBuildEvent:
  for %%i in (cl.exe) do @echo CMAKE_CXX_COMPILER=%%~$PATH:i
  :VCEnd
  CMAKE_CXX_COMPILER=C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.29.30037\bin\Hostx64\x64\cl.exe
  Deleting file "Debug\CompilerIdCXX.tlog\unsuccessfulbuild".
  Touching "Debug\CompilerIdCXX.tlog\CompilerIdCXX.lastbuildstate".
Done Building Project "C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\3.21.0-rc2\CompilerIdCXX\CompilerIdCXX.vcxproj" (default targets).
Build succeeded.
    0 Warning(s)
    0 Error(s)
Time Elapsed 00:00:02.09
Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "CompilerIdCXX.exe"
Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "CompilerIdCXX.vcxproj"
The CXX compiler identification is MSVC, found in "C:/dev/CGAL-5.2.2/examples/Triangulation_2/build/CMakeFiles/3.21.0-rc2/CompilerIdCXX/CompilerIdCXX.exe"
Detecting C compiler ABI info compiled with the following output:
Change Dir: C:/dev/CGAL-5.2.2/examples/Triangulation_2/build/CMakeFiles/CMakeTmp
Run Build Command(s):C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/MSBuild/Current/Bin/MSBuild.exe cmTC_340fb.vcxproj /p:Configuration=Debug /p:Platform=x64 /p:VisualStudioVersion=16.0 /v:m && Microsoft (R) Build Engine version 16.10.2+857e5a733 for .NET Framework
  Microsoft (R) C/C++ Optimizing Compiler Version 19.29.30038.1 for x64
  CMakeCCompilerABI.c
  cl /c /Zi /W1 /WX- /diagnostics:column /Od /Ob0 /D _MBCS /D WIN32 /D _WINDOWS /D "CMAKE_INTDIR=\"Debug\"" /Gm- /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /Zc:inline /Fo"cmTC_340fb.dir\Debug\\" /Fd"cmTC_340fb.dir\Debug\vc142.pdb" /external:env:EXTERNAL_INCLUDE /external:W1 /Gd /TC /errorReport:queue "C:\Program Files\CMake\share\cmake-3.21\Modules\CMakeCCompilerABI.c"
  cmTC_340fb.vcxproj -> C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\CMakeTmp\Debug\cmTC_340fb.exe
Detecting CXX compiler ABI info compiled with the following output:
Run Build Command(s):C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/MSBuild/Current/Bin/MSBuild.exe cmTC_40015.vcxproj /p:Configuration=Debug /p:Platform=x64 /p:VisualStudioVersion=16.0 /v:m && Microsoft (R) Build Engine version 16.10.2+857e5a733 for .NET Framework
  CMakeCXXCompilerABI.cpp
  cl /c /Zi /W1 /WX- /diagnostics:column /Od /Ob0 /D _MBCS /D WIN32 /D _WINDOWS /D "CMAKE_INTDIR=\"Debug\"" /Gm- /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /Zc:inline /GR /Fo"cmTC_40015.dir\Debug\\" /Fd"cmTC_40015.dir\Debug\vc142.pdb" /external:env:EXTERNAL_INCLUDE /external:W1 /Gd /TP /errorReport:queue "C:\Program Files\CMake\share\cmake-3.21\Modules\CMakeCXXCompilerABI.cpp"
  cmTC_40015.vcxproj -> C:\dev\CGAL-5.2.2\examples\Triangulation_2\build\CMakeFiles\CMakeTmp\Debug\cmTC_40015.exe
Please let me know what I am doing wrong so I can get this version of CGAL running. I am also happy to download and install Version 5.3 if thta would resolve the issues.
Thank you!
Jeb Gaither
