cgal-discuss - RE: [cgal-discuss] Speeding Up Arrangement Insertion
  • To: "" <>
  • Subject: RE: [cgal-discuss] Speeding Up Arrangement Insertion
  • Date: Fri, 5 Nov 2021 11:39:46 +0000
  • Accept-language: pt-BR, en-US
  • Arc-authentication-results: i=1; mx.microsoft.com 1; spf=none; dmarc=none; dkim=none; arc=none
  • Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-AntiSpam-MessageData-ChunkCount:X-MS-Exchange-AntiSpam-MessageData-0:X-MS-Exchange-AntiSpam-MessageData-1; bh=1tsugVeYuiK7wu7FPr7o0bHnBtAW5tzGni0lxHU9FOY=; b=V297FLIZ5R6q9EVo/W9kVRbC9Owgx0+DZlIL9ES5QtbF5HfKKKApes9hF3CeACbpSgTF0+5qvh5VMia4VNW3ND8M4+snDvr/06G84sicJgmvijgquKxdsQNqjRNsTgHh/upHWDZMAdaBU2JsD9TxKVQAJ5V/snPjgwTckfL2uUnK2laRUCyIhhqd3vwS75nYh7gUpspUiVT8/XkRqz1dz1XW3VSdi++g2wHrUkXFiovpbXqtM67vjNB+rSh1lcN4TnjTxqvDWbetBFv7fEy/uRn2eTcbLqS+uWp50kJi3VB/IO87SPPP89lV8uVHGx+HwZnMb4TQHcvkUndb3410rA==
  • Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=guvnBaxvolhbAWhYfvSlcuMcgHIdctaVkHhEy27SpKSuJoOJvxGTe0t2RT4NdfYGOWD755A89p3np5WyOOdE3mb26tF61TBh6eRk1FpxwTxnC7zOOg6o7Y0aVZaT3F+u8VjbLU17BrypSYYBfXUxqvd01gRFdOORQjROOFmxtVDFqAGCwsJFGERTfgPuXO/gt0hHJo3FepwZrr18skukgnGP0v7x8HdDPFSQHdhQk43iAV+f8Pwnicam7aiigXeHfGSXXuKYstl0VDwFFXIYV7aqeb1Phj9rcC/hlLYNSvpdO7NnPa31nnn7ucFcEYlBf+TzMCza6BSQrqkKo2iQ+g==
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
  • Ironport-data: A9a23:b6oKP6x/GbdZr64b7bN6t+f3xyrEfRIJ4+MujC/XYbTApDp2hjZTyWNLXmyGb6zcNmCke94ja47j9EJS7Z/SnNRgOVdlrnsFo1Bi+ZOUX4zBRqvTF3rPdZObFBoPA/3z27AsFehsJpPnjkrrYueJQUVUj/nSH+OlULOcYEideCc9IMsfoUI78wIGqtUw6TSJK1vlVeLa+6UzCnf9s9JHGj58B5a4lf9alK+aVAX0EbAJTasjUFf2zxH5BX+ETE27ByOQroJ8RoZWSwtfpYxV8F81/z91Yj+kupDSVxRTB5L3Y02JgHcQXLW+iB9foCB0yrw8KPcXdUZQjXOOgsx1z9JO85e3TG/FPIWQwKJMCV8BQmckZcWq+5efSZS7mcaJ0kvBRGHlxvBpCgc4OYQw+uFrBGhP8boTLzVlghWr3bvpmOzkEYGAgex4dZKwY+vzoEpIxj7QCbMqQIvIXr7RzcRJ2S85wMFIB/fXIcQDAQeDxjzUO0gUfAoDUcdm2r+83CynNWcF9gyB/v9vpTXHk1lYzpzGNfz5evirTONphGCmp0fSpjysW0lebYCLodae2nelh+uKkSalXosXTeS/8v1s2gXJnioUFQEcUka9rb+hkEmiVtlDKksSvC0zsaw180/tRd74NyBUaUWs5nY0M+e82cVjgO1M9kbV3+pdLk4ta2cYLfAD6ooxTzFs0UKVldT0AzApqKeSVX+W6raTq3W1JDQRKmgBIyQDSGPpJvH99ZorgEunoslLScaIYh/dQFkcAAxmaAA+gKkWhM8Pka68+DgrRhqy84PRQFddChr/BwqYA8AQWGJhT4yv9V3S7PIGJ4GcJrVElBDohODGhN0z4VqxeOBhjQnD8HxFJxpIDdEEvWNSIg==
  • Ironport-hdrordr: A9a23:OVg31anwL12kZGVgy6drpltGLgXpDfIn3DAbv31ZSRFFG/FwWfre/8jzpiWUtN9xYhodcL+7VZVoLUmskKKdpLNhWYtKPzOLhILLFutfBOLZqlXd8m/Fh4xgPMxbHZSWZueRMbE3t6nH3DU=
  • Ironport-phdr: A9a23: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
  • Suggested_attachment_session_id: 3d7ed8ab-ee83-362d-feb5-5c3b22e79084
Just sending the code once again with some small changes:
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include <CGAL/Arr_naive_point_location.h>
#include <CGAL/Arr_non_caching_segment_basic_traits_2.h>
#include <CGAL/Segment_2.h>
#include <CGAL/Arr_segment_traits_2.h>
#include <CGAL/Arrangement_2.h>
#include <CGAL/Delaunay_triangulation_2.h>
#include <CGAL/Constrained_Delaunay_triangulation_2.h>
typedef CGAL::Exact_predicates_exact_constructions_kernel                       K1;
typedef CGAL::Arr_segment_traits_2<K1>                                          Traits_2;
typedef CGAL::Arrangement_2<Traits_2>                                           Arrangement_2;
typedef CGAL::Delaunay_triangulation_2<K1>                                      Delaunay2;
typedef CGAL::Constrained_Delaunay_triangulation_2<K1, CGAL::Default, Itag>     CDT2;
typedef Traits_2::Point_2                                                       Point_2;
typedef Traits_2::X_monotone_curve_2                                            Segment_2;
typedef CGAL::Arr_naive_point_location<Arrangement_2>                           WalkPL_2;
int main()
    ExternalDataSet datas("data1.txt","data2.txt");
    Arrangement_2 arr;
    WalkPL_2 walkPL(arr);
    // first step of insertions
    std::chrono::steady_clock::time_point begin = std::chrono::steady_clock::now();
    std::vector<Segment_2> segmentSet1 = datas.externalData(0);
    CGAL::insert_non_intersecting_curves(arr, segmentSet1.begin(), segmentSet1.end());
    segmentSet1.clear();
    std::chrono::steady_clock::time_point end = std::chrono::steady_clock::now();
    if (verbose) std::cout << "Time spent - First Insertion: " << std::setprecision(6) << std::chrono::duration_cast<std::chrono::microseconds>(end - begin).count()/1.0e+6 << std::fixed << " sec." << std::endl;
    //Second step of insertions
    std::vector<Segment_2> segmentSet2 = datas.externalData(1);
    // #pragma omp parallel for if(_parallelOptimization)
    for(auto seg = segmentSet2.begin(); seg < segmentSet2.end(); ++seg)
        CGAL::insert(arr, *seg, walkPL);
    segmentSet2.clear();
    if (verbose) std::cout << "Time spent - Second Insertion: " << std::setprecision(6) << std::chrono::duration_cast<std::chrono::microseconds>(end - begin).count()/1.0e+6 << std::fixed << " sec." << std::endl;
    CDT2 cdt;
    // Constrained Delaunay package to triangulate the arrangement
    for (auto it = arr.edges_begin(); it != arr.edges_end(); ++it) {
        cdt.insert(it->source()->point(), it->target()->point());
    if (verbose) std::cout << "Time spent - Creation of the Constrained Delaunay Triangulation: " << std::setprecision(6) << std::chrono::duration_cast<std::chrono::microseconds>(end - begin).count()/1.0e+6 << std::fixed << " sec." << std::endl;
Att,
Bruno Rammon Silva Souza
De: Bruno Silva
Enviado: sexta-feira, 5 de novembro de 2021 06:20
Para: <>
Assunto: Speeding Up Arrangement Insertion
Hi everyone,
I'm having a problem with efficiency when computing arrangements by CGAL. Thus, I would like to know whether there's any way to improve the efficiency of this.
The code is:
int main()
    segmentSet1.clear();std::chrono::steady_clock::time_point
    // Insertion of the second set of segments
    // #pragma omp parallel for //Parllellization is not working!!
    for(auto seg = segments1.begin(); seg < segments1.end(); ++seg)
    // Section 2 - It is using the constrained Delaunay package to triangulate the arrangement vertices and constrained edges
        CDT.insert(it->source()->point(), it->target()->point());
I have two distinct sets of segments (std::vector<Segment_2> segmentSet1 and std::vector<Segment_2> segmentSet2 ) that comes up from external data. The segments in segmentSet1 don't intersect with others segments in this set. This is also true for the segments in segmentSet2. However, the segments in segmentSet1 certainly intersects with the segments in segmentSet2.
I insert the first set of segments by the function CGAL::insert_non_intersecting_curves(arr, segmentSet1.begin(), segmentSet1.end()). The insertions of the second set of segments are performed by the function CGAL::insert(arr, *seg, walkPL). The efficiency first intersection is pretty good, but the second one is very inefficient. After these insertions, a Constrained Delaunay Triangulation is created.
I would like to know whether there is a way to improve the efficiency of this second insection. I've tried without success to perform a parallelization of the loop in the second insertion.
Is there any way to parallelize this for-loop for the second insertion? Or should I try another approach to improve the overall efficiency?
Best,
Bruno Souza
