- To:
- Subject: Re: [cgal-discuss] Speeding Up Arrangement Insertion
- Date: Fri, 5 Nov 2021 13:46:21 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-data: A9a23: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
- Ironport-hdrordr: A9a23:IfeYFqNzJU+ujsBcThijsMiBIKoaSvp037BL7TENdfUxSKelfq+V/cjzqiWE7gr5NEtNpTnCAtj4fZqkz+8P3WBJB8bZYOCEghrVEGgB1+vfKlTbckWVygc678hdmsNFZeEYY2IVsS6GiDPIa+rIFOP3kpxB+Y/lvhBQpHlRGsJdBvBCe2Km++RNNWx7OaY=
- Ironport-phdr: A9a23:1+AaahW2qqVxKbHDLBnBafBq3KzV8Kx7UjF92vMcY1JmTK2v8tzYMVDF4r011RmVB9yds68P0rCP++C4ACpcu87H6ChDOLV3FDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3OgV6PPn6FZDPhMqrye+y54fTYwJVjzahfL9+Nhq7oRvMusUMnYdvKqk9xgbXrndVZu9awX9kKU+Jkxvz+Mu84IRv/zhMt/4k6sVNTbj0c6MkQLJCET8oKXo15MrltRnCSQuA+H4RWXgInxRLHgbI8gj0Uo/+vSXmuOV93jKaPdDtQrAvRTui9aZrRwT2hyoBKjU07XvYis10jKJcvRKhuxlyyJPabY2JKPZzeL7WcNUHTmRDQ8lRTTRMDJ6iYYsBD+QPPuhWoIfyqFQMsRSzHgasCP/1xzJUmnP706033uI8Gg/GxgwgGNcOvWzVotXoNacSVeS1w7PVzTXGcfxdxDnz55LNchAgu/6MW69/etfWxEkgCgPFj1GQqYj/MDOI0+QCrXKX4Pd6WuKqim4osQdxrSW0y8coi4nJnIMVykve+SplxoY1P8a4RFR1Yd6+CZZdsTyROIRqTM04WW5opDo6xaMcuZ69ZCUHxpUqyhrQZvGbc4aG7BLuWPiPLTl4hH9oerKyiwuv/EavxODyWMm53EpFoydHjtXAqnAD2wLS58SZRfVw8EWs1DCS3A7d7eFEJFo7lavdK5M53rEwmYAcsUDZEi/xgkX2g7eadkol+ui06+Tnf67pqoWAOI9zjwHyKqUumsqlAeQ5KAcCRWab+f6k2LL/+035Wq5Kguc4kqnDtp3ROMcVprahDgNI3Isu5AyzAym73NkXh3ULMVFIdRGdg4T0NFzDIvb1BuqljVu2ijdk3fXGM6XhAprTKnjDl6/scqp8605H0goz1tVf545MCrwOOv7zR0nxtN3GDhMgNwy1w+HnCNNg2o8EV2KPGLeVMKLUsVCW+uIiO/SAaYEatTrnNfQp+vHjgWUklVIefqSlx4YbZX+6E/h+JkWWe3vsgtMPEWcQuQo+SfTniFKfUT5SY3ayW7gz5iw+CI24F4vMW5qigLmA3CihGJ1Ze3tLClSNEXfydoWEQO0AZz6UIs97iTwIT7ahS5U52RG0qAD606ZnLvbT+iAAqZ3j28J65+nKmR4v9Dx0FNiS03yWT2FvhW4IXD833KVnoUNn0FuD0K54g+ZZFdNJ/f9JXB06ZtbhyfdnAYXyRh7ZZYXOD023R82vRzA3VNM4hdEUJF1sHs2ryRHF0S3tCLAck/mHBYc/77nHjEX3PNt362rD0Pwhk0U+WZkIcna3g7Z2sQnVHY/A1UuD0L27cLwVmy/L+mDExmWHuARUURV7TL7eDk0ZfVbckdnp+hbCU6O2EuZgdRBQzNaLbKpMcNzgy1tcA+zyPczXJGO3lWD3DhmBwvaAbZHhZn4GjxnaXUMLmgRW8XedPhUlHQ+gpXjfBXpgDwHBeUTppMZjqXe/R1IxwkmmZkhg3ry5skoamP2YT/oO279CtC4kqjxyEH653sjXEJyLoRB6OqtGN4BuqGxb3H7U4lQudqerKLpv0wZ2m+Ffu0L01g4xAYNaio4ktiFypOKdAaaZylJaMTiex4u2NKeFcwEaHTikarXMwVTCyIrQ56EO9rE8ulLl5UenDBh6m0g=
Hi Bruno;
Instead of inserting each segment successively, insert them "simultaneously" using the following insert free function:
https://doc.cgal.org/latest/Arrangement_on_surface_2/group__PkgArrangementOnSurface2Insert.html#ga744ea4ef5e40e521af139e106b6480f8
The complexity of the global method is almost in O(nlogn), while it is O(n^2) for the other solution.
cf. also https://doc.cgal.org/latest/Arrangement_on_surface_2/index.html#title68
Best
Guillaume
Le 05/11/2021 à 13:37, Bruno Silva a écrit :
Hi Andreas,
Best
Guillaume
Now, I've put this code on gist.github.com:
https://gist.github.com/BrunoRammon/c2850f4aef513571ba27e69773c5d3eb
arrangementInsertion.cpp
GitHub Gist: instantly share code, notes, and
snippets.
gist.github.com
Best,
Bruno
De:
em nome de Andreas Fabri
Enviado: sexta-feira, 5 de novembro de 2021 06:51
Para: Bruno Silva ( via cgal-discuss Mailing List)
Assunto: Re: [cgal-discuss] Speeding Up Arrangement Insertion
Hello,
Ideally, you put code on gist.github.com
Best,
Andreas
On 11/5/2021 12:39 PM, Bruno
Silva ( via
cgal-discuss Mailing List) wrote:
Just sending the code once again with some small changes:
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include <CGAL/Arr_naive_point_location.h>
#include <CGAL/Arr_non_caching_segment_basic_traits_2.h>
#include <CGAL/Segment_2.h>
#include <CGAL/Arr_segment_traits_2.h>
#include <CGAL/Arrangement_2.h>
#include <CGAL/Delaunay_triangulation_2.h>
#include <CGAL/Constrained_Delaunay_triangulation_2.h>
typedef CGAL::Exact_predicates_exact_constructions_kernel
K1;
typedef CGAL::Arr_segment_traits_2<K1>
Traits_2;
typedef CGAL::Arrangement_2<Traits_2>
Arrangement_2;
typedef CGAL::Delaunay_triangulation_2<K1>
Delaunay2;
typedef CGAL::Constrained_Delaunay_triangulation_2<K1,
CGAL::Default,
Itag> CDT2;
typedef Traits_2::Point_2
Point_2;
typedef Traits_2::X_monotone_curve_2
Segment_2;
typedef CGAL::Arr_naive_point_location<Arrangement_2>
WalkPL_2;
int main()
ExternalDataSet datas("data1.txt","data2.txt");
Arrangement_2 arr;
WalkPL_2 walkPL(arr);
// first step of
insertions
std::chrono::steady_clock::time_point
begin =
std::chrono::steady_clock::now();
std::vector<Segment_2>
segmentSet1 =
datas.externalData(0);
CGAL::insert_non_intersecting_curves(arr,
segmentSet1.begin(),
segmentSet1.end());
segmentSet1.clear();
end =
if (verbose)
std::cout
<< "Time
spent - First Insertion: " <<
std::setprecision(6) <<
std::chrono::duration_cast<std::chrono::microseconds>(end
- begin).count()/1.0e+6 <<
std::fixed
<< " sec." <<
std::endl;
//Second step of
insertions
begin = std::chrono::steady_clock::now();
segmentSet2 =
datas.externalData(1);
// #pragma omp
parallel for if(_parallelOptimization)
for(auto seg =
segmentSet2.begin();
seg <
segmentSet2.end(); ++seg)
CGAL::insert(arr, *seg,
walkPL);
segmentSet2.clear();
end = std::chrono::steady_clock::now();
if (verbose)
std::cout
<< "Time
spent - Second Insertion: " <<
std::fixed
<< " sec." <<
std::endl;
CDT2 cdt;
// Constrained
Delaunay package to triangulate the arrangement
for (auto it =
arr.edges_begin();
it != arr.edges_end(); ++it) {
cdt.insert(it->source()->point(),
it->target()->point());
if (verbose)
std::cout
<< "Time
spent - Creation of the Constrained Delaunay
Triangulation: " <<
std::fixed
<< " sec." <<
std::endl;
Att,
Bruno Rammon Silva Souza
De: Bruno Silva
Enviado: sexta-feira, 5 de novembro de 2021 06:20
Para: <>
Assunto: Speeding Up Arrangement Insertion
Para: <>
I'm having a problem with efficiency when computing
arrangements by CGAL. Thus, I would like to know whether
there's any way to improve the efficiency of this.
The code is:
K1;
Traits_2;
Arrangement_2;
Delaunay2;
CGAL::Default,
Itag> CDT2;
Point_2;
Segment_2;
WalkPL_2;
int main()
begin =
segmentSet1 =
segmentSet1.end());
segmentSet1.clear();std::chrono::steady_clock::time_point
if (verbose)
std::cout
<< "Time
std::fixed
<< " sec." <<
std::endl;
// Insertion
of the second set of segments
segmentSet2 =
// #pragma omp
parallel for //Parllellization is not working!!
for(auto seg =
segments1.begin();
seg <
segments1.end(); ++seg)
CGAL::insert(arr, *seg, walkPL);
if (verbose)
std::cout
<< "Time
std::fixed
<< " sec." <<
std::endl;
// Section 2 - It
is using the constrained Delaunay package to
triangulate the arrangement vertices and constrained
edges
for (auto it =
arr.edges_begin();
it !=
CDT.insert(it->source()->point(),
if (verbose)
std::cout
<< "Time
Triangulation: " <<
std::fixed
<< " sec." <<
std::endl;
}I have two distinct sets of segments
(std::vector<Segment_2> segmentSet1 and
std::vector<Segment_2> segmentSet2 ) that comes up
from external data. The segments in segmentSet1 don't
intersect with others segments in this set. This is also
true for the segments in segmentSet2. However, the
segments in segmentSet1 certainly intersects with the
I insert the first set of segments by the function
segmentSet1.begin(), segmentSet1.end()). The insertions of
the second set of segments are performed by the function
CGAL::insert(arr, *seg, walkPL). The efficiency first
intersection is pretty good, but the second one is very
inefficient. After these insertions, a Constrained
Delaunay Triangulation is created.
I would like to know whether there is a way to improve
the efficiency of this second insection. I've tried
without success to perform a parallelization of the loop
in the second insertion.
Is there any way to parallelize this for-loop for the
second insertion? Or should I try another approach to
improve the overall efficiency?
Best,
Bruno Souza
-- Andreas Fabri, PhD Chief Officer, GeometryFactory Editor, The CGAL Project
-- =================================================================== Guillaume DAMIAND CNRS - LIRIS UMR 5205 Université Claude Bernard Bâtiment Nautibus (710) 43 Boulevard du 11 Novembre 1918 69622 Villeurbanne Cedex (France) ------------------------------------------------------------------- Tél: +33 (0)4.72.43.14.34 Fax: +33 (0)4.72.43.15.36 Mail: Web: http://liris.cnrs.fr/guillaume.damiand/ ===================================================================
smime.p7s
Description: Signature cryptographique S/MIME
- [cgal-discuss] Speeding Up Arrangement Insertion, Bruno Silva, 11/05/2021
- RE: [cgal-discuss] Speeding Up Arrangement Insertion, Bruno Silva, 11/05/2021
- Re: [cgal-discuss] Speeding Up Arrangement Insertion, Andreas Fabri, 11/05/2021
- Re: [cgal-discuss] Speeding Up Arrangement Insertion, Guillaume Damiand, 11/05/2021
- Re: [cgal-discuss] Speeding Up Arrangement Insertion, Efi Fogel, 11/09/2021
