- To:
- Subject: Re: [cgal-discuss] Union of balls and self-intersecting mesh
- Date: Wed, 24 Nov 2021 09:26:21 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-data: A9a23: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
- Ironport-hdrordr: A9a23:3nym2qPr4ZlE9cBcTtyjsMiBIKoaSvp037BL7TETdfU7SL38qynDppomPHzP6Ar5JktQ++xoUZPoKRi3yXcS2+gs1NyZMDUO1lHEEGgb1+Tf/wE=
- Ironport-phdr: A9a23:Vy+F0h/bg5w5u/9uWX27ngc9DxPPW53KNwIYoqAql6hJOvz6uci4ZQqDur401geBdL6YwsoMs/DRvaHkVD5Iyre6m1dGTqZxUQQYg94dhQ0qDZ3NI0T6KPn3c35yR5waBxdq8H6hLEdaBtv1aUHMrX2u9z4SHQj0ORZoKujvFYPekdm72/q99pDRbAlEmSSxba9vJxiqsAvdsdUbj5F/Iagr0BvJpXVIe+VSxWx2IF+Yggjx6MSt8pN96ipco/0u+dJOXqX8ZKQ4UKdXDC86PGAv5c3krgfMQA2S7XYBSGoWkx5IAw/Y7BHmW5r6ryX3uvZh1CScIMb7S60/Vza/4KdxUBLmlTkJNzA5/m/UhMJ/gq1UrxC9qBJw2IPUfIKYOeBicq/Bc94XR2xMVdtRWSxbBYO8apMCAfcfMulDtYb9vEcOrRqgCgmqGejhzDhIhmX33a09z+QqDAbL3BckH9IJqnTUrdL1NLsIXeCwyKnF1jrDb/ZM1jf87IjEaAwuofaJXb9pd8fa1EYgGR/fgFqKtYzlIy2a1v4Ls2WD8eZtSOOih3MopQ1vvzShxtkghpfJiI8XxV7I6SR0zYUrKdC3SkN3fNqpHptOuiyeK4Z4QswvTmB0tCg01rAKpZi2dzUExpQgwh7Qcf2Hc46Q7xLsVeaRPTd4hG9+d76lmxmy9k2gxvX9VsmyylZKrzBKnsPCtnAX0RHY98uJSuNl80u/xTqC0xrf5+JELEwui6bXN50szqQwm5YNqUjOHSz7lF/ogKOLckgo4Pak5/r5brn8u5ORNJF4hwfjOao0gMO/G/43Mg0WUmib5+u80Lrj8FX8QLpQj/02lrDVv47HKsgGv6K5DQ9Y3pg55xawCDem19sYnX0ZI15fZB2HiI3pN0nPIPD+E/i/n0yhnCl3y/3CJLHsAZXAImLdnLv9frtx8U5RxBQrwdBa/Z1UC7UBIPzpWk/2sdzVFgQ5Mwizw+b9CdV90Z8eVXiKAq+dK67SvlqI6fguI+mIfoMapDH9K/096/70kXA5gUMdfbWu3ZYPdH+4Ee5pI0GAbXXxg9cBCnsFvhclTOzxk1CCSj5SZ3OqX60m/D07CYSmDZ3CRo+3mrCB0j27TdVrYHtbAAWMDWvwbNfDHOwdbTqbZM5niD0NE7a7DJQw0Amn8w78xb0gJeXd/mgUtInoycNutNDVjgw4yTFkE5Gdz32VVDMz2XgZQic/mqF5u010jFmZlrNphuRRUt1V6fQOWQgzMdvQzvdxFsvpCT7GK9yGQVLjTtS9CiwqVfowxcUPagBzAYaMlBfGihGnCbYOi72GAtQQ9bjd2GS5c915zGzH07Vnil0OTc5GNGngjal6oVuAT7XVmlmUwv75PZ8X2zTAoT/rJYumuUhZVEt9XfyAUy1FIETRqtv96wXJSLr8UdzP3SNOzMeDLu1Bbdi71D2uod/sPd3fZyS6nGLiXX61
Thanks I could reproduce the issue.
So it turns out that this function does not use the mesher but a dedicated code.
As it is based on the dual of the Delaunay triangulation and that your
points are on a grid, I suspect that the dedicated code does not handle
correctly degenerate cases. To check that, I added some noise to the
input points and that removed the self-intersecting faces (mostly because of degenerate faces).
I opened the following issue to track the patching:
https://github.com/CGAL/cgal/issues/6147
Best,
Sebastien.
On 11/23/21 8:55 PM, Bruno Manganelli ( via cgal-discuss Mailing List) wrote:
Here is a somewhat minimal example.
Hope it's good enough!
Bruno
On Tue, Nov 23, 2021 at 5:55 PM Sebastien Loriot < <>> wrote:
It should not happen. IIRC, it is the output from the Surface_mesher
so it should be clean.
Would you have a minimal example showing the problem?
Best,
Sebastien.
On 11/23/21 6:44 PM, Bruno Manganelli (
<> via
> Hi,
> I am using the Union_of_balls_3 class and the mesh_union_of_balls_3
> function.
> However, in certain scenarios, the resulting mesh contains
> self-intersections (PMP::does_self_intersect(mesh) returns true).
> Is this expected?
> I can provide an example if required.
> Thanks!
> Bruno
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
<https://sympa.inria.fr/sympa/info/cgal-discuss>
-- You are currently subscribed to cgal-discuss.
- [cgal-discuss] Union of balls and self-intersecting mesh, Bruno Manganelli, 11/23/2021
- Re: [cgal-discuss] Union of balls and self-intersecting mesh, Sebastien Loriot, 11/23/2021
- Re: [cgal-discuss] Union of balls and self-intersecting mesh, Bruno Manganelli, 11/23/2021
- Re: [cgal-discuss] Union of balls and self-intersecting mesh, Sebastien Loriot, 11/24/2021
- Re: [cgal-discuss] Union of balls and self-intersecting mesh, Bruno Manganelli, 11/25/2021
