- To:
- Subject: [cgal-discuss] texture mapping
- Date: Wed, 24 Nov 2021 11:29:22 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-data: A9a23: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
- Ironport-hdrordr: A9a23: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
- Ironport-phdr: A9a23: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
Hello,
I am using this tutorial (https://doc.cgal.org/latest/Surface_mesh_parameterization/index.html)
to texture a surface I have. I could generate the UV map and
corresponding vertices. But the tutorial does not give any code about
how to achieve the final textured output as it is shown in the tutorial
figure (3rd one). I am new to CGAL and Computer Graphics. Can you please
guide me with some code which is available.
Thank you in advance,
Regards
- [cgal-discuss] texture mapping, Vi Gho, 11/24/2021
- Re: [cgal-discuss] texture mapping, Sebastien Loriot, 11/25/2021
