- To: Ewen Denney <denney AT irisa.fr>
- Cc: coq AT pauillac.inria.fr
- Subject: Re: Unfolding lets
- Date: Mon, 16 Aug 1999 15:58:19 +0200
> Salut,
> What is the general way of going about `unfolding lets'? The folowing
> example shows the kind of thing:
> Variable f : nat -> nat*nat.
> Hypothesis H : (n:nat) ((Fst (f n)) = O).
> Goal let (n,_) = (f O) in (n=O).
> The example I actually have is where f is some complicated thing defined
> elsewhere and I want to move the binding n = Fst (f O) up into the
> assumptions somehow, so that I can work on the body.
> Ewen
Here you have to be aware that "let" is simply a shorthand for Case.
Now, the problem is that doing "Case (f O)" will introduce an
arbirtrary couple, for which hypothesis H is useless. One method to
make sure one remembers that Fst always returns O on this couple is
to make sure a suitable instance of H is in the scope of the "Case"
command:
Generalize (H O);Case (f O);Simpl;Auto.
Another method, easier to generalize, is to keep the relation between
(f O) and the couple as an equality. Here is the technique:
Cut (f O)=(f O);[Pattern -1 (f O);Case (f O);Intros n1 n2 H1|Auto].
Then you get to the following goal, which is quite handy for
all kinds of purposes...
n1 : nat
n2 : nat
H1 : (f O)=(n1,n2)
n1=O
For instance, you can now do:
Rewrite <- H with n:= O;Rewrite H1;Simpl;Auto.
This second method is the one I consider general.
Best regards
Yves
- Unfolding lets, Ewen Denney
- Re: Unfolding lets, Yves Bertot
- Re: Unfolding lets, Ewen Denney
