- To: freek AT cs.kun.nl (Freek Wiedijk)
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: Partial reflection?
- Date: Mon, 16 Aug 1999 16:47:57 +0200 (MET DST)
Hi Freek,
I cannot think about something simillar having been carried out. My
guess would be that if anything has been done, then it would be in the
NuPRL team; they have thought a lot about reflection and I do not know
all their work. You may also fish some ideas looking at people having
worked on conditional rewriting, but I have absolutely no pointer on
the topic.
On the topic of a Field tactic, and more generaly about using
reflection for partial functions, there is certainly some interesting
work to be done. Using an inductive relation is interesting. I am
however not totaly sure it is necesary in your case. The division
function simply takes a third argument, namely a proof that the second
argument is not zero. My guess would be that the tactic then generates
this condition as a sub-goal ?
But provided you have added this condition as a hypothesis, I guess
you can use a traditional interpetation function ?
I write this without having thought much about it, so I certainly can
be wrong.
Cheers,
Benjamin
- Partial reflection?, Freek Wiedijk
- Re: Partial reflection?, Benjamin Werner
- Re: Partial reflection?, Cuihtlauac ALVARADO - STAGIAIRE A FT.BD/CNET/DTL/MSV
